Accesare BIOS
  • Accesare BIOS
    M-a pus Aghiuta sa imi activez optiunea "Fast Boot" in BIOS si acum nu mai pot intra deloc in BIOS. Degeaba apas in nestire F2, boot-ul e instant dupa care se incarca Windows-ul.
    Am citit pe un forum ca avind tastatura pe USB, nu se initializeaza exact la pornirea calculatorului si atunci degeaba mai apas F2 ca nu mai apuca sa citeasca tastatura. Evident ca placa de baza nu are mufa de PS/2 pt. tastatura.
    Calculatorul e sigilat deci nu pot sa-l desfac sa-i fac un reset CMOS.
    Ce as mai putea sa incerc?
    Peugeot 205 XS 1.4l 80CP
    NAV: DreimGO DG100 PNA
    ICE: Kenwood KDC-F327
    DRL: SMD3528 IP65
    Asta am gasit pe goagle, poate te ajuta. Ciudat ca inca mai sunt calculatoare care au sigiliu pe carcasa (daca e desktop).
    1. All USB devices need to be unplugged, apart from keyboard.
    2. Well as soon as I got my question typed in I figured it out, at least for this Intel motherboard.
    I found another computer with the same motherboard and browsed the BIOS settings. Under Boot/Fast Boot/USB Optimization I found this descriptive text (nowhere in the manual by the way):
    "If Enabled, USB devices (keyboards and drives) will not be available until after OS boot, but BIOS will boot faster. If Disabled, USB devices will be available before OS boot, but BIOS will boot slower. This question does not affect USB capabilities after OS boot. This question cannot be enabled while a User Password or Hard Drive Password is installed. In order to disable Fast Boot without entering BIOS Setup: Power down the system, then hold down the power button until the system beeps."
      Nu are voie sa faca asa ceva nici cu "fast boot".Incearca si cu DEL.
      "Hello honey,i'm home ..."
        @sadcozma: de ce e ciudat sa aiba sigiliu? Toate calculatoarele noi pe care le-am primit au avut sigiliu.
        Am incercat si eu inainte faza cu scosul tastaturii, in ideea sa dea Keyboard Error si sa o bag dupa aceea, dar da numai Warning si merge mai departe.
        LE: "In order to disable Fast Boot without entering BIOS Setup: Power down the system, then hold down the power button until the system beeps." - A FUNCTIONAT!!!!
        Multumesc mult pt. ajutor.
        DRL: SMD3528 IP65
          Eu ultima oara cand am avut sigiliu pe o carcasa de desktop a fost prima oara cand mi-am luat calculator, prin ~2000. Dupa, cu trecerea timpului, avansarea tehnologiei, etc, si-au dat si ei seama ca pot sa iti dea pe componente garantia, nu per pachet, fara sa mai fii restrans de faptul ca nu poti sa iti aerisesti si tu praful din carcasa, sa pui un nou cooler pe carcasa pentru un mai bun flow, etc; acum 10 ani sdram`ul avea garantie cat, 1 an, poate 2, acum au pe viata, de asta mi se pare ciudat ca inca iti pun sigiliul. (plus ca in 2000 era frenezia deschiderii carcasei cu atasarea de alte varii accesorii, etc)
          Asta e alta discutie, mie mi se pare ciudat, atata tot
          Ma bucur ca ti-ai rezolvat problema. Din ce imi aduc aminte, ar trebui sa ai o optiune in bios sa poti sa iti "start-up" si usb`ul tot in perioada de boot bios. Imi scapa acum si sunt la munca, nu pot sa fac probe cu laptopul de munca.
            Primul calculator al meu pe care l-am cumparat a avut sigiliu pe carcasa dar urmatoarele n-au avut.
