Page 78 of 78 FirstFirst ... 28687475767778
Results 1,156 to 1,163 of 1163
Thread: VIN (Vehicle Identification Number) - Informatii utile
  1. #1156
    Join Date
    Mar 2013
    Location
    Navodari
    Posts
    46
    Rep Power
    0
    Dinule nu am mai intrat pe aici cam demult
    Daca nu e prea tarziu , poftim o lectura
    Caracteristicile vehiculului
    Linie de produs 508
    Nr. APV/PR 12660 CJ 1 0239
    Data de Inceput de Garantie 23.08.2011
    Numar de Serie Motor 10 DZ86 4002257
    NRE e2*2007/46*0080*01
    P4A 9666987299
    Informatii generale
    GEN DE PRODUS VEHICUL PARTICULAR
    MARCA COMERCIALA, TIP SUBANSAMBLU PEUGEOT
    LINIE DE PRODUS 508
    TIP CAROSERIE BERLINA 4 USI
    NIVEL DE ECHIPARE SUPERIOARA JOASA PLUS
    MOTOR DIESEL TURBO DW12C FILTRU DE PARTICULE
    TRANSMISIE CUTIE DE VITEZE AUTOMATA 6 TREPTE
    TIP DE VOPSEA METALIZATA LACUITA
    CULOAREA CAROSERIEI EEH - VOPSEA GRI HARIA2
    TIP ECHIPARE INTERIOARA PARTIAL DIN PIELE GT MARSTON "4Q"
    CULOARE GARNISAJ "FX"
    CUTIE DE VITEZE (CARACTERISTICI) CUTIE DE VITEZE AUTOMATA AM6C
    EVOLUTIE DEFINITIE TEHNICA GAMA INITIALA
    MOTOR (TIP) MOTOR TIP EW/DW
    Caracteristici vehicul
    DIRECTIE SISTEM DE DIRECTIE ASISTATA
    Alimentare motor
    DETECTOR DE APA IN FILTRUL DE MOTORINA FARA SISTEM DE DETECTARE APA IN FILTRUL DE MOTORINA
    CARBURANT MOTORINA CALITATE DA/DE/DE+
    DEPOLUARE (MOTOR) DEPOLLUTION MOTEUR SUPERIEUR L6 EURO 5
    ESAPAMENT TOBA DE ESAPAMENT TRANSVERSALA
    CILINDREE 2200 CM3
    CATALIZATOR CATALIZATOR IMPREGNAT SUB 10PPM
    RECIRE ULEI SCHIMBATOR PE MOTOR SI CUTIE DE VITEZE
    REZERVOR DE CARBURANT REZERVOR CARBURANT CU ELEMENT DE INDEXARE
    INCALZIRE CIRCUIT GAZE CARTER SISTEM DE INCALZIRE A CIRCUITULUI DE GAZE DIN CARTER
    AUTODIAGNOSTICARE EOBD SISTEM DE AUTODIAGNOSTICARE "EOBD"
    DISPOZITIV (ANTIPOLUARE) RECIRCULARE GAZE DE ESAPAMENT "EGR"
    DEPOLUARE TEHNICA VEHICUL DEPOLUARE TEHNICA VEHICUL EURO5
    FILTRU DE PARTICULE CU FILTRU DE PARTICULE
    VENTILATOR 2 VENTILATOARE ELECTRONICE CU COMANDA INTEGRATA 300W
    VARIANTA SOCIATA INJECTIE MONTARE BOSCH
    LANT DE TRACTIUNE HIBRIDA FARA LANT DE TRACTIUNE HIBRID
    FITRU DE REZERVOR FILTRU REZERVOR INTERIOR
    STOP AND START FARA SISTEM STOP AND START
    Cutie de viteze - Transmisie
    CUPLU RAPORT RAPORT PUNTE 15 X 53
    STIL ROATA (JANTA) STIL 10 DE 18 INCI
    AMBREIAJ FARA AMBREIAJ
    DIFERENTIAL (CUTIE) DIFERENTIAL 86
    JANTA / PNEU DIMENSIUNI ECHIPARE CU PNEURI DE 18 INCI
    PNEURI (DIMENSIUNI, TIP) PNEU 235/45 R18 98W INTARIT
    ROATA (TIP) MONTARE ROATA ALIAJ 2
    INDICATOR DE PIERDERE A PRESIUNII DE UMFLARE INDICATOR PIERDERE PRESIUNE PNEURI
    CUTIE DE VITEZE TIP CUTIE DE VITEZE AUTOMATA AM6 NORMA EURO5
    Suspensie - directie - Franare
    BARA ANTIRULIU SPATE BARA ANTIRULIU SPATE DIAMETRU 21
    ANTIRULIU FATA BARA ANTIRULIU FATA DIAMETRU 24
    SUSPENSIE SUSPENSIE NORMALA
    CONTROL DINAMIC AL STABILITATII CU SISTEM ESP
