Buna ziua, ma puteti ajuta cu verificarea service(verificare istoric) a unui ViN VF38UAHWTFL013501
Multumesc anticipat.
Vin VF38D9HR8BL005211
Caracteristicile vehiculului
Linie de produs 508
Nr. APV/PR 12493 CJ 1 0220
Data de Inceput de Garantie 28.06.2011
NRE e2*2007/46*0080*00
P4A 9666506499
Informatii generale
GEN DE PRODUS VEHICUL PARTICULAR
MARCA COMERCIALA, TIP SUBANSAMBLU PEUGEOT
LINIE DE PRODUS 508
TIP CAROSERIE BERLINA 4 USI
NIVEL DE ECHIPARE INALTIME MEDIE PLUS
MOTOR DIESEL TURBO DV6C
TRANSMISIE CUTIE DE VITEZE MANUALA PILOTATA 6 TREPTE STOP AND START
TIP DE VOPSEA METALIZATA LACUITA
CULOAREA CAROSERIEI EEH - VOPSEA GRI HARIA2
TIP ECHIPARE INTERIOARA PIELE CLAUDIA "Q1"
CULOARE GARNISAJ "FX"
CUTIE DE VITEZE (CARACTERISTICI) CUTIE DE VITEZE MANUALA MCD
EVOLUTIE DEFINITIE TEHNICA GAMA VECHE
MOTOR (TIP) MOTOR TIP DV
Caracteristici vehicul
DIRECTIE SISTEM DE DIRECTIE ASISTATA
Alimentare motor
DETECTOR DE APA IN FILTRUL DE MOTORINA FARA SISTEM DE DETECTARE APA IN FILTRUL DE MOTORINA
CARBURANT MOTORINA CALITATE DA/DE/DE+
DEPOLUARE (MOTOR) DEPOLUARE EURO5 (MOTOR)
ESAPAMENT TOBA DE ESAPAMENT LONGITUDINALA
CILINDREE 1600 CM3
CATALIZATOR CATALIZATOR IMPREGNAT SUB 10PPM
RECIRE ULEI SCHIMBATOR PE MOTOR SI CUTIE DE VITEZE
REZERVOR DE CARBURANT REZERVOR CARBURANT CU ELEMENT DE INDEXARE
INCALZIRE CIRCUIT GAZE CARTER FARA SISTEM DE INCALZIRE CIRCUIT DE GAZE CARTER
VARIATE DE PUTERE (MOTOR) PUTERE MOTOR 82 KW - 270 NM
AUTODIAGNOSTICARE EOBD SISTEM DE AUTODIAGNOSTICARE "EOBD"
DISPOZITIV (ANTIPOLUARE) RECIRCULARE GAZE DE ESAPAMENT "EGR"
DEPOLUARE TEHNICA VEHICUL DEPOLUARE TEHNICA VEHICUL EURO5
FILTRU DE PARTICULE FILTRU DE PARTICULE
VENTILATOR 1 VENTILATOR ELECTRONIC CU DOUA TURATII 140W
VARIANTA SOCIATA INJECTIE SISTEM INJECTIE SIEMENS
LANT DE TRACTIUNE HIBRIDA FARA LANT DE TRACTIUNE HIBRID
FITRU DE REZERVOR FILTRU REZERVOR INTERIOR
STOP AND START CU STOP AND START
Cutie de viteze - Transmisie
CUPLU RAPORT RAPORT PUNTE 19 X 77
STIL ROATA (JANTA) STIL 09 17 INCI
AMBREIAJ FARA AMBREIAJ
DIFERENTIAL (CUTIE) DIFERENTIAL 84
JANTA / PNEU DIMENSIUNI ECHIPARE PNEU 17 INCI
PNEURI (DIMENSIUNI, TIP) PNEU 215/55 R17 94W NERANFORSAT
ROATA (TIP) MONTARE ROATA ALIAJ 3
INDICATOR DE PIERDERE A PRESIUNII DE UMFLARE FARA INDICATOR PENTRU PIERDERE PRESIUNE DIN PNEURI
CUTIE DE VITEZE TIP CUTIE DE VITEZE MANUALA MC
Suspensie - directie - Franare
