Page 1 of 10 12345 ... LastLast
Results 1 to 15 of 148
Thread: peugeot 508 VIN
    Dec 2015
    Floresti, Cluj
    peugeot 508 VIN
    Buna seara,
    sunt de 2 saptamani posesorul unui Peugeot 508 SW 2.0 140 CP.
    Ma poate ajuta cineva cu informatii despre VIN : VF38ERHF8BL025235?
    loplo's Avatar
    Aug 2008
    Sighisoara/Koeln
    650
    Salutari, si bine ai venit printre noi.
    Mai jos ai datele cerute:
    Code:
    Linie de produs	508
    Nr. APV/PR	12560 CJ 1 0555
    Data de Inceput de Garantie	29.06.2011
    NRE	e2*2007/46*0080*00
    Informatii generale
    GENRE DE PRODUIT	VEHICUL PARTICULAR
    MARQUE COMMERCIALE, TYPE ORGANE	PEUGEOT
    LIGNE DE PRODUIT	508
    SILHOUETTE	BREAK 5 USI
    FINITION	INALTIME MEDIE PLUS
    MOTEUR	DIESEL TURBO DW10BTED4 FILTRU DE PARTICULE
    TRANSMISSION	CUTIE DE VITEZE MANUALA6
    TYPE DE PEINTURE	METALIZATA LACUITA
    COULEUR DE CAISSE	KCJ - VOPSEA SIWA
    TYPE D’HABILLAGE INTÉRIEUR	PARTIAL DIN PIELE MARSTON "3F"
    COULEUR DE GARNISSAGE	"FX"
    BOITE DE VITESSES (CARACTÉRISTIQUES)	CUTIE DE VITEZE MANUALA ML6 CL
    MOTEUR (TYPE)	MOTOR TIP EW/DW
    Caracteristici vehicul
    DIRECTION	SISTEM DE DIRECTIE ASISTATA
    Alimentare motor
    DÉTECTEUR D’EAU FILTRE À GAZOLE	FARA SISTEM DE DETECTARE APA IN FILTRUL DE MOTORINA
    CARBURANT	MOTORINA CALITATE DA/DE/DE+
    DÉPOLLUTION (MOTEUR)	DEPOLUARE EURO5 (MOTOR)
    ECHAPPEMENT	TOBA DE ESAPAMENT LONGITUDINALA
    CYLINDRÉE	2000 CM3
    CATALYSEUR	CATALIZATOR IMPREGNAT SUB 10PPM
    REFROIDISSEMENT D’HUILE	SCHIMBATOR PE MOTOR SI CUTIE DE VITEZE
    REZERVOR DE CARBURANT	REZERVOR CARBURANT CU ELEMENT DE INDEXARE
    RÉCHAUFFAGE CIRCUIT GAZ CARTER	SISTEM DE INCALZIRE A CIRCUITULUI DE GAZE DIN CARTER
    AUTODIAGNOSTIC EOBD	SISTEM DE AUTODIAGNOSTICARE "EOBD"
    DISPOSITIF (ANTIPOLLUTION)	RECIRCULARE GAZE DE ESAPAMENT "EGR"
    DÉPOLLUTION TECHNIQUE VÉHICULE	DEPOLUARE TEHNICA VEHICUL EURO5
    FILTRE À PARTICULE	FILTRU DE PARTICULE
    VENTILATEUR	1 VENTILATOR ELECTRONIC CU DOUA TURATII 140W
    VARIANTE ASSOCIÉE INJECTION	SISTEM DE INJECTIE DELPHI
    LANT DE TRACTIUNE HIBRIDA	FARA LANT DE TRACTIUNE HIBRID
    FILTRE RÉSERVOIR	FILTRU REZERVOR INTERIOR
    STOP AND START	FARA SISTEM STOP AND START
    Cutie de viteze - Transmisie
    COUPLE RAPPORT	RAPORT PUNTE 6 X 65
    STYLE ROUE	STIL 05 17 INCI
    EMBRAYAGE	AMBREIAJ HIDRAULIC
    DIFFÉRENTIEL (BOITE)	DIFERENTIAL 86
    JANTE / PNEU DIMENSION	ECHIPARE PNEU 17 INCI
    PNEUMATIQUE (DIMENSIONS, TYPE)	PNEU 215/55 R17 94W NERANFORSAT
    ROUE (TYPE)	MONTARE ROATA ALIAJ 2
    INDICATEUR DE PERTE DE PRESSION DE GONFLAGE	FARA INDICATOR PENTRU PIERDERE PRESIUNE DIN PNEURI
    BOITE DE VITESSES TYPE	ML6C
    Suspensie - directie - Franare
    BARRE ANTIDÉVERS ARRIÈRE	BARA ANTIRULIU SPATE DIAMETRU 20
    ANTIDÉVERS AVANT	BARA ANTIRULIU FATA DIAMETRU 23,5
    SUSPENSION	SUSPENSIE NORMALA
    CONTRÔLE DYNAMIQUE DE STABILITÉ	CU SISTEM ESP
    VARIANTE ASSOCIÉE FREIN	ESP BOSCH 8 1
    DIRECTION (FONCTIONNEMENT)	DIRECTIE ASISTATA ELECTROHIDRAULIC
    Caroserie Echipamente
    ATTACHE-REMORQUE	FARA DISPOZITIV DE REMORCARE
