Page 70 of 75 FirstFirst ... 2060666768697071727374 ... LastLast
Results 1,036 to 1,050 of 1114
Thread: VIN (Vehicle Identification Number) - Informatii utile
  1. #1036
    dumionut11's Avatar
    Oct 2009
    475
    Am gresit o litera, seria corecta este WF0LXXGCBLCA48335, cu zero in loc de "o"
  2. #1037
    Vizitator rogedan's Avatar
    May 2011
    Incearca pe forumul monomarca , adica la ford nu la peugeot .
  3. #1038
    dumionut11's Avatar
    Oct 2009
    475
    Am rezolvat...ramanem fidel marci pana la urma.
  4. #1039
    Jul 2010
    498
    Are cineva cont si pe Citroen...? Ca vad ca trebuie sa ma inregistrez cu firma...
  5. #1040
    norishor's Avatar
    Nov 2010
    Bucuresti / Campina (uneori in weekend))
    213
    Geo, daca ai nev. de caracteristici, da-mi seria si te ajut.
    Diagnoza PSA Tester ORIGINAL ->o722.222.577<- Reparatii chei telecomanda PSA
  6. #1041
    Feb 2016
    126
    Ceva caracteristici si pentru mine va rog ? Ma intereseaza in special daca are esp/asr .
    VF32A8HXF43074792
    Multumesc .
  7. #1042
    Mar 2012
    Cluj-Napoca, Romania
    56
    Quote Originally Posted by SoriNn View Post
    daca are esp/asr
    Cu ABS
    Fara ESP
    ANTIBLOCAGE ANTI-BLOCAGE ROUE
    CONTRÔLE DYNAMIQUE DE STABILITÉ SANS SYSTEME ESP
    VARIANTE ASSOCIÉE FREIN ABS TEVES MK70
    caracteristici VF32A8HXF43074792
    Caractéristiques du véhicule
    Ligne de produit 206
    N°APV/PR 09613 81 2 0111
    Date de Début de Garantie 09/04/2003
    NRE e2*98/14*0250*02
    Informations générales
    GENRE DE PRODUIT VEHICULE PARTICULIER
    MARQUE COMMERCIALE, TYPE ORGANE PEUGEOT
    LIGNE DE PRODUIT 206
    SILHOUETTE BERLINE 5PTES
    FINITION X LINE
    MOTEUR DIESEL TURBO DV4TD
    TRANSMISSION BVM5
    TYPE DE PEINTURE PEINTURE METALLISEE VERNIE
    COULEUR DE CAISSE EZR - PEINTURE GRIS ALUMINIUM
    TYPE D’HABILLAGE INTÉRIEUR TISSU TRESSE ANDORRE + EFKA "PA"
    COULEUR DE GARNISSAGE "FN"
    BOITE DE VITESSES (CARACTÉRISTIQUES) BVM MA5 / O
    MOTEUR (TYPE) MOTEUR TYPE DV
    MONOGRAMME COMPLÉMENTAIRE HDI
    MONOGRAMME COMPLÉMENTAIRE, DIVERS SANS MONOGRAMME COMPLEMENTAIRE
    MONOGRAMME SANS MONOGRAMME
    Caractéristiques véhicule
    FINITION X LINE
    DIRECTION DIRECTION ASSISTANCE NON VARIABLE
    COUPLE TACHYMÈTRE CT 21 X 18
    Alimentation moteur
    BOUCHON DE REMPLISSAGE CARBURANT BOUCHON CARBURANT COULEUR CAISSE
    DÉTECTEUR D’EAU FILTRE À GAZOLE AVEC DETECTEUR EAU FILTRE GASOIL
