Inlocuire senzor presiune diferential FAP!
    am gasit asta pe un forum din Anglia
    I did find some water dripping from the sensor and had already bough a replacement (£42) one so I fitted it, different design but easy to fit.
    previous design code:1618.09: front tube (marked white, also same side of connector), rear tube
    new design code:1618.Z9: left tube, right tube(white rectangle, also same side of connector)
    The connection goes as follows: front and right; rear and left
    If connecting the wrong way round, you'll only get a negative pressure that the ECU will read as low and come with same error being punctured fap, but it never happened I needed the garage to reset it, it wouldn't on its own!
    => racordul din fata marcat cu alb (model vechi) cu cel din dreapta marcat cu un dreptunghi alb(model nou), respectiv racordul din spate(model vechi) cu cel din stanga(model nou)
    MODEL: 307 HDI RC unicat