    VARIANTA ASOCIATA FRANA ESP BOSCH 8 1
    DIRECTIE (FUNCTIONARE) DIRECTIE ASISTATA ELECTROHIDRAULIC
    Caroserie Echipamente
    DISPOZITIV DE REMORCARE FARA DISPOZITIV DE REMORCARE
    ORNAMENT LATERAL (ASPECT) FARA ELEMENTE DE PROTECTIE LATERALE
    ORNAMENT DE ROATA (STIL) FARA CAPAC DE ROATA
    LUMINA DE PRAG LUMINI DE PRAG FATA
    SUPLIMENT DE PROTECTIE (SUB MOTOR) FARA PROTECTIE SUPLIMENTARA SUB MOTOR
    INEL DE FIXARE EXTERIOR (ADAUGAT) FARA INEL DE ARIMARE EXTERIOARA SUPRAPUS
    FUNCTIE COMPLEMENTARA DE RETROVIZOR EXTERIOR RETROVIZOR EXTERIOR RABATABIL ELECTRIC FARA MEMORIE
    STERGATOR PARBRIZ MECANISM STERGERE PARBRIZ CU SENZOR DE PLOAIE
    STERGATOR DE LUNETA FARA MECANISM DE STERGERE LUNETA
    STERGATOR DE PROIECTOR MECANISM DE STERGERE PROIECTOR
    OBTURATOR FATA FATA FARA OBTURATOR PARTE FRONTALA FATA
    GEAM DE PAVILION FARA ELEMENT VITRAT DE PAVILION
    LUNETA (GEAM DE CAPAC DE PORTBAGAJ) GEAM FIX DE CAPAC DE PORTBAGAJ
    BARA DE PROTECTIE BARA DE PROTECTIE FATA/SPATE STANDARD CULOARE CAROSERIE + GRILA VOPSITA
    APARATOARE DE NOROI (BAVETA) FARA APARATORI DE ROTI SPATE
    PORTBAGAJ MONTARE FARA USA SUPORT DE BAGAJE
    PROIECTOR ANTICEATA PROIECTOARE ANTI-CEATA
    ROATA DE REZERVA ROATA TIP ROLA
    ACCESORII EXTERIOARE MANER EXTERIOR SI CULISA ORNAMENT, CROMATE
    RETROVIZOR EXTERIOR (RAZA ZONA CONDUCATOR) OGLINDA BOMBATA LA RETROVIZORUL EXTERIOR
    TRAPA DE PLAFON ACOPERIS FIX
    ORNAMENT DE BARA DE PROTECTIE BARA DE PROTECTIE CU INSERTIE CROMATA
    GEAM (ASPECT) GEAM FUMURIU
    GEAM (TIP) PARBRIZ STRATIFICAT CU IZOLARE FONICA + SPATE SECURIZAT
    ACCES SI PORNIRE CU MAINI LIBERE ACCES SI PORNIRE CU MAINI LIBERE
    Echipament interior
    ALARMA ANTIFURT FARA ALARMA ANTIFURT
    SCAUN SPATE BANCHETA SEPARATA RABATABILA
    DETECTARE UNGHI MORT FARA SISTEM DE SUPRAVEGHERE UNGHI MORT
    COTIERA DE SCAUN SPATE CU COTIERA SPATE
    CENTURA DE SIGURANTA SPATE CENTURI DE SIGURANTA SPATE CU 3 RETRACTOARE IN 3 PUNCTE + MARTOR LUMINOS DE CUPLARE
    CLIMA (TEMPERATURA AMBIANTA) TARI CU CLIMA FOARTE RECE
    GRADARE VITEZE GRADATIE IN KM/H
    PARTE CONDUCERE (POST DE CONDUCERE) VOLAN PE STANGA
    INCALZIRE ADITIONALA FARA SISTEM DE INCALZIRE SUPLIMENTAR
    ECHIPAMENT PLANSA DE BORD DECORATIUNE METAL
    LUMINI INTERIOARE DIVERSE CITITOR HARTA FATA + SPATE CU LED
    GARNISAJ SPATIU DE INCARCARE COVORAS DE PORTBAGAJ + PARTI LATERALE DIN MOCHETA
    TABLOU DE BORD (CARACTERISTICI) GRADATIE 260 KM/H 160 M/H MATRICE COLOR
    CAPITONAJ DE USA DECORATIUNE TEP
    DIFUZOR 4 DIFUZOARE FATA (2 TWEETERE + 2 FATA) + 4 DIFUZOARE SPATE
    COMANDA DE SISTEM AUDIO COMANDA SISTEM AUDIO LA DISTANTA STANDARD
    INSONORIZARE HABITACLU ELEMENT DE IZOLARE FONICA TABLIER 4 KG
    IZOLATIE (TRANSPERANT, PARASOLAR LATERAL, TRAPA DE PLAFON) FARA TRANSPERANT SPATE
    INALTARE SCAUN DE PASAGER FATA DISPOZITIV DE INALTARE PERNA PASAGER REGLARE PARALELA + AVANSARE
    COMANDA DE SCAUN FATA DE CONDUCATOR COMANDA ELECTRICA SCAUN FATA + REGLARE PARTE SUPERIOARA DE PERNA
