Page 25 of 28 FirstFirst ... 152122232425262728 LastLast
Results 361 to 375 of 412
Thread: Salutari de la membri noi
  1. #361
    Apr 2016
    Tg Mures
    Buna, sunt si eu posesor de 407 de putina vreme, si destul de nou si pe forum. Mi-ar fi de mare folos ajutorul lui "norishor", daca nu este deranjul prea mare, cu datele despre masina mea: VF36ERHRH21148293 Mulțumesc.
  2. #362
    Apr 2016
    Tg Mures
    Multumesc anticipat
  3. #363
    norishor's Avatar
    Nov 2010
    Bucuresti / Campina (uneori in weekend))
    198
    Quote Originally Posted by adimia94 View Post
    Caracteristicile vehiculului
    Linie de produs 407
    Nr. APV/PR 10237 CJ 2 0653
    Data de Inceput de Garantie 31.08.2005
    NRE e2*2001/116*0297*03
    Informatii generale
    GENRE DE PRODUIT VEHICUL PARTICULAR
    MARQUE COMMERCIALE, TYPE ORGANE PEUGEOT
    LIGNE DE PRODUIT 407
    SILHOUETTE BREAK 5 USI
    FINITION AA
    MOTEUR DIESEL TURBO DW10BTED4 FILTRU DE PARTICULE
    TRANSMISSION CUTIE DE VITEZE MANUALA6
    TYPE DE PEINTURE VOPSEA METALIZATA LACUITA
    COULEUR DE CAISSE EZR - VOPSEA GRI ALUMINIU
    TYPE D’HABILLAGE INTÉRIEUR IMPLETITURA ANDORRA + TESATURA SOFIS "RR"
    COULEUR DE GARNISSAGE "FT"
    BOITE DE VITESSES (CARACTÉRISTIQUES) CUTIE DE VITEZE MANUALA ML6 CL
    MOTEUR (TYPE) MOTOR TIP EW/DW
    Caracteristici vehicul
    FINITION AA
    DIRECTION MECANISM DE DIRECTIE ASISTATA CARE NU ESTE VARIABILA
    Alimentare motor
    DÉTECTEUR D’EAU FILTRE À GAZOLE FARA SISTEM DE DETECTARE APA IN FILTRUL DE MOTORINA
    CARBURANT MOTORINA
    DÉPOLLUTION (MOTEUR) DEPOLUARE EURO 4 (MOTOR)
    REFROIDISSEMENT D’HUILE SCHIMBATOR APA/ULEI MOTOR
    RÉCHAUFFAGE CIRCUIT GAZ CARTER FARA SISTEM DE INCALZIRE CIRCUIT DE GAZE CARTER
    VARIATION PUISSANCE (MOTEUR) PUTERE STANDARD
    AUTODIAGNOSTIC EOBD SISTEM DE AUTODIAGNOSTICARE "EOBD"
    DISPOSITIF (ANTIPOLLUTION) RECIRCULARE GAZE DE ESAPAMENT "EGR"
    DÉPOLLUTION TECHNIQUE VÉHICULE DEPOLUARE TEHNICA VEHICUL EURO4
    FILTRE À PARTICULE FILTRU DE PARTICULE
    VENTILATEUR 1 VENTILATOR ELECTRONIC CU COMANDA INTEGRATA 150W
    VARIANTE ASSOCIÉE INJECTION SISTEM INJECTIE SIEMENS
    FILTRE RÉSERVOIR FARA FILTRU REZERVOR
    BOÎTIER PAPILLON (ADMISSION AIR MOTEUR) MODUL CLAPETA MOTORIZATA (ADMISIE AER MOTOR)
    Cutie de viteze - Transmisie
    COUPLE RAPPORT RAPORT PUNTE 17 X 71
    STYLE ROUE ROATA COSMOS 17 INCI
    EMBRAYAGE AMBREIAJ HIDRAULIC
    DIFFÉRENTIEL (BOITE) DIFERENTIAL 86
    JANTE / PNEU DIMENSION ECHIPARE PNEU 17 INCI
    PNEUMATIQUE (DIMENSIONS, TYPE) PNEU 215/55 R17 94W NERANFORSAT