    CARTER CYLINDRE (MATIÈRE) CARTER CYLINDRE ALUMINIUM
    CARBURANT GAZOLE
    DÉPOLLUTION (MOTEUR) DEPOL CEE 2000 (MOTEUR)
    PRÉFILTRE MONTAGE SANS PREFILTRE
    CATALYSEUR CATALYSEUR 2 COMPOSES FILTRES IMPR PLATINE
    REFROIDISSEMENT D’HUILE ECHANGEUR EAU/HUILE MOTEUR
    OPTIMISATION DE CONSOMMATION DU VÉHICULE SANS OPTIMISATION CONSOMMATION CARBURANT
    MOTEUR REFROIDISSEMENT RADIATEUR EP:27 21 DM2 PAS 1,1 NON ENCLIQUETABLE
    RÉCHAUFFAGE CIRCUIT GAZ CARTER SANS RECHAUFFAGE CIRCUIT GAZ CARTER
    COUPURE ALIMENTATION CARBURANT AVEC COUPURE ALIMENTATION CARBURANT
    RHÉOSTAT AVEC RHEOSTAT
    AUTODIAGNOSTIC EOBD SANS AUTO-DIAGNOSTIC "EOBD"
    DISPOSITIF (ANTIPOLLUTION) RECIRCULATION GAZ ECHAPPEMENT "EGR"
    DÉPOLLUTION TECHNIQUE VÉHICULE DEPOLLUTION TECHNIQUE VEHICULE L4
    FILTRE À PARTICULE SANS FILTRE A PARTICULES
    VENTILATEUR 2 VENTILATEURS 2 VITESSES 250W
    RÉCUPÉRATION DES VAPEURS D’ESSENCE SANS RECUPERATION VAPEUR ESSENCE
    VARIANTE ASSOCIÉE INJECTION SYSTEME INJECTION BOSCH
    FILTRE RÉSERVOIR FILTRE RESERVOIR INTERIEUR
    BOÎTIER PAPILLON (ADMISSION AIR MOTEUR) SANS BOITIER PAPILLON(ADMISSION AIR MOTEUR)
    Boîte de vitesses Transmission
    TRANSMISSION BVM5
    COUPLE RAPPORT CP 17 X 64
    STYLE ROUE ROUE BOHEME 2 14 POUCES
    VERROUILLAGE SÉCURITÉ BOITE DE VITESSES SANS VERROUILLAGE SECURITE BV
    TYPE DE BOITE DE VITESSES (HOMOLOGATION) TYPE BV MA/5 O
    DIFFÉRENTIEL (BOITE) DIFFERENTIEL RENFORCE
    PNEUMATIQUE (DIMENSIONS, TYPE) PNEU 175/65 R14 82T NON RENFORCE
    ROUES MONTÉES ROUE 5 POUCES 1/2
    ROUE (TYPE) MONTAGE ROUE ALLIAGE
    BOITE DE VITESSES TYPE BVM MA
    Suspension Direction Freinage
    BARRE ANTIDÉVERS ARRIÈRE BARRE ANTI DEVERS AR DIAM 19
    ANTIDÉVERS AVANT BARRE ANTI DEVERS AV DIAM 20
    FREIN PRINCIPAL REPARTITION ELECTRONIQUE FREINAGE
    FREIN TYPE DISQUES AV VENTILES/TAMBOURS AR
    SUSPENSION SUSPENSION NORMALE
    PÉDALIER (TYPE) PEDALIER STANDARD
    Carrosserie Equipements
    AVERTISSEURS AVERTISSEUR STANDARD
    ANTENNE ANTENNE AV LONGUE
    DÉCORATION (ADHÉSIVE) MONTANT PORTE NOIR SANS FILETS DECORATIFS
    ENJOLIVEMENT LATÉRAL (ASPECT) PROTECTEURS LATERAUX TEINTES MASSE
    ENJOLIVEMENT LATÉRAL (DIMENSION) PROTECTEURS LATERAUX
    ENJOLIVEUR ROUE (STYLE) CABOCHON ALU BOHEME
    COMPLÉMENT DE PROTECTION (SOUS MOTEUR) SANS PROTECTION COMPLEMENTAIRE SOUS MOTEUR
    FONCTION COMPLÉMENTAIRE RÉTROVISEUR EXTÉRIEUR RETRO EXT RABATTABLE MANUEL
    ENJOLIVEUR DE SORTIE D’ÉCHAPPEMENT SANS ENJOLIVEUR SORTIE ECHAPPEMENT