    ENJOLIVEMENT LATÉRAL (ASPECT)	FARA ELEMENTE DE PROTECTIE LATERALE
    ENJOLIVEUR ROUE (STYLE)	FARA CAPAC DE ROATA
    FEU D’ÉCLAIRAGE DE SEUIL	LUMINI DE PRAG FATA
    COMPLÉMENT DE PROTECTION (SOUS MOTEUR)	FARA PROTECTIE SUPLIMENTARA SUB MOTOR
    ANNEAU D’ARRIMAGE EXTÉRIEUR (RAPPORTÉ)	FARA INEL DE ARIMARE EXTERIOARA SUPRAPUS
    FONCTION COMPLÉMENTAIRE RÉTROVISEUR EXTÉRIEUR	RETROVIZOR EXTERIOR RABATABIL ELECTRIC FARA MEMORIE
    ESSUIE-VITRE AVANT	MECANISM STERGERE PARBRIZ CU SENZOR DE PLOAIE
    ESSUIE-VITRE ARRIÈRE	MECANISM DE STERGERE LUNETA
    ESSUIE-PROJECTEUR	MECANISM DE STERGERE PROIECTOR
    OBTURATEUR FACE AVANT	OBTURATOR INFERIOR PANOU FRONTAL
    VITRE PAVILLON	CU GEAM DE PAVILION
    VITRE VOLET ARRIÈRE	GEAM FIX DE CAPAC DE PORTBAGAJ
    PARE-CHOCS	BARA DE PROTECTIE FATA/SPATE STANDARD CULOARE CAROSERIE + GRILA CROMATA
    PARE-BOUE (BAVETTE)	FARA APARATORI DE ROTI SPATE
    PORTE-BAGAGES	MONTARE CU BARE DE ACOPERIS
    PROJECTEUR ANTIBROUILLARD	PROIECTOARE ANTI-CEATA
    ROUE DE SECOURS	ROATA ALIAJ + PNEU STANDARD
    ACCESSOIRES EXTÉRIEURS	MANER EXTERIOR SI CULISA ORNAMENT, CROMATE
    RÉTROVISEUR EXTÉRIEUR (RAYON COTÉ CONDUCTEUR)	OGLINDA BOMBATA LA RETROVIZORUL EXTERIOR
    TOIT OUVRANT	ACOPERIS FIX
    ENJOLIVEMENT PARE-CHOCS	BARA DE PROTECTIE CU INSERTIE CROMATA
    VITRE (ASPECT)	GEAM FUMURIU + FUMURIU INCHIS
    VITRE (TYPE)	PARBRIZ STRATIFICAT CU IZOLARE FONICA + SPATE SECURIZAT
    ACCÈS ET DÉMARRAGE MAINS LIBRES	ACCES SI PORNIRE CU MAINI LIBERE
    Echipament interior
    ALARME ANTIVOL	FARA ALARMA ANTIFURT
    ASSISE ARRIÈRE	BANCHETA SEPARATA RABATABILA
    DETECTION ANGLEMORT	FARA SISTEM DE SUPRAVEGHERE UNGHI MORT
    ACCOUDOIR ASSISE ARRIÈRE	CU COTIERA SPATE
    CEINTURE DE SÉCURITÉ ARRIÈRE	CENTURI DE SIGURANTA SPATE CU 3 RETRACTOARE IN 3 PUNCTE + MARTOR LUMINOS DE CUPLARE
    CLIMAT (TEMPERATURE AMBIANTE)	TARI CU CLIMA RECE
    GRADUATION VITESSES	GRADATIE IN KM/H
    COMMANDE DE VITESSES	COMANDA DE VITEZE LA PODEA
    COTÉ DE CONDUITE (POSTE DE CONDUITE)	VOLAN PE STANGA
    CHAUFFAGE ADDITIONNEL	SISTEM DE INCALZIRE HABITACLU SUPLIMENTAR PROGRAMABIL
    EQUIPEMENT PLANCHE DE BORD	DECORATIUNE CUBIC CU OCHIURI MICI
    FEUX INT. DIVERS	CITITOR HARTA FATA + SPATE CU LED
    GARNISSAGE VOLUME CHARGEMENT	COVORAS DE PORTBAGAJ + PARTI LATERALE DIN MOCHETA
    COMBINÉ (CARACTÉRISTIQUES)	GRADATIE 260 KM/H 160 M/H MATRICE COLOR
    GARNISSAGE DE PORTE	DECOR TESATURA
    HAUT-PARLEUR	4 DIFUZOARE FATA (2 TWEETERE + 2 FATA) + 4 DIFUZOARE SPATE
    COMMANDE D’AUTORADIO	COMANDA SISTEM AUDIO LA DISTANTA STANDARD
    INSONORISATION HABITACLE	ELEMENT DE IZOLARE FONICA TABLIER 4 KG
    ISOLATION (RIDEAU, PARE-SOLEIL LATÉRAL, TOIT OUVRANT)	FARA TRANSPERANT SPATE
    REHAUSSE ASSISE AVANT PASSAGER	DISPOZITIV DE INALTARE PERNA PASAGER REGLARE PARALELA + AVANSARE
    COMMANDE ASSISE AVANT CONDUCTEUR	COMANDA ELECTRICA SCAUN FATA + REGLARE PARTE SUPERIOARA DE PERNA
    COMMANDE ASSISE AVANT PASSAGER	COMANDA ELECTRICA SCAUN PASAGER FATA + REGLARE PARTE SUPERIOARA DE PERNA
    RÉGLAGE ASSISE AVANT CONDUCTEUR	SUPORT LOMBAR CU REGLARE CONDUCATOR