BARA ANTIRULIU SPATE BARA ANTIRULIU SPATE DIAMETRU 20
ANTIRULIU FATA BARA ANTIRULIU FATA DIAMETRU 22,5
SUSPENSIE SUSPENSIE NORMALA
CONTROL DINAMIC AL STABILITATII CU SISTEM ESP
VARIANTA ASOCIATA FRANA ESP BOSCH 8 1
DIRECTIE (FUNCTIONARE) DIRECTIE ASISTATA ELECTROHIDRAULIC
Caroserie Echipamente
DISPOZITIV DE REMORCARE FARA DISPOZITIV DE REMORCARE
ORNAMENT LATERAL (ASPECT) FARA ELEMENTE DE PROTECTIE LATERALE
ORNAMENT DE ROATA (STIL) FARA CAPAC DE ROATA
LUMINA DE PRAG LUMINI DE PRAG FATA
SUPLIMENT DE PROTECTIE (SUB MOTOR) FARA PROTECTIE SUPLIMENTARA SUB MOTOR
INEL DE FIXARE EXTERIOR (ADAUGAT) FARA INEL DE ARIMARE EXTERIOARA SUPRAPUS
FUNCTIE COMPLEMENTARA DE RETROVIZOR EXTERIOR RETROVIZOR EXTERIOR RABATABIL ELECTRIC FARA MEMORIE
STERGATOR PARBRIZ MECANISM STERGERE PARBRIZ CU SENZOR DE PLOAIE
STERGATOR DE LUNETA FARA MECANISM DE STERGERE LUNETA
STERGATOR DE PROIECTOR MECANISM DE STERGERE PROIECTOR
OBTURATOR FATA FATA OBTURATOR INFERIOR PANOU FRONTAL
GEAM DE PAVILION FARA ELEMENT VITRAT DE PAVILION
LUNETA (GEAM DE CAPAC DE PORTBAGAJ) GEAM FIX DE CAPAC DE PORTBAGAJ
BARA DE PROTECTIE BARA DE PROTECTIE FATA/SPATE STANDARD CULOARE CAROSERIE + GRILA CROMATA
APARATOARE DE NOROI (BAVETA) FARA APARATORI DE ROTI SPATE
PORTBAGAJ MONTARE FARA USA SUPORT DE BAGAJE
PROIECTOR ANTICEATA PROIECTOARE ANTI-CEATA
ROATA DE REZERVA FARA ROATA DE REZERVA
ACCESORII EXTERIOARE MANER EXTERIOR SI CULISA ORNAMENT, CROMATE
RETROVIZOR EXTERIOR (RAZA ZONA CONDUCATOR) OGLINDA BOMBATA LA RETROVIZORUL EXTERIOR
TRAPA DE PLAFON ACOPERIS FIX
ORNAMENT DE BARA DE PROTECTIE BARA DE PROTECTIE CU INSERTIE CROMATA
GEAM (ASPECT) GEAM FUMURIU
GEAM (TIP) PARBRIZ STRATIFICAT CU IZOLARE FONICA + SPATE SECURIZAT
ACCES SI PORNIRE CU MAINI LIBERE ACCES SI PORNIRE CU MAINI LIBERE
PACHET ROTI MONTAJ PNEURI 17 INCI (DOL08) + MONTAJ JANTA ALIAJ 3 (DRP07) + FĂRĂ ROATĂ DE REZERVĂ (DRS00)
Echipament interior
ALARMA ANTIFURT FARA ALARMA ANTIFURT
SCAUN SPATE BANCHETA SEPARATA RABATABILA
DETECTARE UNGHI MORT FARA SISTEM DE SUPRAVEGHERE UNGHI MORT
COTIERA DE SCAUN SPATE CU COTIERA SPATE
CENTURA DE SIGURANTA SPATE CENTURI DE SIGURANTA SPATE CU 3 RETRACTOARE IN 3 PUNCTE + MARTOR LUMINOS DE CUPLARE
CLIMA (TEMPERATURA AMBIANTA) TARI CU CLIMA TEMPERATA
GRADARE VITEZE GRADATIE IN KM/H
PARTE CONDUCERE (POST DE CONDUCERE) VOLAN PE STANGA
INCALZIRE ADITIONALA FARA SISTEM DE INCALZIRE SUPLIMENTAR
