Page 79 of 79 FirstFirst ... 29697576777879
Results 1,171 to 1,173 of 1173
Thread: VIN (Vehicle Identification Number) - Informatii utile
  1. #1171
    Join Date
    Mar 2019
    Location
    Craiova
    Posts
    2
    Rep Power
    0
    Ma poate ajuta cineva cu VF38DRHC8CL038548? Multumesc mult
  2. #1172
    Join Date
    Sep 2019
    Location
    Bucuresti
    Posts
    14
    Rep Power
    0
    Informatii generale
    GEN DE PRODUS VEHICUL PARTICULAR
    MARCA COMERCIALA, TIP SUBANSAMBLU PEUGEOT
    LINIE DE PRODUS 508
    TIP CAROSERIE BERLINA 4 USI
    NIVEL DE ECHIPARE INALTIME MEDIE PLUS
    MOTOR DIESEL TURBO DW10CTED4 FILTRU DE PARTICULE
    TRANSMISIE CUTIE DE VITEZE MANUALA PILOTATA 6 TREPTE HIBRIDA
    TIP DE VOPSEA METALIZATA LACUITA
    CULOAREA CAROSERIEI KDM - VOPSEA CAFENIU INCHIS GUARANJA
    TIP ECHIPARE INTERIOARA PARTIAL DIN PIELE MARSTON "3F"
    CULOARE GARNISAJ "FX"
    CUTIE DE VITEZE (CARACTERISTICI) CUTIE DE VITEZE MANUALA MC6F
    EVOLUTIE DEFINITIE TEHNICA GAMA INITIALA
    MOTOR (TIP) MOTOR TIP EW/DW
    MONOGRAMA COMPLEMENTARA, DIVERSE HIBRID 4
    DETECTOR DE APA IN FILTRUL DE MOTORINA FARA SISTEM DE DETECTARE APA IN FILTRUL DE MOTORINA
    CARBURANT MOTORINA CALITATE DA/DE/DE+
    DEPOLUARE (MOTOR) DEPOLUARE MOTOR SUPERIOARA L6 EURO 5
    ESAPAMENT TOBA DE ESAPAMENT LONGITUDINALA
    CILINDREE 2000 CM3
    CATALIZATOR CATALIZATOR IMPREGNAT SUB 10PPM
    RECIRE ULEI SCHIMBATOR PE MOTOR SI CUTIE DE VITEZE
    REZERVOR DE CARBURANT REZERVOR CARBURANT CU ELEMENT DE INDEXARE
    INCALZIRE CIRCUIT GAZE CARTER FARA SISTEM DE INCALZIRE CIRCUIT DE GAZE CARTER
    AUTODIAGNOSTICARE EOBD SISTEM DE AUTODIAGNOSTICARE "EOBD"
    DISPOZITIV (ANTIPOLUARE) RECIRCULARE GAZE DE ESAPAMENT "EGR"
    DEPOLUARE TEHNICA VEHICUL DEPOLUARE TEHNICA VEHICUL EURO5
    FILTRU DE PARTICULE CU FILTRU DE PARTICULE
    VENTILATOR 1 VENTILATOR ELECTRONIC CU DOUA TURATII 140W
    VARIANTA SOCIATA INJECTIE SISTEM DE INJECTIE DELPHI
    LANT DE TRACTIUNE LANT DE TRACTIUNE HIBRID
    FITRU DE REZERVOR FILTRU REZERVOR INTERIOR
    STOP AND START CU STOP AND START
    CUPLU RAPORT RAPORT PUNTE 17 X 74
    STIL ROATA (JANTA) STIL 05 17 INCI
    AMBREIAJ FARA AMBREIAJ
    DIFERENTIAL (CUTIE) DIFERENTIAL 86
    JANTA / PNEU DIMENSIUNI ECHIPARE PNEU 17 INCI
    PNEURI (DIMENSIUNI, TIP) PNEU 215/55 R17 94W NERANFORSAT
    ROATA (TIP) MONTARE ROATA ALIAJ 2
    INDICATOR DE PIERDERE A PRESIUNII DE UMFLARE FARA INDICATOR PENTRU PIERDERE PRESIUNE DIN PNEURI
    CUTIE DE VITEZE TIP CUTIE DE VITEZE MANUALA MC
    DISPOZITIV DE REMORCARE FARA DISPOZITIV DE REMORCARE
    ORNAMENT LATERAL (ASPECT) FARA ELEMENTE DE PROTECTIE LATERALE
    ORNAMENT DE ROATA (STIL) FARA CAPAC DE ROATA
    LUMINA DE PRAG LUMINI DE PRAG FATA
    SUPLIMENT DE PROTECTIE (SUB MOTOR) FARA PROTECTIE SUPLIMENTARA SUB MOTOR
