Regulament sectiune.
My 407
    Frumoasa....sa o stapanasti sanatos si fara incidente
    Trimis de pe al meu LG-D605 folosind Tapatalk
      Linie de produs 407
      Nr. APV/PR 10574 CJ 2 0823
      Data de Inceput de Garantie 18.03.2006
      NRE e2*2001/116*0297*04
      Informatii generale
      GENRE DE PRODUIT VEHICUL PARTICULAR
      MARQUE COMMERCIALE, TYPE ORGANE PEUGEOT
      LIGNE DE PRODUIT 407
      SILHOUETTE BERLINA 4 USI
      FINITION AA GRIFFE
      MOTEUR DIESEL TURBO DW10BTED4 FILTRU DE PARTICULE
      TRANSMISSION CUTIE DE VITEZE MANUALA6
      TYPE DE PEINTURE VOPSEA METALIZATA LACUITA
      COULEUR DE CAISSE EXL - VOPSEA NEGRU OBSIDIAN
      TYPE D’HABILLAGE INTÉRIEUR PIELE GRAIN CLAUDIA L019 "CY"
      COULEUR DE GARNISSAGE "FT"
      BOITE DE VITESSES (CARACTÉRISTIQUES) CUTIE DE VITEZE MANUALA ML6 CL
      MOTEUR (TYPE) MOTOR TIP EW/DW
      Caracteristici vehicul
      Alimentare motor
      FILTRE RÉSERVOIR FARA FILTRU REZERVOR
      BOÎTIER PAPILLON (ADMISSION AIR MOTEUR) MODUL CLAPETA MOTORIZATA (ADMISIE AER MOTOR)
      DÉTECTEUR D’EAU FILTRE À GAZOLE FARA SISTEM DE DETECTARE APA IN FILTRUL DE MOTORINA
      CARBURANT MOTORINA
      DÉPOLLUTION (MOTEUR) DEPOLUARE EURO 4 (MOTOR)
      REFROIDISSEMENT D’HUILE SCHIMBATOR APA/ULEI MOTOR
      RÉCHAUFFAGE CIRCUIT GAZ CARTER FARA SISTEM DE INCALZIRE CIRCUIT DE GAZE CARTER
      VARIATION PUISSANCE (MOTEUR) PUTERE STANDARD
      AUTODIAGNOSTIC EOBD SISTEM DE AUTODIAGNOSTICARE "EOBD"
      DISPOSITIF (ANTIPOLLUTION) RECIRCULARE GAZE DE ESAPAMENT "EGR"
      DÉPOLLUTION TECHNIQUE VÉHICULE DEPOLUARE TEHNICA VEHICUL EURO4
      FILTRE À PARTICULE FILTRU DE PARTICULE
      VENTILATEUR 1 VENTILATOR ELECTRONIC CU COMANDA INTEGRATA 150W
      VARIANTE ASSOCIÉE INJECTION SISTEM INJECTIE SIEMENS
      Cutie de viteze - Transmisie
      COUPLE RAPPORT RAPORT PUNTE 17 X 71
      STYLE ROUE ROATA COSMOS 17 INCI
      EMBRAYAGE AMBREIAJ HIDRAULIC
      DIFFÉRENTIEL (BOITE) DIFERENTIAL 86
      JANTE / PNEU DIMENSION ECHIPARE PNEU 17 INCI
      PNEUMATIQUE (DIMENSIONS, TYPE) PNEU 215/55 R17 94W NERANFORSAT
      ROUE (TYPE) MONTARE ROATA ALIAJ 3
      INDICATEUR DE PERTE DE PRESSION DE GONFLAGE INDICATOR PIERDERE PRESIUNE PNEURI
      BOITE DE VITESSES TYPE ML6C
      DIRECTION (FONCTIONNEMENT) DIRECTIE ASISTATA ELECTROHIDRAULIC
      COLONNE DIRECTION COLOANA DE DIRECTIE CU REGLARE MANUALA
      DIRECTION MECANISM DE DIRECTIE ASISTATA CARE NU ESTE VARIABILA
      ANTIDÉVERS AVANT BARA ANTIRULIU FATA DIAMETRU 24
      COURSE MÉCANISME DE DIRECTION CURSA MECANISM DE DIRECTIE 174
      SUSPENSION SUSPENSIE NORMALA
      SUSPENSION ACTIVE FARA SUSPENSIE VARIABILA
      CONTRÔLE DYNAMIQUE DE STABILITÉ CU SISTEM ESP
      Caroserie Echipamente
      ACCÈS ET DÉMARRAGE MAINS LIBRES FARA ACCCES SI PORNIRE MAINI LIBERE
      ATTACHE-REMORQUE FARA DISPOZITIV DE REMORCARE
      ENJOLIVEMENT LATÉRAL (ASPECT) ELEMENTE PROTECTIE LATERALA VOPSITE IN MASA + CROMATE
      ENJOLIVEMENT LATÉRAL (DIMENSION) ELEMENTE DE PROTECTIE LATERALE + TREAPTA
