Consum Peugeot 307
    Am fost aseara pe autostrada Bucuresti-Pitesti si am scos un consum de 8.8l cu o viteza de 170km/h, 4 persoane in masina. :evil:
    Oricum cert este ca masina consuma destul cand o calc. Am avut si 190km/h (mai mult nu am incercat din cauza aglomeratiei de pe sosea) si consumul instant era de 10.5l. Inca nu imi dau seama daca masina trece de 200Km/h, pentru ca pedala mai ramane. Are un prag la 190Km/h unde sta constant, dupa care incepe sa traga iar. Trebuie sa fac un test pe autostrada Soarelui sa vad exact daca trece de 190km/h.
      Gogule un diesel tre' sa aiba aceeasi viteza maxima indiferent de cat de incarcata e masina!!!!
      TOYOTA Avensis D-4D 2.0l 116CP
        Acum sa ne intoarcem la consum, am gasit directiva 93/116 dupa care este dat consumul!!
        Cititi si voi, sper ca toata lumea stie engleza!!
        Fuel Consumption Test (Directive 93/116)
        The new test has been agreed internationally and provides results that are more representative of actual average on-road fuel consumption than previous tests. There are two parts: an urban and an extra-urban cycle. The cycle is the same as that used currently to determine the official exhaust emission classification for the model of vehicle in question, see below.
        The cars tested have to be run-in and must have been driven for at least 1,800 miles (3,000 kilometres) before testing.
        Urban cycle
        The urban test cycle is carried out in a laboratory at an ambient temperature of 20oC to 30oC on a rolling road from a cold start, i.e. the engine has not run for several hours. The cycle consists of a series of accelerations, steady speeds, decelerations and idling. Maximum speed is 31 mph (50 km/h), average speed 12 mph (19 km/h) and the distance covered is 2.5 miles (4 km). The cycle is shown as Part One in the diagram below.
        Extra-urban cycle
        This cycle is conducted immediately following the urban cycle and consists of roughly half steady-speed driving and the remainder accelerations, decelerations, and some idling. Maximum speed is 75 mph (120 km/h), average speed is 39 mph (63 km/h) and the distance covered is 4.3 miles (7 km). The cycle is shown as Part Two in the diagram below.
          Primul lucru care merita observat este ca ei fac aceste teste in interior, deci nu au probleme cu vantul din fata, sau din zlte directii, pe deasupra temperatura camerei este destul de ridicata. Chestia ca nu au vant e un plus destul de mare.
            in ceea ce ma priveste, sunt multumit de consum
            am 1700 km in 2 sapt si datele de pe calc de bord sunt dupa cum urmeaza:
            -drum Predeal-Sacele-Cheia-Ploiesti-Bucuresti (cu serpentine si ceva forja pe DN1) consum mediu 4,2l %
            -forja pe Autostrada Soarelui ~3000RPM (130-140km/h) consum mediu si instant 5,5l%
            -test BUcuresti duminica, v medie 25 km/h consum mediu 5,5l%
            recunosc ca am menajat masina, nu am dat mai mult de 2500RPM (decat dupa 1400 KM parcursi) si am schimbat vitezele jos. si bineinteles motorina EURO 4, OMV din considerente de sulf scazut
            sper ca dupa 5000 km consumul sa se imbunatateasca si mai mult
              Azi m-am dat cu pejo 407 2.0l HDi 136CP si surpriza: in treapta a 5-a la 90 km/h are acelasi cunsum instantaneu ca al meu :shock:, iar explicatie nu au avut sa-mi dea, plus ca motorul s-a incalzit in 5 min (ambele pornite la rece), iar la mine se incalzeste in vreo 15 min!!!
                Nu trebuie sa fi surprins ca acel motor are cam acelasi consum instantaneu (ba chiar si media este tot pe acolo) cu al tau pentru ca unele chestii s-au schimbat. Motoorul de 136cp este o evolutie de la motorul de 110cp. Principalul factor care s-a schimbat este ca au schimbat turbina veche cu una cu geometrie variabila de la Garret. De asemenea este vorba de un motor diesel DOHC cu common rail de generatia a doua (de la Siemens) care este in stare sa injecteze motorina la o presiune maxima de 1650bar (fata de ~1400 la cel vechi). Acel DOHC, daca am retinut eu bine este deasemenea facut dintr-un aliaj de metal mai usor decat ce s-a folosit la celelalte motoare.
