Ajutor resetare indicator nivel combustibil la un Peugeot 206+ 2009 1.4 HDi
  • Ajutor resetare indicator nivel combustibil la un Peugeot 206+ 2009 1.4 HDi
    Am observat acum cateva zile o problema mai ciudata, pe care as vrea sa o impartasesc cu voi pentru a putea gasi o solutie si eventual pentru a mai ajuta si alte persoane care intampina/vor intampina aceasta problema.
    Acum cateva zile am turnat vreo 10-12 L de motorina in rezervor, pana ce acul era aproape de ultima liniuta. Am lasat masina peste noapte in parcare, iar a 2 a zi cand am ajuns inapoi am observat acul fiind putin peste linia de mijloc a indicatorului.
    Cautand aici pe forum, am vazut ca este o problema destul de intalnita la gama Peugeot, problema care din pacate nu avea nici o rezolvare concreta ( sa mergi pana ramai fara motorina si apoi sa faci iar plinul nu mi se pare o rezolvare ).
    Asa ca m-am apucat sa mai sap putin pe internet. Aveti mai jos ceea ce am reusit sa gasesc:
    Hey again - Finally got around to the "rummage". This is what I found
    Model: 206 Full-mux, 307, 807, New Partner
    Motor: All
    Symptom: Tank Gauge and fuel quantity in the MF display is wrong.
    Solution: Synchronization between BSI and fuel gauge.
    Procedure:
    - Switch off ignition
    - Disconnect the fuel gauge black 6 pin connector
    - Apply by hand a resistor of 350 ohms between terminals 5 and 6 on a black 6-pin connector
    - Switch on ignition
    - Check that fuel gauge in the instrument group shows empty tank
    - Keep resistor in the plug for 30 seconds, so the BSI box will store the fuel level.
    - Apply a by hand a resistor of 50 ohms between terminals 5 and 6 on a black 6-pin connector
    - Check that fuel gauge in the instrument group shows full tank
    - Again, keep resistor in the plug for 30 seconds, so the BSI box will store the fuel level.
    - Reconnect the black 6 pin connector to the fuel gauge
    Subsequently, the BSI box and tank meter are synchronized.
    Good luck
    dar si peste asta:
    206 full multiplexed
    small pump
    Top 60Ω
    Middle 170Ω
    Bottom 350Ω
    large pump (1 pipe)
    Top 50Ω
    Middle 220Ω
    Bottom 350Ω
    large pump (2 pipes)
    Top 50Ω
    Middle 200Ω
    Bottom 350Ω
    206 pre multiplex Full 15Ω
    ½ 150Ω
    ¼ 220Ω
    Low (light on) 300Ω
    Empty (light on) 325Ω
    206 pre multiplex Top 14Ω
    Middle 165Ω
    Bottom 340Ω
    Intrebarile mele sunt:
    - cum iti dai seama ca masina este small, large pump 1 pipe sau large pump 2 pipes ?
    - unde trebuie sa conectezi rezistenta ? pe mufa care iese din rezervor / pompa sau in alta parte ?
    Multumesc !
    Astazi am dat bancheta spate jos si capacul negru care sta deasupra rezervorului si am scos mufa din pompa / plutitor. Asa am observat ca are decat 2 fire ... Asta oare pe ce principiu o merge ?
      Ai doar plutitorul la rezervor, cele 2 fire sunt de la el