    RÉGLAGE ASSISE AVANT PASSAGER	REGLARE SUPORT LOMBAR PASAGER
    SYSTÈME DE NAVIGATION	CU SISTEM DE NAVIGATIE CU ECRAN COLOR
    LAMPES DE PROJECTEURS	LAMPA CU DESCARCARE
    LÈVE-VITRE ARRIÈRE	MECANISM ACTIONARE ELECTRICA GEAMURI SPATE CU COMANDA SECVENTIALA
    LÈVE-VITRE AVANT PASSAGER	MECANISM DE ACTIONARE GEAM PASAGER FATA CU COMANDA SECVENTIALA
    AFFICHEUR	AFISAJ DEV
    MIROIR DE COURTOISIE	OGLINDA CONDUCATOR + PASAGER ILUMINATA CU CAPAC
    INDICATEUR D’HUILE	RECEPTOR TEMPORIZAT PENTRU NIVEL + TEMPERATURA
    NAPPE CHAUFFANTE	SCAUN CU INCALZIRE
    SAC GONFLABLE LATÉRAL AVANT	AIRBAG LATERAL ZONA TORACE + AIRBAG CORTINA
    ECLAIRAGE BAS HABITACLE	ILUMINAT ZONA PICIOARELOR CONDUCATOR + PASAGERI FATA + SPATE
    PROTECTION PASSAGER ARRIÈRE	CU PROTECTIE PASAGER SPATE
    NEUTRALISATION COUSSIN GONFLABLE	DEZACTIVARE MANUALA AIRBAG
    PROJECTEUR CORRECTEUR ASSIETTE	REGLARE AUTOMATA A PROIECTOARELOR
    PROJECTEUR DIRECTIONNEL	FARA PROIECTOR DIRECTIONAL
    RÉCEPTEUR RADIO	RADIOTELEFON CU AFISAJ DEPLASAT ’RT6’
    RÉFRIGÉRATION	SISTEM DE REFRIGERARE AUTOMATA
    RÉGULATEUR DE VITESSES	SISTEM DE REGULARIZARE SI DE LIMITARE VITEZA
    REHAUSSE ASSISE AVANT CONDUCTEUR	SISTEM DE INALTARE PERNA SCAUN CONDUCATOR CU REGLARE ELECTRICA
    RÉTROVISEUR INTÉRIEUR	RETROVIZOR INTERIOR CROMAT ELECTROCHIMIC CU POZITII ZI-NOAPTE
    RÉGULATION CLIMATISATION / TEMPÉRATURE	SISTEM DE REFRIGERARE AUTOMATA CU PATRU ZONE
    RANGEMENT VOLUME CHARGEMENT	CU PLASA IN PORTBAGAJ
    TUNER-RADIO	TRI TUNER RADIO
    DÉTECTION D’OBSTACLE	SISTEM DE DETECTARE OBSTACOL RADAR FATA SPATE MDP
    STORES LATÉRAUX	TRANSPERANTE LATERALE "RAND 2"
    ADAPTATION GARNITURE	MANER MANETA PIELE + BURDUF DIN MATERIAL PLASTIC
    AMPLI-ÉQUALISEUR	FARA AMPLIFICATOR EGALIZATOR
    FRÉQUENCE RADIO	FRECVENTA RADIO EUROPA OCCIDENTALA
    COMMANDE VERROUILLAGE	BLOCARE PRIN SIMPLA INCHIDERE
    VOLANT	VOLAN IMBRACAT IN PIELE CU 3 BRATE
    SAC GONFLABLE GENOUX CONDUCTEUR	FARA AIRBAG PENTRU GENUNCHI CONDUCATOR
    ECRAN VIDÉO ARRIÈRE	FARA ECRAN VIDEO IN SPATE
    PRIZA AUXILIARA PACK AUDIO	1 PRIZA JACK + USB
    BOITIER TELEMATIQUE	MODUL TELEMATICA AUTONOM
    Electricitate
    ALTERNATEUR	ALTERNATOR CLASA 18
    BATTERIE	L3 720 EF
    DÉMARREUR	DEMAROR CLASA 6+
    ECLAIREMENT PARTICULIER	APRINDERE AUTOMATA + LUMINI DIURNE FATA
    FRÉQUENCE TÉLÉCOMMANDE DE CONDAMNATION	FRECVENTA TELECOMANDA DE BLOCARE 433,92 MHZ HETERODINA
    ALLUMAGE FEUX	APRINDERE AUTOMATA A LUMINILOR + COMUTARE AUTOMATA
    Marci echipamente
    Diverse
    CRITÈRE VARIANCE, CLIENTÈLE CONCEPTION	STANDARD
    ATMOSPHÈRE	ATMOSFERA NORMALA
    ETIQUETTE	FARA ETICHETA
    PRISE D’ÉCOUTE RADIO	PRIZA CVADRUPLA DE ACCESORII
    COTÉ CIRCULATION	CIRCULARE PE DREAPTA
    JEUX DE CLÉS	2 CHEI TELECOMANDA DE INALTA FRECVENTA
    EQUIPEMENT DE SECOURS	FARA ECHIPARE DE REZERVA
    ROULAGE	DRUM CORECT
    BOÎTIER SERVITUDE	BSI EVOLUTION
    TRIANGLE DE PRÉSIGNALISATION	FARA TRIUNGHI REFLECTORIZANT
    407SW 2.0 HDI -> 508SW 2.0 HDI automatic - BL
    Dec 2015
    Floresti, Cluj
    va multumesc pentru promtitudinea raspunsului.