ECHIPAMENT PLANSA DE BORD DECORATIUNE CUBIC CU OCHIURI MICI
LUMINI INTERIOARE DIVERSE CITITOR HARTA FATA + SPATE CU LED
GARNISAJ SPATIU DE INCARCARE COVORAS DE PORTBAGAJ + PARTI LATERALE DIN MOCHETA
TABLOU DE BORD (CARACTERISTICI) GRADATIE 260 KM/H 160 M/H MATRICE COLOR
CAPITONAJ DE USA DECORATIUNE TEP
DIFUZOR 4 DIFUZOARE FATA (2 TWEETERE + 2 FATA) + 4 DIFUZOARE SPATE
COMANDA DE SISTEM AUDIO COMANDA SISTEM AUDIO LA DISTANTA STANDARD
INSONORIZARE HABITACLU ELEMENT DE IZOLARE FONICA TABLIER 4 KG
IZOLATIE (TRANSPERANT, PARASOLAR LATERAL, TRAPA DE PLAFON) TRANSPERANT MANUAL SPATE
INALTARE SCAUN DE PASAGER FATA DISPOZITIV DE INALTARE PERNA PASAGER REGLARE PARALELA + AVANSARE
COMANDA DE SCAUN FATA DE CONDUCATOR COMANDA ELECTRICA SCAUN CONDUCATOR
COMANDA DE SCAUN FATA DE PASAGER COMANDA ELECTRICA SCAUN PASAGER FATA
REGLARE PERNA DE SEZUT FATA CONDUCATOR SUPORT LOMBAR CU REGLARE CONDUCATOR
REGLARE SCAUN FATA DE PASAGER REGLARE SUPORT LOMBAR PASAGER
SISTEM DE NAVIGATIE CU SISTEM DE NAVIGATIE CU ECRAN COLOR
BECURI DE PROIECTOR LAMPA CU DESCARCARE
ACTIONARE GEAM SPATE MECANISM ACTIONARE ELECTRICA GEAMURI SPATE CU COMANDA SECVENTIALA
ACTIONARE GEAM FATA PASAGER MECANISM DE ACTIONARE GEAM PASAGER FATA CU COMANDA SECVENTIALA
AFISAJ AFISAJ DEV
OGLINDA DE PARASOLAR OGLINDA CONDUCATOR + PASAGER ILUMINATA CU CAPAC
INDICATOR DE ULEI RECEPTOR TEMPORIZAT PENTRU NIVEL + TEMPERATURA
FOLIE INCALZIRE SCAUN SCAUN CU INCALZIRE
AIRBAG LATERAL FATA AIRBAG LATERAL ZONA TORACE + AIRBAG CORTINA
ILUMINAT JOS HABITACLU ILUMINAT ZONA PICIOARELOR CONDUCATOR + PASAGERI FATA + SPATE
PROTECTIE PASAGER SPATE FARA ELEMET DE PROTECTIE PASAGER SPATE
NEUTRALIZARE AIRBAG DEZACTIVARE MANUALA AIRBAG
PROIECTOR CORECTIE VERTICALA REGLARE AUTOMATA A PROIECTOARELOR
PROIECTOR DIRECTIONAL FARA PROIECTOR DIRECTIONAL
RECEPTOR RADIO RADIOTELEFON CU AFISAJ DEPLASAT ’RT6’
REFRIGERARE SISTEM DE REFRIGERARE AUTOMATA
REGULATOR DE VITEZA SISTEM DE REGULARIZARE SI DE LIMITARE VITEZA
INALTARE SCAUN FATA DE CONDUCATOR SISTEM DE INALTARE PERNA SCAUN CONDUCATOR CU REGLARE ELECTRICA
RETROVIZOR INTERIOR RETROVIZOR INTERIOR CROMAT ELECTROCHIMIC CU POZITII ZI-NOAPTE
REGULATOR CLIMATIZARE / TEMPERATURA SISTEM DE REFRIGERARE AUTOMATA CU PATRU ZONE
DEPOZITARE VOLUM DE INCARCARE FARA PLASA IN PORTBAGAJ
TUNER-RADIO TRI TUNER RADIO
DETECTAREA OBSTACOLULUI SISTEM DE DETECTARE OBSTACOL RADAR FATA SPATE MDP