    INSONORISATION COTÉ MOTEUR INSONO SOUS CAPOT + TABLIER +SOUS GMP
    ESSUIE-VITRE AVANT ESSUIE-VITRE AV SANS CAPTEUR DE PLUIE
    ESSUIE-VITRE ARRIÈRE ESSUIE-VITRE AR
    ESSUIE-PROJECTEUR SANS ESSUIE-PROJECTEUR
    OBTURATEUR FACE AVANT SANS OBTURATEUR FACE AV
    VITRE PAVILLON SANS VITRE PAVILLON
    PARE-CHOCS P/C COULEUR CAISSE DEPUIS MOD2000
    PARE-BOUE (BAVETTE) PARE BOUE AV DE ROUE AR
    PORTE-BAGAGES MONTAGE SANS BARRES DE TOIT LONGITUDINALES
    PROJECTEUR ANTIBROUILLARD PROJECTEURS ANTI BROUILLARD
    PROJECTEUR SPÉCIAL (DOUBLE-OPTIQUE) PROJECTEUR SIMPLE PARABOLE
    RÉTROVISEUR EXTÉRIEUR (COTÉ CONDUCTEUR) RETRO EXT CONDUCTEUR CDE MANUELLE
    RÉTROVISEUR EXTÉRIEUR (COTÉ PASSAGER) RETRO EXT PASSAGER CDE MANUELLE
    ROUE DE SECOURS ROUE TOLE + PNEU STANDARD
    ACCESSOIRES EXTÉRIEURS RETRO EXT ET POIGNEES EXT COULEUR CAISSE
    RÉTROVISEUR EXTÉRIEUR (RAYON COTÉ CONDUCTEUR) MIROIR ASPHERIQUE RETRO EXT
    TOIT OUVRANT TOIT FIXE
    ENJOLIVEMENT PARE-CHOCS BANDEAU DE PARE-CHOCS TEINTE MASSE
    VITRE ARRIÈRE (GENRE) VITRE AR CHAUFFANTE
    VITRE (ASPECT) TEINTEE
    VITRE CUSTODE (NATURE) SANS VITRE CUSTODE
    VITRE (TYPE) PARE-BRISE ATHERMIQUE
    Equipement intérieur
    ALARME ANTIVOL SANS ALARME ANTIVOL
    ALLUME-CIGARE ALLUME CIGARE AVANT
    APPUI-TÊTE ARRIÈRE APPUI TETE AR REGLABLE
    APPUI-TÊTE AVANT APPUI-TETE AV ARTICULE
    ASSISE ARRIÈRE BANQUETTE SEPAREE RABATTABLE
    ALARME INTÉRIEURE ALERTE PORTE OUVERTE(CLIGNOTTEMENT PLAFONNIER)
    CACHE-BAGAGES SANS CACHE BAGAGES
    CEINTURE DE SÉCURITÉ ARRIÈRE CEINT SECU AR 3 ENROULEURS 3 PTS
    CEINTURE DE SÉCURITÉ AVANT CEINTURE PYROTECHNIQUE SANS ALARME
    CLIMAT (TEMPERATURE AMBIANTE) PAYS FROIDS
    CLIMATISEUR AEROTHERME AVEC CHAUFFAGE AR
    GRADUATION VITESSES GRADUATION EN KM/H
    COMMODITÉS (POIGNÉES) POIGNEES AV + AR AVEC CROCHETS
    COMPTE-TOURS COMPTE-TOURS A AIGUILLE
    CONDITIONNEMENT RADIO ALIMENT ANTENNE RECEPTEUR HP AV TWEETER
    CONSOLE CONSOLE AVEC CHAUFFAGE AR
    COTÉ DE CONDUITE (POSTE DE CONDUITE) CONDUITE A GAUCHE
    COMMANDE À DISTANCE MONTAGE CDE A DISTANCE
    CHAUFFAGE ADDITIONNEL CHAUFFAGE ADDITIONNEL AUTOMATIQUE
    ECLAIRAGE RANGEMENT SANS ECLAIRAGE DE RANGEMENT
    ECLAIRAGE DE COFFRE VOLUME CHARGEMENT CDE AUTO ECLAIRAGE COFFRE OU VOL CHARGEMENT
    EQUIPEMENT PLANCHE DE BORD FACADE CENTRALE PAILLETEE + BOUTON DIFFUSEUR NOIR
    FEUX INT. DIVERS SANS FEU INTERIEUR DIVERS
    COMBINÉ (CARACTÉRISTIQUES) FOND CADRAN METAL