    date despre istoricul masinii de unde pot obtine?
    masina am cumparat-o din Germania.
    am fost la Eurial Cluj si mi-au spus ca ei nu pot accesa istoricul masinii, dar pot sa-mi faca o diagnoza cu testerul.
    am ramas destul de dezamagit referitor la faptul ca Eurialul nu poate accesa istoricul masinii.
    (*&^%$#@!) bobovis's Avatar
    Targoviste
    8,345
    23
    Unu: te-au mintit, daca exista inregistrari pe service in reteaua Peugeot ei le pot accesa; sfat: fiind proprietar ai tot dreptul sa le ceri asta, bate putin mai tare cu pumnul in tejgheaua lor, eventual pomeneste-le subtil de Protectia Consumatorului si vezi ce se intampla.
    Doi: de ce te interesezi acum de istoric si nu ai facut asta inainte de a o cumpara?
    Tigaia
    Dec 2015
    Floresti, Cluj
    Omul de la care am cumparat masina mi-a spus mai multe lucruri despre masina, si am vrut doar sa verific, chiar daca omul a parut a fi sincer.
    nu aveam cum sa verific istoricul inainte de a cumpara masina, asa ca, acum fiind proprietar cu acte in regula am considerat ca as vrea sa stiu mai multe date din trecutul masinii.
    oricum am facut deja 2000 km cu masina si sunt foarte incantat de aceasta (motor, dotari, comportament pe sosea, confort, eleganta, etc.).
    consider ca este o masina buna!
    loplo's Avatar
    Aug 2008
    Sighisoara/Koeln
    650
    daca iei legatura cu vanzatorul si prezinti seriozitate, ai sanse mari ca Neamtul sa iti dea VINul, pentru a verifica masina.
    Mar 2017
    salut..
    Am achizitionat si eu un Peugeot 508 nou. ma poti ajuta si pe mine sa verific vin ce dotari am la el te rog frumos
    VIN : VF38ERHH8EL010673
    - - - Updated - - -
    salut..
    Am achizitionat si eu un Peugeot 508 nou. ma poti ajuta si pe mine sa verific VIN, ce dotari am la el te rog frumos
    Jan 2012
    Cluj-Napoca
    Quote Originally Posted by danyratoiu87 View Post
    salut..
    - - - Updated - - -
    salut..
