Mini PC Android Tronsmart Orion R28 Meta RK3288 Quad-core 1.8GHz (Cortex-A17)
  • [Vând] Mini PC Android Tronsmart Orion R28 Meta RK3288 Quad-core 1.8GHz (Cortex-A17)
    Noul model android cel mai puternic de pana acum, motorizat de un procesor de ultima generatie RK3288 Quad-core 1.8GHz (Cortex-A17) si o placa grafica Quad Core Mali-T764 GPU ce permite rularea celor mai exigente jocuri, aplicatii si filme, pe o versiune software Android KitKat 4.4.
    Ca o noutate, acest model suporta actualizarea OTA & OTG, ceea ce inseamna ca producatorul va transmite automat actualizarile catre android box-ul dumneavoastra fara nici o interventie din partea utilizatorului.
    In curand va fi disponibila versiunea de soft Android 5.0 Lolipop. De asemenea, inainte de predarea produsului se poate instala diverse programe de vizionat filme si seriale online la cea mai buna calitate, inclusiv cu subtitrare.
    Produsul este nou
    Detalii producator:
    Brand Tronsmart
    Model Orion R28 Meta
    Material Plastic
    Color Black
    Operating System Google Android 4.4, Support OTA function
    CPU Brand Rockchip
    CPU Model RK3288 1.8GHz (Cortex-A17)
    CPU Cores Quad-Core
    GPU Quad Core Mali-T764 GPU
    Memory DDR3 2GB
    Internal Storage Onboard Nandflash 16G
    Expand Memory Micro SD Card (Maximum support 32G
    Antenna External wifi antenna
    Ethernet 10/100M/1000M LAN
    Wifi Connectivity IEEE 802.11 a/b/g/n/ac, 2.4GHz/5GHz
    Camera N/A
    Bluetooth Bluetooth 4.0
    3G N/A
    Video Supported Support 2160P muti-format video decode, H.265, 4K*2K
    Audio Supported Support: MP3/WMA/APE/FLAC/AAC/OGG/AC3/WAV
    Picture Support: Max.8000x8000 JPEG /BMP /GIF /PNG
    HDMI Port Standard HDMI A Type out
    HDMI Version 2.0
    Additional Function 1 x IR Sensor
    Other Interface 1 x Blue power LED
    1 x Power Button
    1 x Update Button(via one pin hole)
    3 x Standard USB
    1 x Micro USB with OTG
    1 x DC in Jack
    1 x S/SPDIF (2CH, 5.1CH)
    1 x RJ45
    1 x Micro SD card slot
    1 x AV Jack
    Reserved, 2*RS232
    Pachetul contine:
    1 Android PC
    1 Alimentator
    1 Cablu HDMI
    1 Cablu mini USB
    1 Fly Mouse
    De departe cel mai de succes PC Android realizat pana acum.
    PRET: 540 RON
    Contact: 0735356156 - George
    "Am citit regulile comerciale si le voi urma cu strictete”.
    Am uitat sa mentionez, produsul beneficiaza de garantie 12 luni.