    COMPTE-TOURS (PRISE INFORMATIONS) COMPTE-TOURS INFO CALCULATEUR
    ANCRAGE SIÈGE ENFANT SANS ANCRAGE SIEGES ENFANTS
    HAUT-PARLEUR MONTAGE 2 HP AV + 2 TWEETERS
    COMMANDE D’AUTORADIO CDE AUTO-RADIO A DISTANCE SANS FONCTION CD
    REHAUSSE ASSISE AVANT PASSAGER SANS REHAUSSE ASSISE AV PASSAGER
    RÉGLAGE ASSISE AVANT CONDUCTEUR MAINTIEN LAT FIXE CONDUCTEUR
    RÉGLAGE ASSISE AVANT PASSAGER MAINTIEN LAT FIXE PASSAGER
    RABATTEMENT ASSISE AVANT CONDUCTEUR SANS RABATTEMENT ASSISE AV CONDUCTEUR
    RABATTEMENT ASSISE AVANT PASSAGER SANS RABATTEMENT ASSISE AV PASSAGER
    INDICATEUR DE TEMPÉRATURE EXTÉRIEURE INDICATEUR TEMPERATURE EXT
    COMPACT DISQUE MONTAGE COMPACT DISQUES
    BOITE DE RANGEMENT SANS BOITE DE RANGEMENT
    SYSTÈME DE NAVIGATION SANS SYSTEME NAVIGATION
    LÈVE-VITRE ARRIÈRE LEVE-VITRE AR CDE MANUELLE
    LÈVE-VITRE AVANT CONDUCTEUR LEVE-VITRE AV CONDUCTEUR CDE ELECTRIQUE
    LÈVE-VITRE AVANT PASSAGER LEVE-VITRE AV PASSAGER CDE ELECTRIQUE
    AFFICHEUR AFFICHEUR (MONTRE ET OU T°)
    MONTRE MONTRE NUMERIQUE
    INDICATEUR D’HUILE RECEPTEUR NIVEAU HUILE
    NAPPE CHAUFFANTE SIEGE NON CHAUFFANT
    SAC GONFLABLE LATÉRAL AVANT SAC GONFLABLE LATERAL AV DOUBLE
    SAC GONFLABLE PASSAGER SAC GONFLABLE COTE PASSAGER
    ORDINATEUR DE BORD SANS ORDINATEUR DE BORD
    PACK ÉQUIPEMENT SANS PACK EQUIPEMENT
    RÉTROVISEUR EXTÉRIEUR RETRO EXT CHAUFFANT
    NEUTRALISATION COUSSIN GONFLABLE NEUTRALISATION MANUELLE COUSSIN GONFLABLE
    COMMANDE INTÉRIEURE DE PORTE (ASPECT) COMMANDE INTERIEURE PORTE ASPECT NEUTRE
    PROTECTION POSTE AVANT SANS PROTECTION POSTE AV
    PARE-SOLEIL AVANT COTE COND+PASS (SANS INSCRIPT)
    RÉCEPTEUR RADIO SYSTEME AUDIO CASSETTE RDS "RB3"
    RÉFRIGÉRATION REFRIGERATION SIMPLE
    RÉGULATEUR DE VITESSES SANS REGULATION VITESSE
    REHAUSSE ASSISE AVANT CONDUCTEUR REHAUSSE CONDUCTEUR REGLAGE PARALLELE
    RANGEMENT (AUTRES) VIDE-POCHES PORTES AV + AR + AUMONIERE
    SURTAPIS (ASPECT) SANS SURTAPIS
    SAC GONFLABLE CONDUCTEUR SAC GONFLABLE COTE CONDUCTEUR
    RANGEMENT VOLUME CHARGEMENT SANS FILET DANS COFFRE
    TAPIS MOQUETTE TUFTEE RASEE F550
    TEMPORISATEUR D’ÉCLAIRAGE TEMPORISATEUR FIXE
    CONTACT TRANSPONDEUR
    ADAPTATION GARNITURE POMMEAU LEVIER VITESSE PLASTIQUE+ PASTILLE CHROME
    AMPLI-ÉQUALISEUR SANS AMPLI EQUALISEUR
    COMMANDE VERROUILLAGE VERROUILLAGE SIMPLE CONDAMNATION
    VOLANT VOLANT MOUSSE 3 BRAS
    VERROUILLAGE RANGEMENT VIDE-POCHES SANS VERROUILLAGE
    Electricité
    ALTERNATEUR ALTERNATEUR CLASSE 15