    Linie de produs 508
    Nr. APV/PR 13624 CJ 1 0351
    Data de Inceput de Garantie 29.01.2015
    NRE e2*2007/46*0080*15
    GEN DE PRODUS VEHICUL PARTICULAR
    MARCA COMERCIALA, TIP SUBANSAMBLU PEUGEOT
    LINIE DE PRODUS 508
    TIP CAROSERIE BREAK 5 USI
    NIVEL DE ECHIPARE INALTA JOASA
    MOTOR DIESEL TURBO DW10CTED4 FILTRU DE PARTICULE
    TRANSMISIE CUTIE DE VITEZE MANUALA6
    TIP DE VOPSEA METALIZATA LACUITA
    CULOAREA CAROSERIEI KTV - VOPSEA NEGRU PERLA NERA
    TIP ECHIPARE INTERIOARA TEATURA SI URZEALA COCHER "3D"
    CULOARE GARNISAJ "FX"
    CUTIE DE VITEZE (CARACTERISTICI) CUTIE DE VITEZE MANUALA ML6 CL
    EVOLUTIE DEFINITIE TEHNICA GAMA VECHE
    MOTOR (TIP) MOTOR TIP EW/DW
    MONOGRAMA COMPLEMENTARA, DIVERSE FARA MONOGRAMA SU
    DIRECTIE SISTEM DE DIRECTIE ASISTATA
    Alimentare motor
    DETECTOR DE APA IN FILTRUL DE MOTORINA FARA SISTEM DE DETECTARE APA IN FILTRUL DE MOTORINA
    DEPOLUARE (MOTOR) DEPOLUARE EURO5 (MOTOR)
    ESAPAMENT TOBA DE ESAPAMENT LONGITUDINALA
    CILINDREE 2000 CM3
    RECIRE ULEI SCHIMBATOR PE MOTOR SI CUTIE DE VITEZE
    INCALZIRE CIRCUIT GAZE CARTER FARA SISTEM DE INCALZIRE CIRCUIT DE GAZE CARTER
    AUTODIAGNOSTICARE EOBD SISTEM DE AUTODIAGNOSTICARE "EOBD"
    DISPOZITIV (ANTIPOLUARE) RECIRCULARE GAZE DE ESAPAMENT "EGR"
    DEPOLUARE TEHNICA VEHICUL DEPOLUARE TEHNICA VEHICUL EURO5
    FILTRU DE PARTICULE FILTRU DE PARTICULE
    VENTILATOR 1 VENTILATOR ELECTRONIC CU DOUA TURATII 140W
    VARIANTA SOCIATA INJECTIE SISTEM DE INJECTIE DELPHI
    FITRU DE REZERVOR FILTRU REZERVOR INTERIOR
    CUPLU RAPORT RAPORT PUNTE 6 X 65
    STIL ROATA (JANTA) STIL 04 17 INCI
    AMBREIAJ AMBREIAJ HIDRAULIC
    DIFERENTIAL (CUTIE) DIFERENTIAL 86
    JANTA / PNEU DIMENSIUNI ECHIPARE PNEU 17 INCI
    PNEURI (DIMENSIUNI, TIP) PNEU 215/55 R17 98W RANFORSAT
    ROATA (TIP) ECHIPARE ROATA CU JANTA DIN ALIAJ 1
    INDICATOR DE PIERDERE A PRESIUNII DE UMFLARE FARA INDICATOR PENTRU PIERDERE PRESIUNE DIN PNEURI
    CUTIE DE VITEZE TIP ML6C
    BARA ANTIRULIU SPATE BARA ANTIRULIU SPATE DIAMETRU 20
    ANTIRULIU FATA BARA ANTIRULIU FATA DIAMETRU 23,5
    SUSPENSIE SUSPENSIE NORMALA
    CONTROL DINAMIC AL STABILITATII CU SISTEM ESCAMOTABIL
    VARIANTA ASOCIATA FRANA ESP BOSCH 8 1
    DIRECTIE (FUNCTIONARE) DIRECTIE ASISTATA ELECTROHIDRAULI
    DISPOZITIV DE REMORCARE FARA DISPOZITIV DE REMORCARE
    ANTENA ANTENA + GPS
    ORNAMENT LATERAL (ASPECT) FARA ELEMENTE DE PROTECTIE LATERALE
    ORNAMENT DE ROATA (STIL) FARA CAPAC DE ROATA
    LUMINA DE PRAG LUMINI DE PRAG FATA
    SUPLIMENT DE PROTECTIE (SUB MOTOR) FARA PROTECTIE SUPLIMENTARA SUB MOTOR
    INEL DE FIXARE EXTERIOR (ADAUGAT) FARA INEL DE ARIMARE EXTERIOARA SUPRAPUS
    FUNCTIE COMPLEMENTARA DE RETROVIZOR EXTERIOR RETROVIZOR EXTERIOR RABATABIL ELECTRIC FARA MEMORIE
    INSONORIZARE PE MOTOR IZOLARE FONICA LA CAPOTA
    STERGATOR PARBRIZ MECANISM STERGERE PARBRIZ CU SENZOR DE PLOAIE
    STERGATOR DE LUNETA MECANISM DE STERGERE LUNETA
    STERGATOR DE PROIECTOR FARA MECANISM DE STERGERE PROIECTOR
    OBTURATOR FATA FATA CU OBTURATOR PE PANOUL FRONTAL AL MODULULUI DE INTRARE AER
    GEAM DE PAVILION CU GEAM DE PAVILION