STORURI LATERALE TRANSPERANTE LATERALE "RAND 2"
ADAPTARE GARNITURA MANER PIELE CU LUMINA DE FUNDAL
AMPLIFICATOR-EGALIZATOR FARA AMPLIFICATOR EGALIZATOR
FRECVENTA RADIO FRECVENTA RADIO EUROPA OCCIDENTALA
COMANDA DE BLOCARE BLOCARE PRIN SIMPLA INCHIDERE
VOLANT VOLAN IMBRACAT IN PIELE CU 3 BRATE
AIRBAG DE GENUNCHI CONDUCATOR FARA AIRBAG PENTRU GENUNCHI CONDUCATOR
ECRAN VIDEO SPATE FARA ECRAN VIDEO IN SPATE
PRIZA AUXILIARA PACK AUDIO 1 PRIZA JACK + USB
MODUL TELEMATIC MODUL TELEMATICA AUTONOM
Electricitate
ALTERNATOR ISTT50
BATERIE L3 760 VRLA1 EN AGM
DEMAROR DEMAROR CLASA 5
ILUMINAT DEOSEBIT APRINDERE AUTOMATA + LUMINI DIURNE FATA
FRECVENTA TELECOMANDA BLOCARE DESCHIDERI FRECVENTA TELECOMANDA DE BLOCARE 433,92 MHZ HETERODINA
APRINDERE LUMINI EXTERIOARE APRINDERE AUTOMATA A LUMINILOR + COMUTARE AUTOMATA
Marci echipamente
Diverse
CRITERIU FACTORI, CLIENTELA CONCEPTIE SERIE SPECIALA FRANTA
ATMOSFERA ATMOSFERA NORMALA
ETICHETA FARA ETICHETA
CONECTOR DE ASCULTARE SISTEM AUDIO PRIZA ACCESORII TRIPLA
PARTEA DE CIRCULATIE CIRCULARE PE DREAPTA
SET DE CHEI 2 CHEI TELECOMANDA DE INALTA FRECVENTA
ECHIPAMENT DE PRIM AJUTOR KIT REPARARE PROVIZORIE PNEU
RULARE DRUM CORECT
MODUL ELECTRONIC (BOÎTIER SERVITUDE) BSI EVOLUTION
TRIUNGHI DE PRESEMNALIZARE FARA TRIUNGHI REFLECTORIZANT
Istoric ? Nu. Caracteristici generale - da.
Multumesc mult si pentru alea
Atunci ia de citeste !
Linie de produs 508
Nr. APV/PR 13995 CJ 1 0224
Data de Inceput de Garantie 23.04.2015
NRE e2*2007/46*0080*29
P4A 9802301499
Informatii generale
LINIE DE PRODUS 508
TIP CAROSERIE BREAK RXH
NIVEL DE ECHIPARE CU EXCEPTIA STANDARDULUI COBORAT
MOTOR DIESEL DW10FC FAP 132KW
TRANSMISIE CUTIE DE VITEZE AUTOMATA 6 TREPTE TIP STOP AND START
TIP ECHIPARE INTERIOARA PIELE CLUB NAPPA "8B"
CUTIE DE VITEZE (CARACTERISTICI) CUTIE DE VITEZE AUTOMATA AM6C
EVOLUTIE DEFINITIE TEHNICA LA JUMATATEA VIETII
MOTOR (TIP) MOTOR TIP EW/DW
MONOGRAMA COMPLEMENTARA, DIVERSE BLUE HDI
Alimentare motor
DEPOLUARE (MOTOR) DEPOLUARE (MOTOR) EURO 6.1
CILINDREE 2000 CM3
INCALZIRE CIRCUIT GAZE CARTER SISTEM DE INCALZIRE A CIRCUITULUI DE GAZE DIN CARTER
DEPOLUARE TEHNICA VEHICUL DEPOLUARE TEHNICA EURO6
VARIANTA SOCIATA INJECTIE SISTEM DE INJECTIE DELPHI
CUPLU RAPORT RAPORT PUNTE 15 X 53
STIL ROATA (JANTA) ROATA CU JANTA DIN ALUMINIU STIL ARCHIPEL 18"
DIFERENTIAL (CUTIE) DIFERENTIAL 86
JANTA / PNEU DIMENSIUNI ECHIPARE CU PNEURI DE 18 INCI