      ENJOLIVEUR ROUE (STYLE) FARA CAPAC DE ROATA
      FEU D’ÉCLAIRAGE DE SEUIL LUMINA PENTRU PRAG
      COMPLÉMENT DE PROTECTION (SOUS MOTEUR) FARA PROTECTIE SUPLIMENTARA SUB MOTOR
      FONCTION COMPLÉMENTAIRE RÉTROVISEUR EXTÉRIEUR RETROVIZOR EXTERIOR RABATABIL ELECTRIC CU MEMORIE
      ESSUIE-VITRE AVANT MECANISM STERGERE PARBRIZ CU SENZOR DE PLOAIE
      ESSUIE-VITRE ARRIÈRE FARA MECANISM DE STERGERE LUNETA
      ESSUIE-PROJECTEUR MECANISM DE STERGERE PROIECTOR
      OBTURATEUR FACE AVANT FARA OBTURATOR PARTE FRONTALA FATA
      VITRE PAVILLON FARA ELEMENT VITRAT DE PAVILION
      ROUE DE SECOURS ROATA JANTA TABLA + PNEU STANDARD
      ACCESSOIRES EXTÉRIEURS MANERE EXTERIOARE + RETROVIZOARE EXTERIOARE CULOARE CAROSERIE
      TOIT OUVRANT ACOPERIS FIX
      ENJOLIVEMENT PARE-CHOCS BANDOU DE BARA DE PROTECTIE COLORAT IN MASA + ORNAMENT INOX
      VITRE (ASPECT) GEAM FUMURIU
      VITRE (TYPE) PARBRIZ + GEAMURI LATERALE STRATIFICATE + LUNETA SECURIZATA
      Echipament interior
      SAC GONFLABLE GENOUX CONDUCTEUR AIRBAG ZONA GENUNCHI CONDUCATOR
      ALARME ANTIVOL FARA ALARMA ANTIFURT
      ACCOUDOIR ASSISE ARRIÈRE CU COTIERA SPATE
      CEINTURE DE SÉCURITÉ ARRIÈRE CENTURI DE SIGURANTA PIROTEHNICE LATERAL SPATE CU RETRACTOR + CENTURA IN 3 PUNCTE
      CLIMAT (TEMPÉRATURE AMBIANTE) TARI CU CLIMA TEMPERATA
      CONDAMNATION ENFANT SIGURANTA COPIL USI SPATE CU COMANDA ELECTRICA
      GRADUATION VITESSES GRADATIE IN KM/H
      COTÉ DE CONDUITE (POSTE DE CONDUITE) VOLAN PE STANGA
      CHAUFFAGE ADDITIONNEL FARA SISTEM DE INCALZIRE SUPLIMENTAR
      EQUIPEMENT PLANCHE DE BORD DECORATIUNE GEOMETRICA
      COMBINÉ (CARACTÉRISTIQUES) GRADATIE 260 KM/H 160 M/H FUNDAL TRANSPARENT
      GARNISSAGE DE PORTE DECORATIUNE GEOMETRICA
      HAUT-PARLEUR 4 DIFUZOARE FATA (2 TWEETERE + 2 DIFUZOARE) + 5 DIFUZOARE SPATE (2 TWEETERE + 2 DIFUZOARE + 1 SUBWOOFER)
      COMMANDE D’AUTORADIO COMANDA SISTEM AUDIO LA DISTANTA
      ISOLATION (RIDEAU, PARE-SOLEIL LATÉRAL, TOIT OUVRANT) TRANSPERANT SPATE CU COMANDA MANUALA
      REHAUSSE ASSISE AVANT PASSAGER DISPOZITIV DE INALTARE PERNA PASAGER REGLARE PARALELA + AVANSARE
      COMMANDE ASSISE AVANT CONDUCTEUR COMANDA SCAUN CU MEMORIE CONDUCATOR
      COMMANDE ASSISE AVANT PASSAGER COMANDA ELECTRICA SCAUN PASAGER FATA
      RÉGLAGE ASSISE AVANT PASSAGER REGLARE SUPORT LOMBAR PASAGER
      COMPACT DISQUE MONTARE COMPACT DISCURI
      SYSTÈME DE NAVIGATION CU SISTEM DE NAVIGATIE CU ECRAN COLOR
      LAMPES DE PROJECTEURS LAMPA CU DESCARCARE
      LÈVE-VITRE ARRIÈRE MECANISM DE ACTIONARE ELECTRICA GEAM SPATE CU COMANDA SECVENTIALA + BLOCARE
      AFFICHEUR AFISAJ (NAVIGATIE+VIDEO+RADIO+CEAS,T°,CD)
      MIROIR DE COURTOISIE OGLINDA CONDUCATOR + PASAGER ILUMINATA CU CAPAC
      INDICATEUR D’HUILE SENZOR CU FUNCTIE DUBLA NIVEL + TEMPERATURA ULEI
      NAPPE CHAUFFANTE SCAUN CU INCALZIRE
      SAC GONFLABLE LATÉRAL AVANT AIRBAG LATERAL ZONA TORACE FATA + SPATE + AIRBAG CORTINA
      ECLAIRAGE BAS HABITACLE FARA ILUMINAT INFERIOR DE HABITACLU