    BATTERIE BATTERIE L2 400
    DÉMARREUR DEMARREUR CLASSE 5
    ECLAIREMENT PARTICULIER SANS ECLAIRAGE PARTICULIER
    MULTIPLEXAGE MONTAGE MULTIPLEXE
    Marques d'équipements
    Divers
    CRITÈRE VARIANCE, CLIENTÈLE CONCEPTION PACK CLIM
    ATMOSPHÈRE ATMOSPHERE NORMALE
    BOITE DE PREMIERS SECOURS SANS BOITE PREMIER SECOURS
    PRISE D’ÉCOUTE RADIO SANS PRISE ACCESSOIRES
    CHOCS LATÉRAUX PORTE NON RENFORCEE
    JEUX DE CLÉS 1 CLE PLIP HF + 1 CLE PRINCIPALE UNIQUE
    ROULAGE BONNE ROUTE
    SURVEILLANCE VITESSE SANS SURVEILLANCE VITESSE
    TRIANGLE DE PRÉSIGNALISATION CONDITIONNEMENT TRIANGLE PRESIGNALISATION
  8. #1043
    Jan 2012
    Cluj-Napoca
    Salut! Imi poate face cineva o verificare?
    VF38D9HD8CL061293
    Vanzatorul spune ca are cutie automata, mie pe un site (autoDNA) mi-a aparut cutie manuala.
    Multumesc mult!
  9. #1044
    Jan 2015
    Quote Originally Posted by calinutz View Post
    VF38D9HD8CL061293
    Multumesc mult!
    508 BERLINA 4 USI 1.6 HDI 115 (DV6C) CUTIE DE VITEZE MANUALA PILOTATA (Cu stop and start)
  10. #1045
    Jan 2012
    Cluj-Napoca
    Quote Originally Posted by bragelone View Post
  11. #1046
    Ionut159's Avatar
    1,696
    VF38D9HD8CL061293
    Multumesc mult!
    AutoDNA-ul ala e gaselnita a unor tipi care de multe ori fac bani frumosi pe nimic. Exemplu concret: masina pusa la vanzare de mine cu 0 inregistrari in istoric la reprezentanta. Masina cumparata de la privat din FR si servisata din 15 in 15k km la garaj(service auto privat - omul lucra la receptie service acolo) cu toate facturile doveditoare de la 0 km pana la zi. Daca faceai verificare la autodna, iti zicea cum ca masina respectiva are 1 inregistrare legata de nr de km in istoric. Clientul s-a pus si a cumparat ceva raport de vreo 80 si ceva de lei(din ce am inteles sunt si mai ieftine), tentat de faptul ca ii spunea ca are 1 inregistrare. Cand a primit raportul surpriza: inregistrarea arata asa - data x(data la care am publicat eu anuntul pe autovit) - nr km Y(nr de km pe care i-am trecut eu in anunt). Mi-a aratat clientul raportul de la autodna dupa ce a verificat masina si am facut tranzactia, spunandu-mi "uite pe ce am aruncat 80 si ceva de lei".
    Acum strict legat de masina cu vin-ul postat de tine, uita-te foarte atent la poze si o sa observi niste probleme. Nu e topic-ul indicat pt a discuta despre asta, dar am discutat fix despre masina asta in privat cu un alt coleg care fusese interesat de ea.
