NLS_LOWER
  • [Propunere] NLS_LOWER
    Style= &quot Robinet de salle de bain;font-size:14px;" > these functions all received parameters is the character group type (except CHR) and returns the character value. In addition to the special instructions, values of these functions most return type VARCHAR2. By the return type character function limit and the basic type of database constraints are the same, for example: VARCHAR2 value is limited to 2000 characters (ORACLE 8 to 4000 characters), while the CHAR value is limited to 255 characters (2000 in ORACLE8). When used in the process of statements, they can be assigned to the PL/SQL variable.ASCII grammar VARCHAR2 or CHAR type: ASCII (char c the function): the first character returns a string of ASCII code, his inverse function is CHR () using position: process and SQL statement.select ASCII ('') from dual select Chr (49886); from dual; CHR syntax: Chr (x) function: back in the database character set has the equivalent numerical and X characters.CHR and ASCII are a pair of inverse function.After CHR conversion character after the ASCII conversion and the character of the original. uses position: process and SQL statement.CONCAT syntax: CONCAT (C1, C2) function: C1, C2 as string, the function will C2 connected to the C1, if C1 is null, returns c2. if C2 is null, it returns C1, if C1, C2 is null, null is returned, he and the operator || returned results the same. using position: process and SQL statement chemise tommy hilfiger.Syntax: INITCAP INITCAP (string) function: the first letter capitalized words and the other letters in lowercase string each word string.The word is used. A space or for alphanumeric character by spaces, control characters, punctuation separation.Not alphanumeric. uses position: process and SQL statement.select INITCAP ('luo, Jia, you') from dual; select INITCAP ('luo Jia you') from dual; LTRIM syntax: LTRIM (string1, string2) function: return to delete from the left is the characters that appear in string2 string1.String2 is the default setting for the individual space.The database will scan string1 Ballon de football, starting with the leftmost.When does not meet the first character in string2, results are returned.The behavior of LTRIM and RTRIM are very similar. uses position: process and SQL statement.Syntax: LOWER LOWER (string) function: returns a string Lunettes de soleil hommes Mont Blanc, and all characters lowercase using position: process and SQL statement.NLS_INITCAP syntax: NLS_INITCAP (string[, nlsparams]): function returns a string to capitalize the first letter of each word and the word of the other letters in lowercase string, nlsparams specifies a different sort of sequence is different from the default value of the session.If you do not specify a parameter, the function and the same INITCAP.Nlsparams can be used is of the form: 'NLS_SORT=sort' sort here made a language sequence. uses position: process and SQL statement.NLS_LOWER syntax: NLS_LOWER (string[, nlsparams]): function returns all the letters in the string are lowercase string.Not alphabetic character.The nlsparams parameter of Nlsparams parameter form and use and NLS_INITCAP are the same burberry femme pas cher.If the nlsparams is not included sweat Ed Hardy Femme, so NLS_LOWER made the same treatment and LOWER. uses position; process and SQL statement.NLS_UPPER syntax: nls_upper (string[, nlsparams]): function returns all the letters in the string are capitalized in the form of string.Not alphabetic character.The nlsparams parameter form and use and NLS_INITCAP in the same.If you do not set the parameters, the NLS_UPPER function and UPPER of the same. uses position: process and SQL statement.REPLACE syntax: REPLACE (string, search_str[, replace_str]) function: put all the string search_str in string with the optional replace_str replacement, if you do not specify a replace_str, string search_str all string will be deleted.REPLACE is a subset of the features provided by TRANSLATE set. uses position: process and SQL statement.Related articles: http://www.v2gether.net/bbs//viewthr...%3D1&frombbs=1 http://bbs.ispace2966.com/thread-2374854-1-1.html http://zgluyou.a105.72ym.cn/forum.ph...ead&tid=526339
