208 e bomba. Abia astept sa il vad la cursa.
Peugeot 208 T16 Pikes Peak - 875 kg / 875 cp
De Hyundai ati auzit?
LE:
Daca pentru 208-ul lui Loeb am gasit specificatii tehnice, pentru Genesis Coupe nu au fost puse la dispozitie date tehnice (cel putin eu n-am gasit), ci doar dezvaluita puterea, 900 CP, fata de 700 CP cat avea Hyundai-ul anul trecut, cand Millen a stabilit recordul cursei.
PEUGEOT 208 T16 PIKES PEAK TECHNICAL SPECIFICATION
ENGINE
Type V6 bi-turbo
Cubic capacity 3.2-litres
Number of valves 24
Position Mid-rear
Number of cylinders V6 (60°)
Maximum power 875hp
Torque 90mkg
Maximum revs 7,800rpm
Top speed 240kph / 150mph
0-100kph / 0-62mph 1.8s
0-200kph / 125mph 4.8s
0-240kph / 150mph 7.0s
TRANSMISSION
Type Four-wheel drive
Gearbox Longitudinally-mounted six-speed sequential gearbox with steering wheel-mounted paddle-shift
CHASSIS
Frame Tubular steel
Bodywork Carbon
SUSPENSION / BRAKES / STEERING
Suspension Double wishbones & pushrod/rocker arm actuation at all corners
Springs Torsion bars
Dampers Pressurised dampers
Anti-roll bars Front and rear
Steering Hydraulic power steering
Brakes Hydraulic double circuit brake system with one-piece light alloy callipersBrake discs Vented carbon discs front and rear
Diameter (front): 380mm / Diameter (rear): 355mm
Wheels Specific 18x13 magnesium alloy wheels derived from F1 technology
Tyres Michelin (31/71x18)
DIMENSIONS
Length 4,500mm
Width 2,000mm
Height 1,300mm
Front / rear overhang 1,690mm
Wheelbase 2,695mm
Wing 2,000mm (based on the rear wing of the Peugeot 908)
Fuel tank 40 litres
Weight 875kgLast edited by bobovis; 10-05-2013, 03:27 PM.
La Pikes Peak acolo nu prea mai are treaba firma in sine care se prezinta cu masina... asa a fost si Duster de 859 de cai , motor de la Nissan GT-R , deci ca e Hyundai , Dacia , Peugeot , etc nu prea are nici o treaba . Mai mult depinde cine e in spatele volanului , si cum la 208 va fii Loeb , pe unde a fost si s`a concurat pe asfalt nu prea a avut cu cine sa discute
, sunt curios ce va fii .
De ex la filmarea de la Hyundai , la min 5.56 pilotul greseste . Daca te uiti atent , termina virajul si schimba 2 trepte , nu`mi dau seama cum... dupa sunet , masina pare ca nu trage deci schimba 2 in jos , dupa miscarea mainii , mi se pare ca trage de maneta , deci ar schimba 2 trepte in sus . Oricum ar face pierde timp , d`asta zic , ca , conteaza mai mult cine e in spatele volanului . Masinile in teorie sunt cam egale[URL="http://www.peugeotclubromania.ro/forum/threads/28646-Golden-Lion"][B]Leul turbat[/B] [COLOR=#0000FF][B]4[/B][/COLOR][COLOR=#D3D3D3][B]0[/B][/COLOR][COLOR=#FF0000][B]7[/B][/COLOR][/URL]
Corect, in cursa (de altfel ca in imensa majoritate a curselor) conteaza piesa dintre volan si scaunul soferului. Dar anul acesta Loeb este rookie, Rhys Millen este veteran, daca pot sa-i spun asa. In plus Millen beneficiaza si de sfaturile tatului sau, Rod, care a fost de 5 ori campion la clasa Unlimited. Iar Loeb este si el om, mai greseste din cand in cand...
http://www.amsonline.ro/sebastian-lo...la-pikes-peak/
Sebastien Loeb, multiplu campion mondial īn WRC, a concurat īn faimoasa cursă americană de la Pikes Peak și a reușit să fie primul pilot din istorie care parcurge traseul īn mai puțin de nouă minute.
După nouă titluri īn WRC, Sebastien Loeb avea nevoie de o nouă provocare, pe care a găsit-o concurānd la Pikes Peak. Mașina special construită pentru acest eveniment a fost un Peugeot 208 T16, propulsată de un V6 biturbo de 875 CP. Masa mașinii, de doar 875 kg, īnseamnă că bolidul a avut un raport putere/greutate de 1CP/1kg.
Noua supermașină a lui Loeb
Avānd īn vedere aceste cifre, nici nu este de mirare că mașina poate accelera de la 0 l 100 de km/h īn doar 1.8 s, iar viteza de 240 km/h este atinsă īn 7 s.
Loeb a reușit să termine cursa de la Pikes Peak īn 8 minute și 13.87 s, cu peste un minut și 30 de s mai puțin decāt recordul anterior stabilit de către Rhys Millen anul trecut. Anul acesta, Millen a parcurs cei 20 de km īn 9 minute și 2 s.
http://www.youtube.com/watch?feature...nz8i14E#at=201Peugeot 508 RXH, 2.0 HDI Hybrid, 200 CP
