What features do you know Peugeot 406 have?
  • What features do you know Peugeot 406 have?
    Peugeot 406 adopted a new generation of EW, engine emissions to 1997 ml, 16 valve, maximum power 99 kw, due to reduce body weight, top speed of 280 km/H, 0-100 km/H speed time of 10.8 seconds.3.0 litres of O - 100 km/h speed up time of 8.3 seconds, is very good.
    The size of the car is 4555 mm long, width is 1765 mm, modest. Modelling respect is also but do not break, the overall impression is not the route of luxury car, low inclined forward and fresh hood costume body line is in that it smell. Such a luxury car, of course, the original car intelligent anti-theft system will be served onboard, the car's safety also have relatively comprehensive care, including in front of the dual airbags; Match hand and a more safety of explosive preloaded belts; The front door with a built-in collision stiffener (it's a pity that the back door no);Headlamps beam projection Angle can be adjusted in the car; Automatic induction wiper; Front fog lamps; High brake lights. It's fair to say that it has good safety equipments should be.
    Peugeot 406 front axle are equipped with anti-roll bar, set of hanging is soft, so the roll around the pile when the car is not obvious, also won't people be eight to seven meat, according to the steering wheel to the almost of the car, but because it is as the design, the speed faster, already can feel on the rear of the stirring, began to have a sign outside. After all is a 2.0 L car, receiving, refueling reaction or not agile enough. The 3.0 L engine torque is good, a sense of speed of piling is slightly better.
    The sound insulation of the very quiet in the car, they do well. Air-conditioning outlet lowest temperature, too, are seven degrees Celsius. Although idle when very quiet, but really run was different. Every time acceleration, engine speed exceeds 3500 turn, noise coming from the engine room to start feels more noisy.