    COMANDA DE SCAUN FATA DE PASAGER COMANDA ELECTRICA SCAUN PASAGER FATA + REGLARE PARTE SUPERIOARA DE PERNA
    REGLARE PERNA DE SEZUT FATA CONDUCATOR SUPORT LOMBAR CU REGLARE CONDUCATOR
    REGLARE SCAUN FATA DE PASAGER REGLARE SUPORT LOMBAR PASAGER
    SISTEM DE NAVIGATIE CU SISTEM DE NAVIGATIE CU ECRAN COLOR
    BECURI DE PROIECTOR LAMPA CU DESCARCARE
    ACTIONARE GEAM SPATE MECANISM ACTIONARE ELECTRICA GEAMURI SPATE CU COMANDA SECVENTIALA
    ACTIONARE GEAM FATA PASAGER MECANISM DE ACTIONARE GEAM PASAGER FATA CU COMANDA SECVENTIALA
    AFISAJ AFISAJ DEV
    OGLINDA DE PARASOLAR OGLINDA CONDUCATOR + PASAGER ILUMINATA CU CAPAC
    INDICATOR DE ULEI RECEPTOR TEMPORIZAT PENTRU NIVEL + TEMPERATURA
    FOLIE INCALZIRE SCAUN SCAUN CU INCALZIRE
    AIRBAG LATERAL FATA AIRBAG LATERAL ZONA TORACE + AIRBAG CORTINA
    ILUMINAT JOS HABITACLU ILUMINAT ZONA PICIOARELOR CONDUCATOR + PASAGERI FATA + SPATE
    PROTECTIE PASAGER SPATE FARA ELEMET DE PROTECTIE PASAGER SPATE
    NEUTRALIZARE AIRBAG DEZACTIVARE MANUALA AIRBAG
    PROIECTOR CORECTIE VERTICALA REGLARE AUTOMATA A PROIECTOARELOR
    PROIECTOR DIRECTIONAL FARA PROIECTOR DIRECTIONAL
    RECEPTOR RADIO RADIOTELEFON CU AFISAJ DEPLASAT ’RT6’
    REFRIGERARE SISTEM DE REFRIGERARE AUTOMATA
    REGULATOR DE VITEZA SISTEM DE REGULARIZARE SI DE LIMITARE VITEZA
    INALTARE SCAUN FATA DE CONDUCATOR SISTEM DE INALTARE PERNA SCAUN CONDUCATOR CU REGLARE ELECTRICA
    RETROVIZOR INTERIOR RETROVIZOR INTERIOR CROMAT ELECTROCHIMIC CU POZITII ZI-NOAPTE
    REGULATOR CLIMATIZARE / TEMPERATURA SISTEM DE REFRIGERARE AUTOMATA CU DOUA ZONE
    DEPOZITARE VOLUM DE INCARCARE FARA PLASA IN PORTBAGAJ
    TUNER-RADIO TRI TUNER RADIO
    DETECTAREA OBSTACOLULUI SISTEM DE DETECTARE OBSTACOL RADAR FATA SPATE MDP
    STORURI LATERALE FARA TRANSPERANTE LATERALE
    ADAPTARE GARNITURA MANER PIELE CU LUMINA DE FUNDAL
    AMPLIFICATOR-EGALIZATOR FARA AMPLIFICATOR EGALIZATOR
    FRECVENTA RADIO FRECVENTA RADIO EUROPA OCCIDENTALA
    COMANDA DE BLOCARE BLOCARE PRIN SIMPLA INCHIDERE
    VOLANT VOLAN IMBRACAT IN PIELE CU 3 BRATE
    AIRBAG DE GENUNCHI CONDUCATOR FARA AIRBAG PENTRU GENUNCHI CONDUCATOR
    ECRAN VIDEO SPATE FARA ECRAN VIDEO IN SPATE
    PRIZA AUXILIARA PACK AUDIO 1 PRIZA JACK + USB
    MODUL TELEMATIC MODUL TELEMATICA AUTONOM
    Electricitate
    ALTERNATOR ALTERNATOR CLASA 18
    BATERIE L3 760 VRLA1 EN AGM
    DEMAROR DEMAROR CLASA 6+
    ILUMINAT DEOSEBIT APRINDERE AUTOMATA + LUMINI DIURNE FATA
    FRECVENTA TELECOMANDA BLOCARE DESCHIDERI FRECVENTA TELECOMANDA DE BLOCARE 433,92 MHZ HETERODINA
    APRINDERE LUMINI EXTERIOARE APRINDERE AUTOMATA A LUMINILOR + COMUTARE AUTOMATA
    Marci echipamente
    Diverse
    CRITERIU FACTORI, CLIENTELA CONCEPTIE STANDARD
    ATMOSFERA ATMOSFERA NORMALA
    ETICHETA FARA ETICHETA
    CONECTOR DE ASCULTARE SISTEM AUDIO PRIZA ACCESORII TRIPLA
    PARTEA DE CIRCULATIE CIRCULARE PE DREAPTA
    SET DE CHEI 2 CHEI TELECOMANDA DE INALTA FRECVENTA