    ROUE (TYPE) MONTARE ROATA ALIAJ 3
    INDICATEUR DE PERTE DE PRESSION DE GONFLAGE FARA INDICATOR PENTRU PIERDERE PRESIUNE DIN PNEURI
    BOITE DE VITESSES TYPE ML6C
    Suspensie - directie - Franare
    COLONNE DIRECTION COLOANA DE DIRECTIE CU REGLARE MANUALA
    ANTIDÉVERS AVANT BARA ANTIRULIU FATA DIAMETRU 24,5
    COURSE MÉCANISME DE DIRECTION CURSA MECANISM DE DIRECTIE 174
    SUSPENSION SUSPENSIE NORMALA
    SUSPENSION ACTIVE FARA SUSPENSIE VARIABILA
    CONTRÔLE DYNAMIQUE DE STABILITÉ CU SISTEM ESP
    DIRECTION (FONCTIONNEMENT) DIRECTIE ASISTATA ELECTROHIDRAULIC
    Caroserie Echipamente
    ATTACHE-REMORQUE FARA DISPOZITIV DE REMORCARE
    ENJOLIVEMENT LATÉRAL (ASPECT) ELEMENTE PROTECTIE LATERALA VOPSITE IN MASA + CROMATE
    ENJOLIVEMENT LATÉRAL (DIMENSION) ELEMENTE DE PROTECTIE LATERALE + TREAPTA
    ENJOLIVEUR ROUE (STYLE) FARA CAPAC DE ROATA
    FEU D’ÉCLAIRAGE DE SEUIL LUMINA PENTRU PRAG
    COMPLÉMENT DE PROTECTION (SOUS MOTEUR) FARA PROTECTIE SUPLIMENTARA SUB MOTOR
    FONCTION COMPLÉMENTAIRE RÉTROVISEUR EXTÉRIEUR RETROVIZOR EXTERIOR RABATABIL ELECTRIC FARA MEMORIE
    ESSUIE-VITRE AVANT MECANISM STERGERE PARBRIZ CU SENZOR DE PLOAIE
    ESSUIE-VITRE ARRIÈRE MECANISM DE STERGERE LUNETA
    ESSUIE-PROJECTEUR FARA MECANISM DE STERGERE PROIECTOR
    OBTURATEUR FACE AVANT FARA OBTURATOR PARTE FRONTALA FATA
    VITRE PAVILLON CU GEAM DE PAVILION
    ROUE DE SECOURS ROATA JANTA TABLA + PNEU STANDARD
    ACCESSOIRES EXTÉRIEURS MANERE EXTERIOARE + RETROVIZOARE EXTERIOARE CULOARE CAROSERIE
    TOIT OUVRANT ACOPERIS FIX
    ENJOLIVEMENT PARE-CHOCS BANDOU DE BARA DE PROTECTIE COLORAT IN MASA + ORNAMENT INOX
    VITRE (ASPECT) GEAM COLORAT TRANSPARENT
    VITRE (TYPE) PARBRIZ STRATIFICAT + GEAMURI LATERALE SI SPATE SECURIZATE
    ACCÈS ET DÉMARRAGE MAINS LIBRES FARA ACCCES SI PORNIRE MAINI LIBERE
    Echipament interior
    ALARME ANTIVOL FARA ALARMA ANTIFURT
    ACCOUDOIR ASSISE ARRIÈRE CU COTIERA SPATE
    CEINTURE DE SÉCURITÉ ARRIÈRE CENTURI DE SIGURANTA PIROTEHNICE LATERAL SPATE CU RETRACTOR + CENTURA IN 3 PUNCTE
    CLIMAT (TEMPERATURE AMBIANTE) TARI CU CLIMA RECE
    CONDAMNATION ENFANT SIGURANTA COPIL MANUALA USA SPATE
    GRADUATION VITESSES GRADATIE IN KM/H
    COTÉ DE CONDUITE (POSTE DE CONDUITE) VOLAN PE STANGA
    CHAUFFAGE ADDITIONNEL FARA SISTEM DE INCALZIRE SUPLIMENTAR
    EQUIPEMENT PLANCHE DE BORD PLANSA DE BORD STANDARD + FATADA ALUMINIU ARGINT VIU
    COMBINÉ (CARACTÉRISTIQUES) GRADATIE 260 KM/H 160 M/H FUNDAL TRANSPARENT
    GARNISSAGE DE PORTE DECORATIUNE GEOMETRICA
    HAUT-PARLEUR 4 DIFUZOARE FATA (2 TWEETERE + 2 FATA) + 2 DIFUZOARE SPATE