    LUNETA (GEAM DE CAPAC DE PORTBAGAJ) GEAM FIX DE CAPAC DE PORTBAGAJ
    BARA DE PROTECTIE BARA DE PROTECTIE FATA/SPATE STANDARD CULOARE CAROSERIE + GRILA CROMATA
    APARATOARE DE NOROI (BAVETA) FARA APARATORI DE ROTI SPATE
    PORTBAGAJ MONTARE CU BARE DE ACOPERIS
    PROIECTOR ANTICEATA PROIECTOARE ANTI-CEATA
    ROATA DE REZERVA FARA ROATA DE REZERVA
    ACCESORII EXTERIOARE MANER EXTERIOR IN CULOAREA CAROSERIEI + CULISA ORNAMENT CROMAT
    RETROVIZOR EXTERIOR (RAZA ZONA CONDUCATOR) OGLINDA BOMBATA LA RETROVIZORUL EXTERIOR
    TRAPA DE PLAFON ACOPERIS FIX
    ORNAMENT DE BARA DE PROTECTIE BARA DE PROTECTIE CU INSERTIE CROMATA
    GEAM (ASPECT) GEAM FUMURIU
    GEAM (TIP) PARBRIZ STRATIFICAT CU IZOLARE FONICA + SPATE SECURIZAT
    ACCES SI PORNIRE CU MAINI LIBERE FARA ACCCES SI PORNIRE MAINI LIBERE
    ALARMA ANTIFURT FARA ALARMA ANTIFURT
    SCAUN SPATE BANCHETA SEPARATA RABATABILA
    DETECTARE UNGHI MORT FARA SISTEM DE SUPRAVEGHERE UNGHI MORT
    COTIERA DE SCAUN SPATE CU COTIERA SPATE
    CENTURA DE SIGURANTA SPATE CENTURI DE SIGURANTA SPATE CU 3 RETRACTOARE IN 3 PUNCTE + MARTOR LUMINOS DE CUPLARE
    CENTURA DE SIGURANTA FATA CENTURA DE SIGURANTA PIROTEHNICA DUBLA CU ALARMA
    CLIMA (TEMPERATURA AMBIANTA) TARI CU CLIMA RECE
    GRADARE VITEZE GRADATIE IN KM/H
    COMANDA DE VITEZE COMANDA DE VITEZE LA PODEA
    PARTE CONDUCERE (POST DE CONDUCERE) VOLAN PE STANGA
    INCALZIRE ADITIONALA FARA SISTEM DE INCALZIRE SUPLIMENTAR
    ECHIPAMENT PLANSA DE BORD DECORATIUNE SATIN ARGINTAT
    LUMINI INTERIOARE DIVERSE LAMPA DE CITIT HARTA FATA + SPATE + LED FATA
    GARNISAJ SPATIU DE INCARCARE COVORAS DE PORTBAGAJ + PARTI LATERALE DIN MOCHETA
    TABLOU DE BORD (CARACTERISTICI) MAX: 260 KM/H-160 M/H, MAT BLANCH
    CAPITONAJ DE USA DECOR TESATURA
    DIFUZOR 4 DIFUZOARE FATA (2 TWEETERE + 2 FATA) + 4 DIFUZOARE SPATE
    COMANDA DE SISTEM AUDIO COMANDA SISTEM AUDIO LA DISTANTA STANDARD
    IZOLATIE (TRANSPERANT, PARASOLAR LATERAL, TRAPA DE PLAFON) FARA TRANSPERANT SPATE
    INALTARE SCAUN DE PASAGER FATA SISTEM INALTARE PERNA SCAUN PASAGER REGLAJ INAINTE
    COMANDA DE SCAUN FATA DE CONDUCATOR COMANDA MANUALA SCAUN CONDUCATOR
    COMANDA DE SCAUN FATA DE PASAGER COMANDA MANUALA SCAUN PASAGER FATA
    REGLARE PERNA DE SEZUT FATA CONDUCATOR SUPORT LOMBAR CU REGLARE CONDUCATOR
    REGLARE SCAUN FATA DE PASAGER SPATAR SCAUN PASAGER CARE SE POATE INCLINA
    SISTEM DE NAVIGATIE CU SISTEM DE NAVIGATIE CU ECRAN COLOR
    BECURI DE PROIECTOR LAMPA CU HALOGEN
    ACTIONARE GEAM SPATE MECANISM ACTIONARE ELECTRICA GEAMURI SPATE CU COMANDA SECVENTIALA
    ACTIONARE GEAM FATA PASAGER MECANISM DE ACTIONARE GEAM PASAGER FATA CU COMANDA SECVENTIALA
    AFISAJ AFISAJ DEV
    OGLINDA DE PARASOLAR OGLINDA CONDUCATOR + PASAGER ILUMINATA CU CAPAC
    INDICATOR DE ULEI RECEPTOR TEMPORIZAT PENTRU NIVEL + TEMPERATURA
    FOLIE INCALZIRE SCAUN SCAUN CU INCALZIRE
    AIRBAG LATERAL FATA AIRBAG LATERAL ZONA TORACE + AIRBAG CORTINA
    ILUMINAT JOS HABITACLU FARA ILUMINAT INFERIOR DE HABITACLU
    PROTECTIE PASAGER SPATE FARA ELEMET DE PROTECTIE PASAGER SPATE
    NEUTRALIZARE AIRBAG DEZACTIVARE MANUALA AIRBAG
    PROIECTOR CORECTIE VERTICALA REGLARE MANUALA DE LA DISTANTA A PROIECTOARELOR