    ECHIPAMENT DE PRIM AJUTOR FARA ECHIPARE DE REZERVA
    RULARE DRUM CORECT
    MODUL ELECTRONIC (BOÎTIER SERVITUDE) BSI EVOLUTION
    TRIUNGHI DE PRESEMNALIZARE FARA TRIUNGHI REFLECTORIZANT
  2. #1157
    Join Date
    Mar 2013
    Location
    Navodari
    Posts
    46
    Rep Power
    0
    Pentru Bogdan V. ( user nevalidat )
    Poate din aceasta cauza - ca userul tau nu a fost validat inca , nu ai primit si poate nici nu vei putea primi mesaje de la mine
    Asa ca iti raspund aici pentru verificare de VIN vf33H9HYB84424787
    Linie de produs 307 RESTYL
    Nr. APV/PR 10565 89 2 0242
    Numar de Serie Motor 10 JB57 3003143
    NRE e2*2001/116*0299*02
    Informatii generale
    LINIE DE PRODUS 307 RESTYL
    TIP CAROSERIE BREAK TIMP LIBER
    NIVEL DE ECHIPARE MEDIE INALTA
    MOTOR DIESEL TURBO DV6TED4 110CV FARA FILTRU DE PARTICULE
    TRANSMISIE CUTIE DE VITEZE MANUALA5
    TIP DE VOPSEA VOPSEA METALIZATA LACUITA
    CULOAREA CAROSERIEI EZR - VOPSEA GRI ALUMINIU
    TIP ECHIPARE INTERIOARA TESATURA SI URZEALA MINIKA + EKFA "NV"
    CUTIE DE VITEZE (CARACTERISTICI) CUTIE DE VITEZE MECANICA BE4 L
    MOTOR (TIP) MOTOR TIP DV
    MONOGRAMA COMPLEMENTARA, DIVERSE HDI (I CROM)
    MONOGRAMA SW
    DIRECTIE SISTEM DE DIRECTIE VARIABILA ASISTATA
    CUPLU DE TAHOMETRU RAPORT TRANSMISIE 22 X NO
    Alimentare motor
    DETECTOR DE APA IN FILTRUL DE MOTORINA CU SISTEM DE DETECTARE APA IN FILTRUL DE MOTORINA
    BLOC CILINDRI (MATERIAL) BLOC CILINDRI ALUMINIU
    CARBURANT MOTORINA
    DEPOLUARE (MOTOR) DEPOLUARE CEE 2000 (MOTOR)
    CATALIZATOR CATALIZATOR CU 2 COMPUSI IN FILTRE IMPREGNATE CU PLATINA
    RECIRE ULEI SCHIMBATOR APA/ULEI MOTOR
    INCALZIRE CIRCUIT GAZE CARTER FARA SISTEM DE INCALZIRE CIRCUIT DE GAZE CARTER
    AUTODIAGNOSTICARE EOBD AUTODIAGNOSTICARE "EOBD" FARA ACCELEROMETRU
    DEPOLUARE TEHNICA VEHICUL DEPOLUARE TEHNICA VEHICUL L4
    FILTRU DE PARTICULE FARA FILTRU DE PARTICULE
    VENTILATOR 1 VENTILATOR 2 TURATII 130W AERO
    RECUPERARE VAPORI DE BENZINA FARA SISTEM DE RECUPERARE A VAPORILOR DE BENZINA
    VARIANTA SOCIATA INJECTIE SISTEM DE INJECTIE BOSCH
    CUPLU RAPORT CP 19 X 72
    STIL ROATA (JANTA) ROATA CU JANTA DIN TABLA 16 INCI
    AMBREIAJ AMBREIAJ HIDRAULIC
    TIP DE CUTIE DE VITEZE (OMOLOGARE) CUTIE DE VITEZE TIP BE4/5 L
    DIFERENTIAL (CUTIE) DIFERENTIAL 84
    JANTA / PNEU DIMENSIUNI MONTAJ PNEU 16 INCI
    PNEURI (DIMENSIUNI, TIP) PNEU 205/55 R16 91V FARA INTARIRE
    ROTI MONTATE ROATA 6 INCI 1/2
    ROATA (TIP) MONTARE ROATA CU JANTA DIN TABLA
    INDICATOR DE PIERDERE A PRESIUNII DE UMFLARE FARA INDICATOR PENTRU PIERDERE PRESIUNE DIN PNEURI
    CUTIE DE VITEZE TIP CUTIE DE VITEZE MANUALA BE4R
    BARA ANTIRULIU SPATE BARA ANTIRULIU SPATE DIAMETRU 30
    ANTIRULIU FATA BARA ANTIRULIU FATA DIAMETRU 23
    RACIRE ULEI DE POMPA DE DIRECTIE FARA SISTEM DE RACIRE ULEI DE POMPA DE DIRECTIE
    CONTROL DINAMIC AL STABILITATII FARA SISTEM ESP
    VARIANTA ASOCIATA FRANA ABS BOSCH 8 0
