  • Originally posted by bobovis View Post
    Cine are un aparat foto mai de Doamne-ajuta si poate sa-l aduca diseara???
    Am eu
    • Merci, Sebi, esti un dragut.......
      Tigaia
      • Am aparatul foto cu mine in masina, incarcat, tot! Daca tu vrei un DSLR, nu am dinala)
        "Viewing who's online":))
        • Daca habar n-am ce inseamna un lucru, cu siguranta nu-l vreau....:blush:
          Tigaia
          • S-aude neică în surdină
            Huruială...de maşină,
            Vine Eduard pe ogoare
            Cu ghiers dulce-n cingătoare.
            Vine luminos în noapte,
            Zice versuri, dulce şoapte,
            Tuns, frezat, ferchezuit,
            ...poate şi niţel pilit...:cheer:
            Vine neică preagrăbit,
            Căci vezi Doamne...a auzit
            De-un băiet promiţător,
            Cu eclere-n rezervor.
            Bobo, bagă gaz şi el,
            Chiar de e mai mititel,
            Forumiştii-ncetinel,
            Se adună uşurel,
            Cu salivă-n gură tată,
            c-o s-o facem lată...lată!
            Basti vine ca şi vântu
            Vine de mâncă pământu,
            Ce mai gaşcă, nebunie,
            Cu eclere e orgie!:thumbup:
            ...am luat-o dreacu razna de tot!)))
            • Originally posted by Florian View Post
              Ce naiba e ala DSLR?
              Tigaia
              • :clapping: Florian
                • Jalonel s-a pregatit,
                  Are-o blonda de petit.
                  Vine tare din Berceni,
                  Zici ca este tras de reni
                    (Digital Single Lens Reflex) A digital still image camera that uses a single lens reflex (SLR) mechanism. Most professional cameras have always been single lens reflex cameras, although analog. Digital SLRs began to emerge in the early 1990s, but became very popular after the turn of the century. Following are the two major differences between DSLRs and standard digital cameras.
                    Removable Lenses
                    No single lens can accommodate every photographic requirement, and SLR cameras have always used removable lenses. A wide variety of lenses are available for each camera system, and many lenses that fit 35mm analog SLRs also fit digital SLRs. However, the CCD or CMOS sensor in a digital SLR is generally not as large as a 35mm film frame, and there is typically a multiplier factor in focal length. For example, using a multiplier factor of 1.5x, a 50mm lens on a 35mm camera is equivalent to a 75mm lens when attached to a digital SLR.
                    Through the Lens
                    In an SLR, the photographer sees the image through the actual picture lens. To compose the picture, a mirror reflects the light from the lens to the viewfinder. When the picture is taken, the mirror momentarily flips out of the way to allow the light to pass through the lens diaphragm to the CCD or CMOS sensor (or to film in an analog SLR). Through-the-lens viewing enables precise manual focusing because tiny LCD screens do not have sufficient resolution. In addition, holding the camera against the face helps steady it.
                    With the first digital SLRs, the LCD screen was used to review the recorded image, not to preview it for picture taking. In 2006, Olympus introduced the first DSLR with an LCD preview, and other camera vendors followed soon after. See digital camera and Four Thirds system.
                    Adica e mai smecher ))
                    • Hai, bine, m-ai lamurit.... Ia-l p'al tau, asa amarat cum o fi......:happy:
                      Tigaia
                      • Oricum l-am luat, am incarcat aseara acumulatorii, am golit cardul, e pregatit.
                        • V.O.I. N.U. S.U.N.T.E.T.I. N.O.R.M.A.L.I. !!!
                          Am intrat dimineata pe forum sa vad ce se mai anunta si era "liniste si pace" ..iar de la 17.30 citesc aici si rad cu lacrimi. NU sunteti normali!!!
                          PS: Edy, vezi ca si pe mine m-ai uitat :p
                          După 2 ani si jumătate de condus maşina am aflat că NU AM FAP
                          • Cand credeati ca ati scapat
                            Nebunu a inviat,
                            Si acasa e ajuns
                            Sa se-apuce de impuns.
                            Bobo nu e pe felie
                            Ce-i in cap si-n palarie,
                            El DSLR nu stie
                            Insa trage o piftie.
                            Florian gatit ca pruna
                            Vine si aduce una,
                            Una dulce, mititica
                            De incape intr-o sticla.
                            Dar mai bine pe capota
                            Ca poate e mai comoda,
                            Si decat sa faca spume
                            Mai bine sa iasa-n lume.
                            Bucataru' suna-n furca
                            Si ar mai gati si-o curca,
                            Dar de-atata vanzoleala
                            A pus-o si de-o tranteala.
                            El aduce multe bunuri
                            Branza, cascaval, salamuri
                            Iara la sfarsit ne-o trage
                            Cu o ciorba de potroace.
                            Fashy nu este pe lista
                            Edi ii da o batista,
                            Sa nu curga lacrimioara
                            Sa se-auda-n toata tara.
                            • Baiii !!! Eu am scris o gramada de poezii despre tine, si tu doar una despre mine? :mad:
                              • crisglam e un nick mai greu
                                Sunt poet doar, nu un zeu,
                                Si in versuri daca-l bag
                                Tare-mi e ca nu-l mai trag.
                                Ca el este barosan
                                Brici, cu freza, mentosan,
                                Si vine mancand asfaltu'
                                Stropi de bale cad pe altu'.
                                O fi el mai cintezoi
                                Si se pune cu alti 2,
                                Dar degeaba-i strategia
                                Ca eu ii stiu meseria.