    INEL DE FIXARE EXTERIOR (ADAUGAT) FARA INEL DE ARIMARE EXTERIOARA SUPRAPUS
    FUNCTIE COMPLEMENTARA DE RETROVIZOR EXTERIOR RETROVIZOR EXTERIOR RABATABIL ELECTRIC FARA MEMORIE
    INSONORIZARE PE MOTOR IZOLARE FONICA LA CAPOTA
    STERGATOR PARBRIZ MECANISM STERGERE PARBRIZ CU SENZOR DE PLOAIE
    STERGATOR DE LUNETA FARA MECANISM DE STERGERE LUNETA
    STERGATOR DE PROIECTOR MECANISM DE STERGERE PROIECTOR
    OBTURATOR FATA FATA CU OBTURATOR PE PANOUL FRONTAL AL MODULULUI DE INTRARE AER
    GEAM DE PAVILION FARA ELEMENT VITRAT DE PAVILION
    LUNETA (GEAM DE CAPAC DE PORTBAGAJ) GEAM FIX DE CAPAC DE PORTBAGAJ
    BARA DE PROTECTIE BARA DE PROTECTIE FATA/SPATE STANDARD CULOARE CAROSERIE + GRILA CROMATA
    APARATOARE DE NOROI (BAVETA) FARA APARATORI DE ROTI SPATE
    PORTBAGAJ MONTARE FARA USA SUPORT DE BAGAJE
    PROIECTOR ANTICEATA PROIECTOARE ANTI-CEATA
    ROATA DE REZERVA FARA ROATA DE REZERVA
    ACCESORII EXTERIOARE MANER EXTERIOR SI CULISA ORNAMENT, CROMATE
    RETROVIZOR EXTERIOR (RAZA ZONA CONDUCATOR) OGLINDA BOMBATA LA RETROVIZORUL EXTERIOR
    TRAPA DE PLAFON ACOPERIS FIX
    ORNAMENT DE BARA DE PROTECTIE BARA DE PROTECTIE CU INSERTIE CROMATA
    GEAM (ASPECT) GEAM FUMURIU
    GEAM (TIP) PARBRIZ STRATIFICAT CU IZOLARE FONICA + SPATE SECURIZAT
    ACCES SI PORNIRE CU MAINI LIBERE ACCES SI PORNIRE CU MAINI LIBERE
    ALARMA ANTIFURT FARA ALARMA ANTIFURT
    SCAUN SPATE BANCHETA SEPARATA RABATABILA
    DETECTARE UNGHI MORT FARA SISTEM DE SUPRAVEGHERE UNGHI MORT
    COTIERA DE SCAUN SPATE CU COTIERA SPATE
    CENTURA DE SIGURANTA SPATE CENTURI DE SIGURANTA SPATE CU 3 RETRACTOARE IN 3 PUNCTE + MARTOR LUMINOS DE CUPLARE
    CLIMA (TEMPERATURA AMBIANTA) TARI CU CLIMA TEMPERATA
    GRADARE VITEZE GRADATIE IN KM/H
    PARTE CONDUCERE (POST DE CONDUCERE) VOLAN PE STANGA
    INCALZIRE ADITIONALA FARA SISTEM DE INCALZIRE SUPLIMENTAR
    ECHIPAMENT PLANSA DE BORD DECORATIUNE CUBIC CU OCHIURI MICI
    LUMINI INTERIOARE DIVERSE CITITOR HARTA FATA + SPATE CU LED
    GARNISAJ SPATIU DE INCARCARE COVORAS DE PORTBAGAJ + PARTI LATERALE DIN MOCHETA
    TABLOU DE BORD (CARACTERISTICI) GRADATIE 260 KM/H 160 M/H MATRICE COLOR
    CAPITONAJ DE USA DECOR TESATURA
    DIFUZOR 4 DIFUZOARE FATA (2 TWEETERE + 2 FATA) + 4 DIFUZOARE SPATE
    COMANDA DE SISTEM AUDIO COMANDA SISTEM AUDIO LA DISTANTA STANDARD
    INSONORIZARE HABITACLU ELEMENT DE IZOLARE FONICA TABLIER 4 KG
    IZOLATIE (TRANSPERANT, PARASOLAR LATERAL, TRAPA DE PLAFON) TRANSPERANT MANUAL SPATE
    INALTARE SCAUN DE PASAGER FATA SISTEM INALTARE PERNA SCAUN PASAGER REGLAJ INAINTE
    COMANDA DE SCAUN FATA DE CONDUCATOR COMANDA MANUALA SCAUN CONDUCATOR
    COMANDA DE SCAUN FATA DE PASAGER COMANDA MANUALA SCAUN PASAGER FATA
    REGLARE PERNA DE SEZUT FATA CONDUCATOR SUPORT LOMBAR CU REGLARE CONDUCATOR