PNEURI (DIMENSIUNI, TIP) PNEU 245/45 R18 W FARA INTARIRE
ROATA (TIP) MONTARE ROATA ALIAJ 4
INDICATOR DE PIERDERE A PRESIUNII DE UMFLARE INDICATOR PIERDERE DE PRESIUNE UMFLARE NORMA ECE 64.02
CUTIE DE VITEZE TIP CUTIE DE VITEZE AUTOMATA AM6 NORMA EURO6
BARA ANTIRULIU SPATE BARA ANTIRULIU SPATE DIAMETRU 21,5
ANTIRULIU FATA BARA ANTIRULIU FATA DIAMETRU 24,5
CONTROL DINAMIC AL STABILITATII CU SISTEM ESCAMOTABIL
ANTENA ANTENA + GPS
FUNCTIE COMPLEMENTARA DE RETROVIZOR EXTERIOR RETROVIZOR EXTERIOR RABATABIL ELECTRIC CU MEMORIE
INSONORIZARE PE MOTOR IZOLARE FONICA LA CAPOTA
STERGATOR DE LUNETA MECANISM DE STERGERE LUNETA
OBTURATOR FATA FATA CU OBTURATOR PE PANOUL FRONTAL AL MODULULUI DE INTRARE AER
GEAM DE PAVILION CU GEAM DE PAVILION
PORTBAGAJ MONTARE CU BARE DE ACOPERIS
PROIECTOR ANTICEATA FARA PROIECTOARE ANTICEATA
GEAM (ASPECT) GEAM FUMURIU + FUMURIU INCHIS
Echipament interior
DETECTARE UNGHI MORT CU SUSITEM DE SUPRAVEGHERE UNGHI MORT
CENTURA DE SIGURANTA FATA CENTURA DE SIGURANTA PIROTEHNICA DUBLA CU ALARMA
CLIMA (TEMPERATURA AMBIANTA) TARI CU CLIMA RECE
ECHIPAMENT PLANSA DE BORD DECORATIUNE ALUMINIU + DEGRADE
CAPITONAJ DE USA DECORATIUNE PIELE CLUB
DIFUZOR 4 DIFUZOARE FATA (2 TWEETERE + 2 DIFUZOARE) + 5 DIFUZOARE SPATE (2 TWEETERE + 2 DIFUZOARE + 1 SUBWOOFER)
IZOLATIE (TRANSPERANT, PARASOLAR LATERAL, TRAPA DE PLAFON) FARA TRANSPERANT SPATE
COMANDA DE SCAUN FATA DE CONDUCATOR COMANDA SCAUN FATA CU MEMORIE + REGLARE PARTE SUPERIOARA DE PERNA
COMANDA DE SCAUN FATA DE PASAGER COMANDA ELECTRICA SCAUN PASAGER FATA + REGLARE PARTE SUPERIOARA DE PERNA
BECURI DE PROIECTOR LAMPA CU LED
AFISAJ AFISAJ ECRAN DIGITAL TACTIL
PROTECTIE PASAGER SPATE CU PROTECTIE PASAGER SPATE
RECEPTOR RADIO RECEPTOR RADIO SMEG DIGITAL
COVORAS DE PODEA (ASPECT) COVORASE TRAMONTANE BRODERIE PIELE
DEPOZITARE VOLUM DE INCARCARE CU PLASA IN PORTBAGAJ
DETECTAREA OBSTACOLULUI SISTEM DE DETECTARE OBSTACOLE CU RADAR FATA SPATE + CAMERA VIDEO SPATE
STORURI LATERALE FARA TRANSPERANTE LATERALE
AMPLIFICATOR-EGALIZATOR CU AMPLIFICATOR EGALIZATOR
PRIZA AUXILIARA PACK AUDIO 1 PRIZA JACK + 2 USB
Electricitate
ALTERNATOR ISTT53
BATERIE L3 760 VRLA2 EN AGM
DEMAROR DEMAROR CLASA 6+
Marci echipamente
Diverse
CRITERIU FACTORI, CLIENTELA CONCEPTIE STANDARD
CONECTOR DE ASCULTARE SISTEM AUDIO PRIZA CVADRUPLA DE ACCESORII
RULARE DRUM CORECT
Sa o stapanesti sanatos !!