    PROIECTOR DIRECTIONAL FARA PROIECTOR DIRECTIONAL
    RECEPTOR RADIO RADIOTELEFON CU AFISAJ DEPLASAT ’RT6’
    REFRIGERARE SISTEM DE REFRIGERARE AUTOMATA
    REGULATOR DE VITEZA SISTEM DE REGULARIZARE SI DE LIMITARE VITEZA
    INALTARE SCAUN FATA DE CONDUCATOR SISTEM DE INALTARE PERNA CONDUCATOR REGLARE MANUALA
    RETROVIZOR INTERIOR RETROVIZOR INTERIOR CROMAT ELECTROCHIMIC CU POZITII ZI-NOAPTE
    REGULATOR CLIMATIZARE / TEMPERATURA SISTEM DE REFRIGERARE AUTOMATA CU DOUA ZONE
    COVORAS DE PODEA (ASPECT) FARA COVORAS SUPLIMENTAR
    DEPOZITARE VOLUM DE INCARCARE CU PLASA IN PORTBAGAJ
    DETECTAREA OBSTACOLULUI SISTEM DE DETECTARE OBSTACOLE CU RADAR FATA SPATE
    STORURI LATERALE FARA TRANSPERANTE LATERALE
    ADAPTARE GARNITURA MANER MANETA PIELE + BURDUF DIN MATERIAL PLASTIC
    AMPLIFICATOR-EGALIZATOR FARA AMPLIFICATOR EGALIZATOR
    FRECVENTA RADIO FRECVENTA RADIO EUROPA OCCIDENTALA
    COMANDA DE BLOCARE BLOCARE PRIN SIMPLA INCHIDERE
    AIRBAG DE GENUNCHI CONDUCATOR FARA AIRBAG PENTRU GENUNCHI CONDUCATOR
    ECRAN VIDEO SPATE FARA ECRAN VIDEO IN SPATE
    MODUL TELEMATIC MODUL TELEMATICA AUTONOM
    ALTERNATOR ALTERNATOR CLASA 18
    BATERIE L3 720 EF
    DEMAROR DEMAROR CLASA 6+
    ILUMINAT DEOSEBIT APRINDERE AUTOMATA + LUMINI DIURNE FATA
    FRECVENTA TELECOMANDA BLOCARE DESCHIDERI FRECVENTA TELECOMANDA DE BLOCARE 433,92 MHZ HETERODINA
    APRINDERE LUMINI EXTERIOARE APRINDERE LUMINI MANUALA
    CRITERIU FACTORI, CLIENTELA CONCEPTIE BUSINESS LINE
    ATMOSFERA ATMOSFERA NORMALA
    ETICHETA FARA ETICHETA
    CONECTOR DE ASCULTARE SISTEM AUDIO PRIZA CVADRUPLA DE ACCESORII
    PARTEA DE CIRCULATIE CIRCULARE PE DREAPTA
    SET DE CHEI 1 CHEIE TELECOMANDA INALTA FRECVENTA + 1 CHEIE PRINCIPALA UNICA
    ECHIPAMENT DE PRIM AJUTOR KIT REPARARE PROVIZORIE PNEU
    RULARE DRUM CORECT
    MODUL ELECTRONIC (BOÎTIER SERVITUDE) BSI EVOLUTION
    TRIUNGHI DE PRESEMNALIZARE FARA TRIUNGHI REFLECTORIZANT
    Mar 2017
    Multumesc frumos de raspuns.
    Sep 2016
    medgidia
    54
    Imi dati si mie ceva informati va rog? VIN:VF38DRHC8CL031340.
    Jan 2012
    Cluj-Napoca
    Quote Originally Posted by dumi_adj2009 View Post
    Linie de produs 508
    Nr. APV/PR 12912 CJ 1 0273
    Data de Inceput de Garantie 20.06.2012
    NRE e2*2007/46*0080*06
    Informatii generale
    LINIE DE PRODUS 508
    TIP CAROSERIE BERLINA 4 USI
    NIVEL DE ECHIPARE INALTIME MEDIE PLUS
    TRANSMISIE CUTIE DE VITEZE MANUALA PILOTATA 6 TREPTE HIBRIDA
    CULOAREA CAROSERIEI KTH - VOPSEA GRI THORIUM
    TIP ECHIPARE INTERIOARA PIELE CLAUDIA "Q1"
    CULOARE GARNISAJ "FD"
    CUTIE DE VITEZE (CARACTERISTICI) CUTIE DE VITEZE MANUALA MC6F
    MONOGRAMA COMPLEMENTARA, DIVERSE HIBRID 4
    Alimentare motor
    CILINDREE 2000 CM3
    CATALIZATOR CATALIZATOR IMPREGNAT SUB 10PPM
    LANT DE TRACTIUNE HIBRIDA LANT DE TRACTIUNE HIBRID
    STOP AND START CU STOP AND START
    CUPLU RAPORT RAPORT PUNTE 17 X 74
    STIL ROATA (JANTA) STIL 05 17 INCI
    AMBREIAJ FARA AMBREIAJ
    PNEURI (DIMENSIUNI, TIP) PNEU 215/55 R17 94W NERANFORSAT
    ROATA (TIP) MONTARE ROATA ALIAJ 2
    CUTIE DE VITEZE TIP CUTIE DE VITEZE MANUALA MC