    REGLARE SCAUN FATA DE PASAGER SPATAR SCAUN PASAGER CARE SE POATE INCLINA
    SISTEM DE NAVIGATIE CU SISTEM DE NAVIGATIE CU ECRAN COLOR
    BECURI DE PROIECTOR LAMPA CU DESCARCARE
    ACTIONARE GEAM SPATE MECANISM ACTIONARE ELECTRICA GEAMURI SPATE CU COMANDA SECVENTIALA
    ACTIONARE GEAM FATA PASAGER MECANISM DE ACTIONARE GEAM PASAGER FATA CU COMANDA SECVENTIALA
    AFISAJ AFISAJ DEV
    OGLINDA DE PARASOLAR OGLINDA CONDUCATOR + PASAGER ILUMINATA CU CAPAC
    INDICATOR DE ULEI RECEPTOR TEMPORIZAT PENTRU NIVEL + TEMPERATURA
    FOLIE INCALZIRE SCAUN SCAUN FARA INCALZIRE
    AIRBAG LATERAL FATA AIRBAG LATERAL ZONA TORACE + AIRBAG CORTINA
    ILUMINAT JOS HABITACLU ILUMINAT ZONA PICIOARELOR CONDUCATOR + PASAGERI FATA + SPATE
    PROTECTIE PASAGER SPATE FARA ELEMET DE PROTECTIE PASAGER SPATE
    NEUTRALIZARE AIRBAG DEZACTIVARE MANUALA AIRBAG
    PROIECTOR CORECTIE VERTICALA REGLARE AUTOMATA A PROIECTOARELOR
    PROIECTOR DIRECTIONAL FARA PROIECTOR DIRECTIONAL
    RECEPTOR RADIO RADIOTELEFON CU AFISAJ DEPLASAT ’RT6’
    REFRIGERARE SISTEM DE REFRIGERARE AUTOMATA
    REGULATOR DE VITEZA SISTEM DE REGULARIZARE SI DE LIMITARE VITEZA
    INALTARE SCAUN FATA DE CONDUCATOR SISTEM DE INALTARE PERNA CONDUCATOR REGLARE MANUALA
    RETROVIZOR INTERIOR RETROVIZOR INTERIOR CROMAT ELECTROCHIMIC CU POZITII ZI-NOAPTE
    REGULATOR CLIMATIZARE / TEMPERATURA SISTEM DE REFRIGERARE AUTOMATA CU PATRU ZONE
    DEPOZITARE VOLUM DE INCARCARE FARA PLASA IN PORTBAGAJ
    TUNER-RADIO TRI TUNER RADIO
    DETECTAREA OBSTACOLULUI SISTEM DE DETECTARE OBSTACOL CU RADAR SPATE
    STORURI LATERALE TRANSPERANTE LATERALE "RAND 2"
    ADAPTARE GARNITURA MANER MANETA DE VITEZE DIN PIELE CU INSERTIE CROMATA
    AMPLIFICATOR-EGALIZATOR FARA AMPLIFICATOR EGALIZATOR
    FRECVENTA RADIO FRECVENTA RADIO EUROPA OCCIDENTALA
    COMANDA DE BLOCARE BLOCARE PRIN SIMPLA INCHIDERE
    VOLANT VOLAN IMBRACAT IN PIELE CU 3 BRATE
    AIRBAG DE GENUNCHI CONDUCATOR FARA AIRBAG PENTRU GENUNCHI CONDUCATOR
    ECRAN VIDEO SPATE FARA ECRAN VIDEO IN SPATE
    PRIZA AUXILIARA PACK AUDIO 1 PRIZA JACK + USB
    MODUL TELEMATIC MODUL TELEMATICA AUTONOM
    ALTERNATOR ISTT6
    BATERIE L3 800
    DEMAROR DEMAROR CLASA 5
    ILUMINAT DEOSEBIT APRINDERE AUTOMATA + LUMINI DIURNE FATA
    FRECVENTA TELECOMANDA BLOCARE DESCHIDERI FRECVENTA TELECOMANDA DE BLOCARE 433,92 MHZ HETERODINA
    APRINDERE LUMINI EXTERIOARE APRINDERE AUTOMATA A LUMINILOR + COMUTARE AUTOMATA
  3. #1173
    Join Date
    Sep 2019
    Location
    Bucuresti
    Posts
    14
    Rep Power
    0
    Quote Originally Posted by norishor View Post
    da, @luck33ro. Totusi, RAR-ul are ultimul cuvant din pacate.
    Cred ca o sa o inmatriculez la bulgari ca sa nu mai aiba RAR ultimul cuvant
Tags for this Thread
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