                Ca sa nu mai vorbim ca masina poseda o cu totul alta transmisie, cu 6 trepte.
                  consum 307 hdi
                  pe un 1.6 hdi 110cp consum mediu in 5000 km de 6,0 dar am rulat mai mult in oras si nu o menajez deloc.in afara daca nu sari de 140km/h consuma putin:intre 4,5 si 5,5
                  307 1.6 hdi 110cp oct &#39;04
                    Eu doar 6.7l/100km am scos in oras si nu imi dau seama cum poti sa scoti mai putin decat scrie in cartea tehnica a masinii. :x Urban - 6.1l. Cumva ai 307 in 3 usii??? :roll:
                    • #25
                      nope! 5 doors! asa imi spune calculatorul doctore!precizez ca 6,0 e consumul mediu!dupa traseul de 900 km de revelion consumul mediu scazuse la 5,8 dar dupa ce am revenit in oras in 2 zile am revenit la 6!si eu care ii injuram ca au consumul de uzina mediu declarat de 5,0!bafta! p.s. schimb de la 2800rpm in sus viteza!
                      • #26
                        Drum Bucuresti - Sugas (CV)
                        Distanta: 440 KM (dus-intors)
                        Conditii: 5 pers in masina, portbagaj plin, schiuri deasupra (cu suport), frig de -12 gr C, serpentine, ceva zapada
                        Viteza: mediu 55km/h, croaziera 100-110km/h, max. 130 kmh
                        Motorina: OMV EUR 4
                        CONSUM: 6% (mediu, indicat la bord)
                        eu sunt multumit de consumul asta, date fiind conditiile speciale de deplasare si faptul ca inca nu am 3000km parcursi in total. In conditii "normale" ia 4,5-5% (sportiv) la drum lung. interesant este faptul ca in oras ia MAI PUTIN (din cauza turelor mici la care o tin). pe drum drept intr-a 5-a la 90kmh constant, consumul instant este de aprox 3,0 %. cred ca asta este si viteza optima pt cei care merg la "consum" (de fapt-nimic nou sub soare)
                        se vede clar ca dimensiunea redusa a motorului (1600 cmc) face consumul comparabil la drum lung (viteze mari, ture "multe") cu cel din oras. media se apropie de 5l% in cele doua regimuri de mers(cam asa scrie si in carte, nu?)
                        eu ma declar multumit. Doamne ajuta(-ne) !
                        • #27
                          Eu am acum un consum mediu de 7.5l /100km. Am ajuns cu el si la 8.1l asta in conditiile in care trafic aglomerat si mers la 30Km/h cu anvelope de vara. Mi-am pus momentan doua gume pe fata de iarna, Fulda. Sa vedem daca scade consumul pentru ca acum nu mai patineaza la pornirea de pe loc la semafor.
                          • #28
                            Doc am vazut ca ai adus in vorba cutia de viteze de la 307 HDi 90 CP, factorul care influenteaza consumul, in rau la aceste motorizari!! La 206 acelasi tip de motor consumul este cu 1-2l mai mic decat la 307 si nu este diferenta decat de 150 kg intre masini!! Sa fie alta cutie pe 206 HDi 90 CP????
                            • #29
                              Originally posted by Hilfiger_80
                              [b]Sa fie alta cutie pe 206 HDi 90 CP????
                              Tot ce-i posibil... opricum 150 kg nu este chiara asa de putin.. .reprezinta vreo ~15% din greutatea masinia pe cand un litru in plus tot cam atat reprezinta la consum... asta dupa un calcul facut dupa un paharel de tarie...
                              • #30
                                Si sa nu uit si de 406 care tot asa consuma mai putin decat 307 si e cu 10 kg mai usor decat 307!!! Oare si asta are alta cutie????