    PEDALIER (TIP) PEDALIER STANDARD
    AVERTIZOARE SISTEM DE AVERTIZARE STANDARD
    ANTENA ANTENA SCURTA PAVILION
    DECORATIUNE (ADEZIVA) ORNAMENT SPATE DE USA FATA + ORNAMENT FATA DE USA SPATE
    ORNAMENT LATERAL (ASPECT) ELEMENTE DE PROTECTIE LATERALE CULOAREA CAROSERIEI
    ORNAMENT LATERAL (DIMENSIUNE) ELEMENTE DE PROTECTIE LATERALE
    ORNAMENT DE ROATA (STIL) STIL JUPITER 8 FANTE 16 INCI
    LUMINA DE MERS INAPOI CU 1 LUMINA PENTRU MERS INAPOI
    FUNCTIE COMPLEMENTARA DE RETROVIZOR EXTERIOR RETROVIZOR EXTERIOR CU PLIERE MANUALA
    ORNAMENT DE CAP DE TEAVA DE ESAPAMENT FARA ORNAMENT PE IESIREA TEVII DE ESAPAMENT
    INSONORIZARE PE MOTOR IZOLARE FONICA LA CAPOTA
    STERGATOR PARBRIZ MECANISM STERGERE PARBRIZ FARA SENZOR DE PLOAIE
    STERGATOR DE LUNETA MECANISM DE STERGERE LUNETA
    STERGATOR DE PROIECTOR FARA MECANISM DE STERGERE PROIECTOR
    GEAM DE PAVILION CU GEAM DE PAVILION
    BARA DE PROTECTIE BARA DE PROTECTIE FATA + SPATE STANDARD IN CULOAREA CAROSERIEI
    APARATOARE DE NOROI (BAVETA) CU APARATORI DE ROTI SPATE
    RETROVIZOR EXTERIOR (PARTEA CONDUCATORULUI) RETROVIZOR EXTERIOR CONDUCATOR CU COMANDA ELECTRICA
    RETROVIZOR EXTERIOR (PARTEA PASAGERULUI) RETROVIZOR EXTERIOR PASAGER CU COMANDA ELECTRICA
    ROATA DE REZERVA ROATA CU JANTA TABLA + PNEU CU DIMENSIUNE NESTANDARDIZATA
    ACCESORII EXTERIOARE MANER EXTERIOR + ORNAMENT CAPAC ALUMINIU + RETROVIZOR EXTERIOR IN CULOAREA CAROSERIEI
    SPALARE LUNETA MECANISM DE SPALARE LUNETA
    ORNAMENT DE BARA DE PROTECTIE BANDOU DE BARA DE PROTECTIE CULOAREA CAROSERIEI
    GEAM (ASPECT) GEAM FUMURIU + FUMURIU INCHIS SPATE
    GEAM LATERAL SPATE (NATURA) GEAM LATERAL SPATE FIX
    GEAM (TIP) PARBRIZ STRATIFICAT CU IZOLARE FONICA + GEAMURI LATERALE & SPATE SECURIT
    PACHET RADIO / INFORMATII / COMUNICARE RD4, FARA NAVIGATIE, AFISAJ NIVEL C, FARA AMPLIFICATOR EGALIZATOR
    Echipament interior
    ALARMA ANTIFURT CU ALARMA ANTIFURT
    TETIERA SPATE TETIERA SPATE REGLABILA
    TETIERA FATA TETIERA FATA ARTICULATA
    SCAUN SPATE 3 SCAUNE SPATE SEPARATE (1 CULISANT)
    SCAUN SUPLIMENTAR FARA PERNA DE SCAUN SUPLIMENTARA
    COTIERA DE SCAUN SPATE FARA COTIERA SPATE
    BAGHETA PLANSEU DE INCARCARE CU BAGHETA DE PLANSEU DE INCARCARE
    MASCARE BAGAJE CU PANOU DE MASCARE BAGAJE
    CENTURA DE SIGURANTA SPATE CENTURI DE SIGURANTA SPATE 5 RETRACTOARE IN 3 PUNCTE
    CENTURA DE SIGURANTA FATA CENTURA DE SIGURANTA PIROTEHNICA CU ALARMA
    CLIMA (TEMPERATURA AMBIANTA) TARI CU CLIMA RECE
    AMBALARE SISTEM AUDIO ALIMENTARE ANTENA RECEPTOR DIFUZOR FATA/SPATE TWEETER
    INCALZIRE ADITIONALA SISTEM DE INCALZIRE SUPLIMENTARA AUTOMATA
    ECHIPAMENT PLANSA DE BORD PLANSA DE BORD STANDARD + FATADA GRI LION
    VARIATIE DE ECHIPARE INTERIOARA VOLAN MANER BURDUF PIELE
    DEPOZITARE SUB SCAUN 2 SERTARE DE DEPOZITARE SUB SCAUN
    TABLOU DE BORD (CARACTERISTICI) GRADATIE 220 KM/H 140 M/H FUNDAL NEGRU CU CONTUR CROMAT
    DIFUZOR 4 DIFUZOARE FATA (2 TWEETERE + 2 FATA) + 2 DIFUZOARE SPATE