Multumesx frumos!
Buna, as dori si eu mai multe informatii. Multumesc
VF38DRHF8BL096344
VF38DRHF8BL096344
Trimite508 BERLINA 4 USI 2.0 HDi 138 FAP CUTIE DE VITEZE
Linie de produs 508
Nr. APV/PR 12785 CJ 1 0402
Data de Inceput de Garantie 30.03.2012
NRE e2*2007/46*0080*04
P4A 9691274299
Informatii generale
LINIE DE PRODUS 508
NIVEL DE ECHIPARE INALTA JOASA
MOTOR DIESEL TURBO DW10BTED4 FILTRU DE PARTICULE
TRANSMISIE CUTIE DE VITEZE MANUALA6
CULOAREA CAROSERIEI KGN - VOPSEA BOURRASQUE
TIP ECHIPARE INTERIOARA TESATURA NERVURON "5L"
CULOARE GARNISAJ "FD"
CUTIE DE VITEZE (CARACTERISTICI) CUTIE DE VITEZE MANUALA ML6 CL
MONOGRAMA COMPLEMENTARA, DIVERSE FARA MONOGRAMA SUPLIMENTARA
Alimentare motor
STOP AND START FARA SISTEM STOP AND START
DEPOLUARE (MOTOR) DEPOLLUTION MOTEUR SUPERIEUR L6 EURO 5
CILINDREE 2000 CM3
FILTRU DE PARTICULE CU FILTRU DE PARTICULE
CUPLU RAPORT RAPORT PUNTE 6 X 65
STIL ROATA (JANTA) STIL 02 16 INCI
AMBREIAJ AMBREIAJ HIDRAULIC
JANTA / PNEU DIMENSIUNI MONTAJ PNEU 16 INCI
PNEURI (DIMENSIUNI, TIP) PNEU 215/60 R16 95H FARA INTARIRE
ROATA (TIP) MONTARE ROATA ALIAJ 2
CUTIE DE VITEZE TIP ML6C
ANTIRULIU FATA BARA ANTIRULIU FATA DIAMETRU 23
ACCES SI PORNIRE CU MAINI LIBERE FARA ACCCES SI PORNIRE MAINI LIBERE
STERGATOR DE PROIECTOR FARA MECANISM DE STERGERE PROIECTOR
ROATA DE REZERVA ROATA JANTA TABLA + PNEU STANDARD
ACCESORII EXTERIOARE MANER EXTERIOR IN CULOAREA CAROSERIEI + CULISA ORNAMENT CROMAT
Echipament interior
COMANDA DE VITEZE COMANDA DE VITEZE LA PODEA
ECHIPAMENT PLANSA DE BORD DECORATIUNE IMITATIE LEMN
LUMINI INTERIOARE DIVERSE LAMPA DE CITIT HARTA FATA + SPATE + LED FATA
TABLOU DE BORD (CARACTERISTICI) GRADATIE 260 KM/H 160 M/H MATRICE MONOCROMA
CAPITONAJ DE USA DECOR TESATURA
INALTARE SCAUN DE PASAGER FATA SISTEM INALTARE PERNA SCAUN PASAGER REGLAJ INAINTE
COMANDA DE SCAUN FATA DE CONDUCATOR COMANDA MANUALA SCAUN CONDUCATOR
COMANDA DE SCAUN FATA DE PASAGER COMANDA MANUALA SCAUN PASAGER FATA
REGLARE SCAUN FATA DE PASAGER SPATAR SCAUN PASAGER CARE SE POATE INCLINA
BECURI DE PROIECTOR LAMPA CU HALOGEN
AFISAJ AFISAJ DEV
FOLIE INCALZIRE SCAUN SCAUN FARA INCALZIRE
ILUMINAT JOS HABITACLU FARA ILUMINAT INFERIOR DE HABITACLU
PROIECTOR CORECTIE VERTICALA REGLARE MANUALA DE LA DISTANTA A PROIECTOARELOR
INALTARE SCAUN FATA DE CONDUCATOR SISTEM DE INALTARE PERNA CONDUCATOR REGLARE MANUALA
REGULATOR CLIMATIZARE / TEMPERATURA SISTEM DE REFRIGERARE AUTOMATA CU DOUA ZONE