    CONTROL DINAMIC AL STABILITATII CU SISTEM ESP
    DIRECTIE (FUNCTIONARE) DIRECTIE ASISTATA ELECTROHIDRAULIC
    STERGATOR DE LUNETA FARA MECANISM DE STERGERE LUNETA
    STERGATOR DE PROIECTOR MECANISM DE STERGERE PROIECTOR
    GEAM DE PAVILION FARA ELEMENT VITRAT DE PAVILION
    PORTBAGAJ MONTARE FARA USA SUPORT DE BAGAJE
    ACCESORII EXTERIOARE MANER EXTERIOR SI CULISA ORNAMENT, CROMATE
    ACCES SI PORNIRE CU MAINI LIBERE ACCES SI PORNIRE CU MAINI LIBERE
    Echipament interior
    CLIMA (TEMPERATURA AMBIANTA) TARI CU CLIMA TEMPERATA
    ECHIPAMENT PLANSA DE BORD DECORATIUNE IMITATIE LEMN
    LUMINI INTERIOARE DIVERSE CITITOR HARTA FATA + SPATE CU LED
    TABLOU DE BORD (CARACTERISTICI) GRADATIE 260 KM/H 160 M/H MATRICE COLOR
    CAPITONAJ DE USA DECORATIUNE TEP
    DIFUZOR 4 DIFUZOARE FATA (2 TWEETERE + 2 DIFUZOARE) + 5 DIFUZOARE SPATE (2 TWEETERE + 2 DIFUZOARE + 1 SUBWOOFER)
    INSONORIZARE HABITACLU ELEMENT DE IZOLARE FONICA TABLIER 4 KG
    IZOLATIE (TRANSPERANT, PARASOLAR LATERAL, TRAPA DE PLAFON) TRANSPERANT MANUAL SPATE
    INALTARE SCAUN DE PASAGER FATA DISPOZITIV DE INALTARE PERNA PASAGER REGLARE PARALELA + AVANSARE
    COMANDA DE SCAUN FATA DE CONDUCATOR COMANDA ELECTRICA SCAUN CONDUCATOR
    COMANDA DE SCAUN FATA DE PASAGER COMANDA ELECTRICA SCAUN PASAGER FATA
    REGLARE SCAUN FATA DE PASAGER REGLARE SUPORT LOMBAR PASAGER
    BECURI DE PROIECTOR LAMPA CU DESCARCARE
    AFISAJ AFISAJ DEV
    ILUMINAT JOS HABITACLU ILUMINAT ZONA PICIOARELOR CONDUCATOR + PASAGERI FATA + SPATE
    PROIECTOR CORECTIE VERTICALA REGLARE AUTOMATA A PROIECTOARELOR
    INALTARE SCAUN FATA DE CONDUCATOR SISTEM DE INALTARE PERNA SCAUN CONDUCATOR CU REGLARE ELECTRICA
    REGULATOR CLIMATIZARE / TEMPERATURA SISTEM DE REFRIGERARE AUTOMATA CU PATRU ZONE
    DEPOZITARE VOLUM DE INCARCARE FARA PLASA IN PORTBAGAJ
    DETECTAREA OBSTACOLULUI SISTEM DE DETECTARE OBSTACOL RADAR FATA SPATE MDP
    STORURI LATERALE TRANSPERANTE LATERALE "RAND 2"
    ADAPTARE GARNITURA MANER MANETA DE VITEZE DIN PIELE CU INSERTIE CROMATA
    AMPLIFICATOR-EGALIZATOR CU AMPLIFICATOR EGALIZATOR
    Electricitate
    ALTERNATOR ISTT6
    BATERIE L3 800
    DEMAROR DEMAROR CLASA 5
    APRINDERE LUMINI EXTERIOARE APRINDERE AUTOMATA A LUMINILOR + COMUTARE AUTOMATA
    Marci echipamente
    Diverse
    CRITERIU FACTORI, CLIENTELA CONCEPTIE STANDARD
    CONECTOR DE ASCULTARE SISTEM AUDIO PRIZA ACCESORII TRIPLA
    SET DE CHEI 2 CHEI TELECOMANDA DE INALTA FRECVENTA
    RULARE DRUM CORECT
    Ionut159's Avatar
    1,737
    Ati dezgropat un thread vechi de 2 ani si nu isi are rostul. Exista thread pentru decodarea vin-ului pentru toate modelele. Nu e necesar sa continuam aici separat doar pt 508.
    Sep 2016
    medgidia
    54
    Multumesc "calinutz". "ionut159" poate ai dreptate, dar cei care nu stiu apeleaza aici👍.
    giorgio_24's Avatar
    Dec 2010
    Hoinar:P!!!
    1,848
    O chestie ciudata insa🤔zice ca e noua,insa garantia pleaca in 2015 si noi suntem in 2017...sau ma insel🙄
    Inviato da mTalk
    giorgio_24's Avatar
    Dec 2010
    Hoinar:P!!!
    1,848
    Ma refeream la nenea @ratzoiu87😏 cu al lui 508 nou
    Inviato da mTalk