    COMANDA DE SISTEM AUDIO COMANDA SISTEM AUDIO LA DISTANTA FARA FUNCTIE CD
    INALTARE SCAUN DE PASAGER FATA SISTEM DE INALTARE PERNA SCAUN PASAGER FATA REGLARE PARALELA
    COMANDA DE SCAUN FATA DE CONDUCATOR COMANDA MANUALA SCAUN CONDUCATOR
    RABATERE SCAUN FATA DE CONDUCATOR SCAUN CONDUCATOR FARA SISTEM DE RABATERE PERNA DE SEZUT
    RABATERE SCAUN FATA DE PASAGER FARA RABATERE PERNA DE SEZUT DE SCAUN PASAGER FATA
    COTIERA DE SCAUN FATA COTIERE FATA CONDUCATOR SI PASAGER
    INDICATOR DE TEMPERATURA EXTERIOARA INDICATOR TEMPERATURA EXTERIOARA
    CD FARA MONTARE COMPACT DISC
    CASETA DE DEPOZITARE FARA CONTAINER DE DEPOZITARE
    SISTEM DE NAVIGATIE FARA SISTEM DE NAVIGARE
    BECURI DE PROIECTOR LAMPA CU HALOGEN
    ACTIONARE GEAM SPATE MECANISM ACTIONARE GEAMURI SPATE CU COMANDA MANUALA
    ACTIONARE GEAM DE CONDUCATOR MECANISM ACTIONARE GEAM CONDUCATOR CU COMANDA SECVENTIALA
    AFISAJ AFISAJ (RADIO + CEAS, T°,CD)
    SUPORT DE PICIOR SUPORT SPRIJINIRE PICIOR CONDUCATOR
    INDICATOR DE ULEI SENZOR DE NIVEL DE ULEI
    MONTARE TETIERA SPATE MONTARE 3 TETIERE SPATE
    FOLIE INCALZIRE SCAUN SCAUN FARA INCALZIRE
    AIRBAG DE PASAGER AIRBAG LATERAL PASAGER
    ACTIONARE GEAM ELECTRICA (FUNCTIONARE) FUNCTIE ANTIPRINDERE PE PARTEA CONDUCATORULUI + PASAGERULUI
    CALCULATOR DE BORD CU CALCULATOR DE BORD
    PACHET ECHIPAMENT FARA PACHET ECHIPAMENT
    RETROVIZOR EXTERIOR RETROVIZOR EXTERIOR CU INCALZIRE
    COMANDA INTERIOARA DE USA (ASPECT) COMANDA INTERIOARA USA ASPECT GRI LION
    PROIECTOR CORECTIE VERTICALA REGLARE MANUALA DE LA DISTANTA A PROIECTOARELOR
    PROTECTIE POST FATA FARA PROTECTIE POST FATA
    DEPOZITARE (POST DE CONDUCERE) FARA COMPARTIMENT DE DEPOZITARE IN CONSOLA FATA DE PAVILION
    RECEPTOR RADIO SISTEM AUDIO COMPACT DISC RDS "RD4"
    REGULATOR DE VITEZA FARA SISTEM DE REGULARIZARE VITEZA
    INALTARE SCAUN FATA DE CONDUCATOR RIDICARE SCAUN CONDUCATOR REGLARE PARALELA
    RETROVIZOR INTERIOR RETROVIZOR INTERIOR CU REGLARE PENTRU ZI - NOAPTE
    COVORAS DE PODEA (ASPECT) FARA COVORAS SUPLIMENTAR
    AIRBAG DE CONDUCATOR AIRBAG LATERAL CONDUCATOR
    DEPOZITARE VOLUM DE INCARCARE CU PLASA IN PORTBAGAJ
    TUNER-RADIO CU UN SINGUR TUNER RADIO
    DETECTAREA OBSTACOLULUI SISTEM DE DETECTARE OBSTACOLE
    ADAPTARE GARNITURA MANER LEVIER DE VITEZE + BURDUF PIELE
    COVORAS DE PODEA FARA COVORAS SUPLIMENTAR
    FRECVENTA RADIO FRECVENTA RADIO ASIA
    COMANDA DE BLOCARE BLOCARE PRIN SUPRA INCHIDERE + AUTOMATA
    Electricitate
    ALTERNATOR ALTERNATOR CLASA 15
    BATERIE BATERIE L2 400
    ILUMINAT DEOSEBIT FARA ILUMINAT SPECIAL
    MULTIPLEXARE MONTARE RETEA MULTIPLEXATA CAN CAN
    Marci echipamente
    Diverse
    SOC LATERAL USA CARE NU ESTE INTARITA
    RULARE DRUM CORECT
    MONITORIZARE VITEZA FARA SISTEM DE MONITORIZARE VITEZA
    MODUL ELECTRONIC (BOÎTIER SERVITUDE) BSI COMM 2003
  3. #1158
    Join Date
    Mar 2019
    Location
    Bucuresti
    Posts
    3
    Rep Power
    0
    caracteristici?