    COMMANDE D’AUTORADIO COMANDA SISTEM AUDIO LA DISTANTA
    ISOLATION (RIDEAU, PARE-SOLEIL LATÉRAL, TOIT OUVRANT) FARA TRANSPERANTE SPATE
    REHAUSSE ASSISE AVANT PASSAGER SISTEM INALTARE PERNA SCAUN PASAGER REGLAJ INAINTE
    COMMANDE ASSISE AVANT CONDUCTEUR COMANDA MANUALA SCAUN CONDUCATOR
    COMMANDE ASSISE AVANT PASSAGER COMANDA MANUALA SCAUN PASAGER FATA
    RÉGLAGE ASSISE AVANT PASSAGER REGLARE MODULARA PERNA DE SEZUT PASAGER FATA
    COMPACT DISQUE FARA MONTARE COMPACT DISC
    SYSTÈME DE NAVIGATION FARA SISTEM DE NAVIGARE
    LAMPES DE PROJECTEURS LAMPA CU HALOGEN
    LÈVE-VITRE ARRIÈRE MECANISM DE ACTIONARE ELECTRICA GEAM SPATE CU COMANDA SECVENTIALA + BLOCARE
    AFFICHEUR AFISAJ (RADIO + CEAS + SI SAU T°,CD)
    MIROIR DE COURTOISIE OGLINDA CONDUCATOR + PASAGER ILUMINATA CU CAPAC
    INDICATEUR D’HUILE SENZOR CU FUNCTIE DUBLA NIVEL + TEMPERATURA ULEI
    NAPPE CHAUFFANTE SCAUN FARA INCALZIRE
    SAC GONFLABLE LATÉRAL AVANT AIRBAG LATERAL ZONA TORACE FATA + SPATE + AIRBAG CORTINA
    ECLAIRAGE BAS HABITACLE FARA ILUMINAT INFERIOR DE HABITACLU
    NEUTRALISATION COUSSIN GONFLABLE DEZACTIVARE MANUALA AIRBAG
    PROJECTEUR CORRECTEUR ASSIETTE REGLARE MANUALA DE LA DISTANTA A PROIECTOARELOR
    PROJECTEUR DIRECTIONNEL FARA PROIECTOR DIRECTIONAL
    RÉCEPTEUR RADIO SISTEM AUDIO COMPACT DISC RDS "RD4"
    RÉFRIGÉRATION SISTEM DE REFRIGERARE AUTOMATA
    RÉGULATEUR DE VITESSES FARA SISTEM DE REGULARIZARE VITEZA
    REHAUSSE ASSISE AVANT CONDUCTEUR SISTEM DE INALTARE PERNA CONDUCATOR REGLARE MANUALA
    RÉTROVISEUR INTÉRIEUR RETROVIZOR INTERIOR CU REGLARE PENTRU ZI - NOAPTE CU OGLINDA CARE NU ESTE CROMATA ELECTROCHIMIC
    RÉGULATION CLIMATISATION / TEMPÉRATURE SISTEM DE REFRIGERARE AUTOMATA CU DOUA ZONE
    TUNER-RADIO TUNER DUBLU RADIO
    PROTECTION INTÉRIEURE FARA PROTECTIE INTERIOARA
    DÉTECTION D’OBSTACLE FARA SISTEM DE DETECTARE OBSTACOLE
    STORES LATÉRAUX TRANSPERANTE LATERALE "RAND 2"
    ADAPTATION GARNITURE MANER MANETA DE VITEZE PIELE
    AMPLI-ÉQUALISEUR FARA AMPLIFICATOR EGALIZATOR
    FRÉQUENCE RADIO FRECVENTA RADIO EUROPA OCCIDENTALA
    COMMANDE VERROUILLAGE BLOCARE PRIN SIMPLA INCHIDERE
    VOLANT VOLAN IMBRACAT IN PIELE CU 3 BRATE
    SAC GONFLABLE GENOUX CONDUCTEUR AIRBAG ZONA GENUNCHI CONDUCATOR
    Electricitate
    ALTERNATEUR ALTERNATOR CLASA 18
    BATTERIE BATERIE L3 450
    DÉMARREUR DEMAROR CLASA 6+
    ECLAIREMENT PARTICULIER APRINDERE AUTOMATA A LUMINILOR
    Marci echipamente
    Diverse
    CRITÈRE VARIANCE, CLIENTÈLE CONCEPTION STANDARD
    ATMOSPHÈRE ATMOSFERA NORMALA
    ROULAGE DRUM CORECT
    Cu placere!