  12. #1047
    Feb 2009
    Valcanesti
    Salut! M-am decis sa cumpar un Peugeot 308 si ma intereseaza si pe mine echiparea pe seria de sasiu VF34C9HXC55316042 cu cat mai multe detalii daca e posibil.
    Aparent nu e foarte echipat dar m-ar ajuta o descriere detaliata.
    Dau berica
  13. #1048
    Cristi_M.'s Avatar
    May 2010
    49
    2,230
    Astea-s:
    Ligne de produit 308
    N°APV/PR 11621 89 1 0729
    Date de Début de Garantie 21/01/2009
    NRE e2*2001/116*0362*04
    LIGNE DE PRODUIT 308
    FINITION MOYENNE BASSE
    MOTEUR DIESEL TURBO DV6ATED4
    TRANSMISSION BVM5
    COULEUR DE CAISSE ETS - PEINTURE GRIS CENDRE
    TYPE D’HABILLAGE INTÉRIEUR TISSU SIBAYAK + OMNI BITON "TQ"
    COULEUR DE GARNISSAGE "FX"
    BOITE DE VITESSES (CARACTÉRISTIQUES) BVM BE4 L
    DEFINITION A VENIR ANCIENNE GAMME
    Alimentation moteur
    ALIMENTATION INJECTION TURBO ECHANGEUR DIRECT
    CARBURANT GAZOLE
    DÉPOLLUTION (MOTEUR) DEPOLLUTION EURO 4(MOTEUR)
    CYLINDRÉE 1600 CM3
    CATALYSEUR CATALYSEUR 2 COMPOSES SUP 50PPM 140GR
    MOTEUR REFROIDISSEMENT RADIATEUR EPAISSEUR:27 - 21 DM2 ALU BRASE
    AUTODIAGNOSTIC EOBD AUTO-DIAGNOSTIC "EOBD" SANS ACCELEROMETRE
    DÉPOLLUTION TECHNIQUE VÉHICULE DEPOLLUTION TECHNIQUE VEHICULE EURO 4
    VENTILATEUR 1 VENTILATEUR 2 VITESSES 140W AERO SANS ECOPE
    RÉCUPÉRATION DES VAPEURS D’ESSENCE SANS RECUP VAPEUR ESSENCE
    TRANSMISSION BVM5
    COUPLE RAPPORT CP 19 X 72
    STYLE ROUE ROUE TOLE 15 POUCES
    EMBRAYAGE EMBRAYAGE HYDRAULIQUE
    DIFFÉRENTIEL (BOITE) DIFFERENTIEL 84
    JANTE / PNEU DIMENSION MONTE PNEU 15 POUCES
    PNEUMATIQUE (DIMENSIONS, TYPE) PNEU 195/65 R15 91H NON RENFORCE
    ROUES MONTÉES ROUE 6 POUCES 1/2
    ROUE (TYPE) MONTAGE ROUE TOLE
    INDICATEUR DE PERTE DE PRESSION DE GONFLAGE SANS INDICATEUR PERTE PRESSION GONFLAGE
    BOITE DE VITESSES TYPE BVM BE4R
    VARIANTE ASSOCIÉE FREIN ABS BOSCH 8 1
    BARRE ANTIDÉVERS ARRIÈRE BARRE ANTI DEVERS AR DIAM 27
    ANTIDÉVERS AVANT BARRE ANTI DEVERS AV DIAM 22,5
    FREIN TYPE DISQUES AV VENTILES/DISQUES AR
    ACCÈS ET DÉMARRAGE MAINS LIBRES SANS ACCES/DEMARRAGE MAINS LIBRES
    ATTACHE-REMORQUE SANS ATTACHE REMORQUE
    ANTENNE ANTENNE PAVILLON COURTE
    DÉFLECTEUR AÉRODYNAMIQUE ARRIÈRE MONTAGE SANS DEFLECTEUR AR