    Buna, ma poate ajuta cineva cu lista de caracteristici pentru VF3HURHC8DS167101 ? multumesc.
  4. #1159
    Join Date
    Mar 2013
    Location
    Navodari
    Posts
    46
    Rep Power
    0
    Linie de produs 3008 (T84E)
    Nr. APV/PR 13444 89 2 0024
    Data de Inceput de Garantie 31.10.2013
    Numar de Serie Motor 10 DYZC 4040369
    NRE e2*2007/46*0094*05
    P4A 9691239599
    Informatii generale
    LINIE DE PRODUS 3008 (T84E)
    TIP CAROSERIE CROSS OVER 5 USI
    NIVEL DE ECHIPARE INALTA JOASA
    MOTOR DIESEL TURBO DW10CTED4 FILTRU DE PARTICULE
    TRANSMISIE CUTIE DE VITEZE MANUALA PILOTATA 6 TREPTE HIBRIDA
    CULOAREA CAROSERIEI KTV - VOPSEA NEGRU PERLA NERA
    TIP ECHIPARE INTERIOARA TESATURA OMBRAGE+SOFIS "9Z"
    CUTIE DE VITEZE (CARACTERISTICI) CUTIE DE VITEZE MANUALA MC6F
    EVOLUTIE DEFINITIE TEHNICA ANIMATIE DE GAMA
    MONOGRAMA COMPLEMENTARA, DIVERSE FARA MONOGRAMA SUPLIMENTARA
    MONOGRAMA FARA MONOGRAMA
    Alimentare motor
    ALIMENTARE INJECTIE TURBO DIRECTA CU SCHIMBATOR
    CARBURANT MOTORINA
    DEPOLUARE (MOTOR) DEPOLUARE EURO5 (MOTOR)
    CILINDREE 2000 CM3
    CATALIZATOR CATALIZATOR CU MAI PUTIN DE 50PPM
    MOTOR RACIRE RADIATOR EP:35 - 21 DM2 ALUMINIU BRAZAT
    DISPOZITIV (ANTIPOLUARE) RECICLARE GAZE DE ESAPAMENT "EGR" + SCHIMBATOR
    FILTRU DE PARTICULE FILTRU DE PARTICULE
    VENTILATOR 1 VENTILATOR 2 TURATII 160W
    VARIANTA SOCIATA INJECTIE SISTEM DE INJECTIE DELPHI
    LANT DE TRACTIUNE HIBRIDA LANT DE TRACTIUNE HIBRID
    STOP AND START CU STOP AND START
    CUPLU RAPORT RAPORT PUNTE 17 X 74
    STIL ROATA (JANTA) ROATA ISARA 16 INCI
    PNEURI (DIMENSIUNI, TIP) PNEU 215/60 R16 95H FARA INTARIRE
    ROTI MONTATE ROATA 7 INCI
    CUTIE DE VITEZE TIP CUTIE DE VITEZE MANUALA MC
    BARA ANTIRULIU SPATE BARA ANTIRULIU SPATE DIAMETRU 25
    ANTIRULIU FATA BARA ANTIRULIU FATA DIAMETRU 25
    AVERTIZOARE SISTEM DE AVERTIZARE ACORD
    ANTENA ANTENA + GPS
    DEFLECTOR AERODINAMIC SPATE MONTARE CU DEFLECTOR DE AER
    ORNAMENT LATERAL (ASPECT) ELEMENTE DE PROTECTIE + PARTE INFERIOARA DE CAROSERIE NEAGRA + INSERTIE CROMATA
    PROTECTIE SUB CAROSERIE ELEMENT DE PROTECTIE DIN MATERIAL PLASTIC SUB MOTOR
    LUMINA DE PRAG FARA LUMINA DE PRAG
    FUNCTIE COMPLEMENTARA DE RETROVIZOR EXTERIOR RETROVIZOR EXTERIOR PLIABIL ELECTRIC + DIODA/LED
    APARATOARE DE NOROI APARATOARE DE NOROI STANDARD CU SPUMA FATA
    STERGATOR PARBRIZ MECANISM STERGERE PARBRIZ CU INTERMITENTA CU CADENTA AUTOMATA + INDICATOR NIVEL DE APA
    OBTURATOR FATA FATA CU OBTURATOR PE PANOUL FRONTAL AL MODULULUI DE INTRARE AER
    BARA DE PROTECTIE BARA DE PROTECTIE FATA/SPATE COLORATA IN MASA
    ROATA DE REZERVA FARA ROATA DE REZERVA
    ACCESORII EXTERIOARE MANER EXTERIOR CULOARE CORSERIE
    ORNAMENT DE BARA DE PROTECTIE BANDOU DE BARA DE PROTECTIE CROMAT - AVENTURA
    GEAM (ASPECT) FUMURIU + FUMURIU INCHIS
    Echipament interior
    CENTURA DE SIGURANTA FATA CENTURA DE SIGURANTA PIROTEHNICA DUBLA CU ALARMA
    CLIMA (TEMPERATURA AMBIANTA) TARI CU CLIMA TEMPERATA
    SIGURANTA COPII SIGURANTA COPIL USI SPATE CU COMANDA ELECTRICA
    CONSOLA CONSOLA LUNGA + COMPARTIMENT DE DEPOZITARE
    ILUMINAT DE PORTBAGAJ VOLUM INCARCARE COMANDA AUTOMATA DE ILUMINAT PORTBAGAJ SI VOLUM DE INCARCARE