    Diagnoza PSA Tester ORIGINAL ->o722.222.577<- Reparatii chei telecomanda PSA
  4. #364
    Apr 2016
    Tg Mures
    Multumesc mult norishor.
  5. #365
    norishor's Avatar
    Nov 2010
    198
    Pt. putin!
  6. #366
    May 2016
    Tg Mures
    Salut de membru nou
    Salutari.Sunt Zsolt si detin un Peugeot 508 SW 2.0 HDI 163 CP Allure.
    Bine v-am gasit!
  7. #367
    alex82's Avatar
    Apr 2009
    1,663
    Bine ai venit ! ...
  8. #368
    May 2016
    Giurgiu
    salut,sunt nou pe aici,detin un 307 1.6hdi 110cp
  9. #369
    Apr 2016
    salut
    salut, sunt Alex , posesor 206 an 200 , 1.4 benzina, nu bate,nu troncane ))
  10. #370
    Vizitator Toc raul's Avatar
    Jun 2016
    CLUJ-NAPOCA
    salutare.ma ajuta si pe mine cineva cu niste infomatii?multumesc
  11. #371
    Jul 2016
    Salutare
    De saptamana viitoare voi deveni si eu posesor de Peugeot, astept un 308 nou noutz automat cu motor 1,2 benzina, turbo de 130 cai.
    Mai are cineva, ca sa sharuie primele impresii, ce are bun so rau, sfaturi de exploatarez etc???
    Mentionez ca e prima data cand am (voi avea defapt, caci nu a sosit inca) masina frantuzeasca, toate experientele mele anterioare fiind "nemtesti"
    Nicu
  12. #372
    Jul 2016
    targoviste
    Salutare, posesor de peugeot 307 2.0 hdi 2002 de 4 zile, sper sa pot ajuta cu orice informatie.Initial mi-am facut cont sa aflu detalii despre usa blocata fata stanga , intre timp am rezolvat-o, o sa deschid un topic nou cu solutia, poate ajuta pe careva, tinand cont ca este problema comuna la 307.
  13. #373
    Jul 2016
    Salut ,am si eu 2 leuti in familie 206 1,4 hdi sotia si eu 407 1,8 benzina 116 cp .Acesta din urma il am de 7 zile ,pe care am montat instalatie gpl.
  14. #374
    Feb 2015
    Focsani
    Salutare tuturor posesorilor de Peugeot . Ma numesc Radu si am un Peugeot 206 din 2001 motor de 1.2 putin modificat ca de acum incepe distractia si sper sa reusesc mai multe cu ajutorul vostru . O zi faina tuturor.
  15. #375
    Vizitator monitor77's Avatar
    Aug 2016
    Fagaras
    Salutari !
    Buna ziua si bine v-am gasit !
    Ma numesc Gabriel, sunt din judetul Brasov si de doua saptamani sunt posesorul unui frumos 407 din 2007, motorizare 1,6 HDi.
    Ca la orice masina SH, vrand-nevrand, ne lovim de unele necunoscute. Am intrat aici pentru a ma documenta si pentru a cunoaste posesori de astfel de masini, din zona mea si de ce nu, din toata tara.
    Pana acum am urmatoarele probleme:
    - nu se incuie si descuie mecanic (cu nici una din cele doua chei)
    - am luat masina cu al doilea rand de roti, de aliaj R17 si nu sunt trecute in carte. Cei de la reprezentanta au zis ca nu sunt acceptate pe acest model. Daca le vrea cineva sunt dispus sa le schimb cu unele pe 16.
    Acestea fiind spuse va doresc o zi buna si va multumesc anticipat !
