Vand Amplificator Kicker si SUB Pioneer
  • [Vānd] Vand Amplificator Kicker si SUB Pioneer
    Vand amplificator Kicker ZX400.1
    mono subwoofer amplifier 200 watts RMS x 1 at 4 ohms (400 watts x 1 at 2 ohms)
    variable low-pass filter (50-200 Hz at 24 dB per octave)
    variable bass boost (0-18 dB at 40 Hz)
    subsonic filter (12 dB at 25 Hz)
    wired remote bass level control
    Class D design
    CEA-2006 compliant
    speaker-level inputs
    preamp inputs and outputs fuse rating: 40A x 1
    si
    sub Pioneer TS-W308D4 12-Inch in cutie custom facuta dupa dimensiunile celei orginale. Este legat pe 2 ohm.
    FEATURES
    Size 12"
    Woofer Cone Material Interlaced Basalt/Carbon Fiber Reinforced IMPP Cone
    Woofer Cone Design Cone Reinforcement Arcs
    Surround Wide Roll, Three-Layer Fiber Woven Radial
    Voice Coil 4-Layer, Long Voice Coil
    Voice Coil Wire Copper
    Voice Coil Bobbin Phenol Resin Coated Glass Cloth
    Damper (Spider) Aramid Fiber
    Damper Ring Yes
    Top Plate Standard
    Projected Pole Yoke with Vented Pole
    Magnet Construction Double Mass High-Power (83oz)
    Basket Design Stamped Basket with Magnet Cover
    Gasket ABS
    Wire Terminals Integrated Single-Sided Silver Compression Terminals
    SPECIFICATIONS
    Watts MAX. Music Power 1400 Watts
    Watts Nominal Power Handling 400 Watts
    Frequency Response 20 ~ 180Hz
    Sensitivity D2 (90d D4 (92d
    Ohm Rating D2: (1 or 4 ohm) D4: (2 or 8 ohm)
    Recommended Enclosure 0.85 ~ 1.75 Cubic Feet
    Dimensions 327 mm x 172 mm
    Mounting Depth 153 mm
    Accessory Grill UD-G308
    Pret amandoua 400 lei.
    "Am citit regulile comerciale si le voi urma cu strictete"
    Contact - forum, PM