    VARIATIE DE ECHIPARE INTERIOARA MANER CONSOLA CENTRALA PIELE
    LUMINI INTERIOARE DIVERSE 1 PLAFONIERA FATA + 1 PLAFONIERA SPATE + 2 LAMPI DE CITIT FATA + 2 LIS SPATE
    DEPOZITARE SUB SCAUN FARA COMPARTIMENT DE DEPOZITARE SUB SCAUN
    TABLOU DE BORD (CARACTERISTICI) TABLOU DE BORD CU MATRICE
    REGLARE PERNA DE SEZUT FATA CONDUCATOR SUPORT LOMBAR CONDUCATOR
    SISTEM DE NAVIGATIE CU SISTEM DE NAVIGATIE ECRAN COLOR + INFO TRAFIC
    ACTIONARE GEAM SPATE MECANISM DE ACTIONARE GEAM SPATE SECVENTIAL CU COMANDA ELECTRICA
    CITITOR DE INFORMATII RUTIERE FARA SISTEM DE SUPRAVEGHERE TRAIECTORIE LATERALA
    AFISAJ AFISAJ DG4
    ILUMINAT JOS HABITACLU FARA ILUMINAT INFERIOR DE HABITACLU
    WIFI FARA WIFI
    RECEPTOR RADIO RT6 RADIOTELEFON - AFISAJ DEPLASAT
    DEPOZITARE (ALTELE) BUZUNARE PE SPATARELE SCAUNELOR FATA + COMPARTIMENTE DE DEPOZITARE SUB SCAUNELE RANDULUI 2
    COVORADS DE PODEA MOCHETA DILOURS F330
    TUNER-RADIO TUNER DUBLU RADIO
    DETECTAREA OBSTACOLULUI SISTEM DE DETECTARE OBSTACOLE CU RADAR FATA SPATE
    ADAPTARE GARNITURA MANER MANETA DE VITEZE DIN PIELE CU INSERTIE CROMATA
    COMANDA DE BLOCARE BLOCARE PRIN SIMPLA INCHIDERE + AUTOMATA
    VOLANT VOLAN IMBRACAT IN PIELE 3 BRATE CU DECORATIUNE METALICA
    PRIZA AUXILIARA PACK AUDIO 1 PRIZA USB
    Electricitate
    ALTERNATOR ALTERNATOR ISTT6
    BATERIE BATERIE L3 450
    DEMAROR DEMAROR CLASA 5
    ILUMINAT DEOSEBIT LUMINI DE ZI FATA
    MASURA INCARCARII BATERIEI CU SISTEM DE MASURARE A NIVELULUI DE INCARCARE A BATERIEI
    Marci echipamente
    Diverse
    CRITERIU FACTORI, CLIENTELA CONCEPTIE BUSINESS LINE
    MODIFICARE AN MODEL IN CURS FARA MODIFICARE IMPORTANTA
    SET DE CHEI 2 CHEI TELECOMANDA INALTA FRECVENTA
    ECHIPAMENT DE PRIM AJUTOR KIT REPARARE PROVIZORIE PNEU
    Sa o stapanesti sanatos !!!
    (nice car)
  5. #1160
    Join Date
    Mar 2019
    Location
    Bucuresti
    Posts
    3
    Rep Power
    0
    Mulțumesc. Nu am luat o încă. Dar din ce vad nu prea se potriveste cu ce e în poze autovit.ro/anunt/peugeot-3008-ID7Gjz2J.html#ac4ce49470. Țesătură vs piele, ecrane în tetiere Vin zice ca nu dar de fapt sunt. Care o fi problema?
  6. #1161
    skipper's Avatar
    Join Date
    Apr 2006
    Location
    B
    Posts
    135
    Rep Power
    13
    Salut.
    Ma poate ajuta si pe mine cineva cu istoricul pt VF36ERHRE21355147 ? Caracteristicile le-am gasit, istoricul de service nu!
  7. #1162
    skipper's Avatar
    Join Date
    Apr 2006
    Location
    B
    Posts
    135
    Rep Power
    13
    Reinoiesc rugamintea, poate reuseste cineva!
    Multumiri anticipate!
  8. #1163
    Join Date
    Mar 2013
    Location
    Navodari
    Posts
    46
    Rep Power
    0
    Nu ti-a raspuns nimeni pentru ca nu poate nimeni .
    Ai vazut ceva asemanator pe forum ? Nici nu ai sa vezi .
    Daca masina a fost reparata in service-uri autorizate , ai sansa sa gasesti un raspuns la un asemenea service , contra cost , bineinteles .
    Daca masina a avut interventii la un mic atelier auto si nu a operat in cartea vehicolului , nu ai sa afli niciodata istoricul acesteia .
Tags for this Thread
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