ADAPTARE GARNITURA MANER MANETA PIELE + BURDUF DIN MATERIAL PLASTIC
Electricitate
APRINDERE LUMINI EXTERIOARE APRINDERE LUMINI MANUALA
ALTERNATOR ALTERNATOR CLASA 15
BATERIE L3 720 EF
Marci echipamente
Diverse
CRITERIU FACTORI, CLIENTELA CONCEPTIE BUSINESS LINE
SET DE CHEI 1 CHEIE TELECOMANDA INALTA FRECVENTA + 1 CHEIE PRINCIPALA UNICA
ECHIPAMENT DE PRIM AJUTOR FARA ECHIPARE DE REZERVA
RULARE DRUM CORECT
salutare!se poate o verificare vin?: VF38D9HD8EL045942
orice fel de info este utila. multumesc anticipat.
VF38D9HD8EL045942
Linie de produs 508
Nr. APV/PR 13911 CJ 1 0060
Data de Inceput de Garantie 22.12.2014
NRE e2*2007/46*0080*24
P4A 9803147699
Informatii generale
LINIE DE PRODUS 508
TIP ECHIPARE INTERIOARA TESATURA COCHER
CULOARE GARNISAJ "FR"
MONOGRAMA COMPLEMENTARA, DIVERSE E-HDI
Alimentare motor
CILINDREE 1600 CM3
ANTENA ANTENA + GPS
Echipament interior
ECHIPAMENT PLANSA DE BORD DECORATIUNE SATIN ARGINTAT
TABLOU DE BORD (CARACTERISTICI) MAX: 260 KM/H-160 M/H, MAT BLANCH
INDICATOR DE ULEI FARA INDICATOR DE NIVEL DE ULEI
RECEPTOR RADIO SISTEM AUDIO ANALOG SMEG
COVORAS DE PODEA (ASPECT) FARA COVORAS SUPLIMENTAR
DETECTAREA OBSTACOLULUI SISTEM DE DETECTARE OBSTACOL CU RADAR SPATE
Electricitate
ALTERNATOR ISTT51
Marci echipamente
Diverse
RULARE DRUM CORECT
Va salut! se poate o verificare la acest VIN VF38D5FV8BL077860? Va multumesc anticipat.
Salut !!! si La Multi Ani !!!
Va rog toate informatiile pentru seria
VF3WC9HXC34139966
I said BYE BYE BYE !!!!!
Salutare tuturor si la multi ani!
Va rog, as vrea sa stiu istoricul unui 206 1.4 hdi.
Ieri am cumparat masina, adusa din Italia (in octombrie 2018).
M-ar ajuta mult sa stiu ce probleme a avut.
VIN VF32ABHZA47745416
Multumesc.
Scuze
seria este VF32A8HZA47745416
Pe link-ul de mai jos puteti vedea cum arata un raport scos de pe carvertical.com. Raportul a costat 69 lei.
Dupa cum puteti vedea, raportul este deficitar la sectiunea "Daune". Verifica in putine tari si valori procentuale aleatorii.
In cazul meu, am cumparat o masina adusa din Italia, deci, m-ar fi interesat verificarea in Italia, ceea ce nu s-a facut.
Spre deosebire de raportul esantion, raportul generat pentru masina mea nu contine date despre km parcursi, echipament si activitate identificata.
Cel putin am aflat ca nu e declarata furata.
In concluzie, nu cred ca a meritat banii.
https://www.carvertical.com/ro/rapor...b-75fe581fec9a