      NEUTRALISATION COUSSIN GONFLABLE DEZACTIVARE MANUALA AIRBAG
      PROJECTEUR CORRECTEUR ASSIETTE REGLARE AUTOMATA A PROIECTOARELOR
      PROJECTEUR DIRECTIONNEL FARA PROIECTOR DIRECTIONAL
      RÉCEPTEUR RADIO SISTEM RADIOTELEFON "RT3"
      RÉFRIGÉRATION SISTEM DE REFRIGERARE AUTOMATA
      RÉGULATEUR DE VITESSES SISTEM DE REGULARIZARE SI DE LIMITARE VITEZA
      REHAUSSE ASSISE AVANT CONDUCTEUR SISTEM DE INALTARE PERNA SCAUN CONDUCATOR CU REGLARE ELECTRICA
      RÉTROVISEUR INTÉRIEUR RETROVIZOR INTERIOR CROMAT ELECTROCHIMIC CU POZITII ZI-NOAPTE
      RÉGULATION CLIMATISATION / TEMPÉRATURE SISTEM DE REFRIGERARE AUTOMATA CU DOUA ZONE
      TUNER-RADIO TUNER DUBLU RADIO
      PROTECTION INTÉRIEURE FARA PROTECTIE INTERIOARA
      DÉTECTION D’OBSTACLE DETECTOR DE OBSTACOLE SPATE
      STORES LATÉRAUX TRANSPERANTE LATERALE "RAND 2"
      ADAPTATION GARNITURE MANER MANETA DE VITEZE PIELE
      AMPLI-ÉQUALISEUR CU AMPLIFICATOR EGALIZATOR
      COMMANDE VERROUILLAGE BLOCARE PRIN SIMPLA INCHIDERE
      VOLANT VOLAN IMBRACAT IN PIELE CU 3 BRATE
      Electricitate
      ALTERNATEUR ALTERNATOR CLASA 18
      BATTERIE BATERIE L3 450
      DÉMARREUR DEMAROR CLASA 6+
      ECLAIREMENT PARTICULIER APRINDERE AUTOMATA A LUMINILOR
      FRÉQUENCE RADIO FRECVENTA RADIO EUROPA OCCIDENTALA
      Marci echipamente
      Diverse
      CRITÈRE VARIANCE, CLIENTÈLE CONCEPTION STANDARD
      ATMOSPHÈRE ATMOSFERA NORMALA
      ROULAGE DRUM CORECT
      BOÎTIER SERVITUDE BSI COMM 2003
        frumos rau...memorii scaune, hm..ai cumparat o din romania?
          Frumos, s-o stapanesti sanatos! Are si trapa?
          GTI Edition 35 Stage 2+
            Da am luato din romania masina o cunosc de cand a fost cumparata a fost al uni prieten eu am servis auto si eu iam facut servisurile si am cunoscuto. Edy.EEM nu are trapa.
              Poze cu leuti
              Lei mei dragi
                My 407
                Sa-i stapanesti sanatos !
                Ai si un mesaj privat
                Lion 4ever
                Lion King
                Ex Peugeot 407
                  Originally posted by vdobrican View Post
                  Lei mei dragi
                  Atentie cand intrii in cusca lor )
                  Multi km fara probleme cu ambii lei.
                    Frumoasa.Interiorul din piele e bestial.Trebuia pus in prim plan 407 cand le-ai facut poze la amandoua.
                    Peugeot 407SW 110CP.
                      E mai rusinoasa, e noua in curte Sa o stapanesti sanatos, arata bine, e si dotata.
                      Felina mea
                        Va multumesc, nu musca sunt foarte blanzi.
                          Azi a primit o distributie noua Contitech si pompa apa
                            Sambata i-am curatat tubulatura de la clima si schimbatorul de temperatura la 407 urmeaza sa ii fac si la 307, nu mai baga nici un fel de miros.
                              Azi i-am schimbat toate bujiile Beru si am curatat si egr-ul daca tot lam dat jos dar era curat doar putin fum deloc depunere acuma are 242800 km.