    ENJOLIVEMENT LATÉRAL (ASPECT) PROTECTEURS LATERAUX TEINTE MASSE
    ENJOLIVEUR ROUE (STYLE) STYLE PACAYA 15 POUCES
    FEU DE RECUL AVEC 1 FEU RECUL
    FEU D’ÉCLAIRAGE DE SEUIL SANS FEU ECLAIRAGE DE SEUIL
    PARE-BOUE PARE-BOUE STANDARD
    ESSUIE-VITRE AVANT ESSUIE-VITRE INTERMITTENT 2 VITESSES
    ESSUIE-VITRE ARRIÈRE (FONCTIONNEMENT) ESSUIE VITRE AR INTERMITTENT AUTO MARCHE ARRRIERE
    VITRE VOLET ARRIÈRE VITRE VOLET AR FIXE
    PARE-CHOCS PC AV STCC JONC+BRT CH+AR STCC
    PARE-BOUE (BAVETTE) SANS BAVETTES AR
    PLAQUE POLICE SANS PLAQUE POLICE
    RÉTROVISEUR EXTÉRIEUR (COTÉ CONDUCTEUR) RETRO EXT CONDUCTEUR CDE ELECTRIQUE
    RÉTROVISEUR EXTÉRIEUR (COTÉ PASSAGER) RETRO EXT PASSAGER CDE ELECTRIQUE
    ACCESSOIRES EXTÉRIEURS POIGN EXT + PIED RETRO + RETRO CC
    RÉTROVISEUR EXTÉRIEUR (RAYON COTÉ CONDUCTEUR) GLACE RETRO EXT BOMBE
    VITRE (TYPE) P-B FEUILLETE ACCOUSTIQUE + AR TREMPE
    SAC GONFLABLE GENOUX CONDUCTEUR SANS SAC GONFLABLE GENOUX CONDUCTEUR
    PRISE AUXILIAIRE PACK AUDIO SANS PRISE AUXILIAIRE PACK AUDIO
    BOITIER TELEMATIQUE SANS BOITIER TELEMATIQUE
    ASSISE SUPPLÉMENTAIRE SANS ASSISE SUPPLEMENTAIRE
    ACCOUDOIR ASSISE ARRIÈRE SANS ACCOUDOIR AR
    CACHE-BAGAGES TABLETTE
    CEINTURE DE SÉCURITÉ AVANT ENROUL PYRO AV + ALARME BOUCLAGE COND
    CONDAMNATION ENFANT CONDAMNATION ENFANT MANUELLE AR
    ECLAIRAGE DE COFFRE VOLUME CHARGEMENT CDE AUTO ECLAIRAGE COFFRE ET VOL CHARGEMENT
    EQUIPEMENT PLANCHE DE BORD PL/BORD EMBASE WARM SILVER U NOIR
    FEUX INT. DIVERS LECTEUR DE CARTE
    TABLETTE DE TRAVAIL SANS TABLETTE TRAVAIL
    RANGEMENT SOUS SIÈGE SANS RANGEMENT SOUS SIEGE
    COMBINÉ (CARACTÉRISTIQUES) GRADUATION 230 KM/H 140 M/H FOND NOIR CERCL CHROM
    HAUT-PARLEUR 4 HP AV (2 TW + 2 AV) + 2 HP AR
    INSONORISATION HABITACLE INSONO TABLIER 13 KG
    COMMANDE ASSISE AVANT CONDUCTEUR CDE SIEGE AV MANUEL CONDUCTEUR
    COMMANDE ASSISE AVANT PASSAGER CDE SIEGE AV MANUEL PASSAGER
    RÉGLAGE ASSISE AVANT CONDUCTEUR DOSSIER CONDUCTEUR INCLINABLE
    RÉGLAGE ASSISE AVANT PASSAGER DOSSIER PASSAGER INCLINABLE
    ACCOUDOIR ASSISE AVANT ACCOUDOIR CENTRAL ASSISE AVANT
    COMPACT DISQUE SANS MONTAGE COMPACT DISQUE
    LAMPES DE PROJECTEURS LAMPE HALOGENE
    LECTEUR D’INFORMATIONS ROUTIÈRES SANS SURVEILLANCE TRAJECTOIRE LATERALE
    LÈVE-VITRE AVANT CONDUCTEUR LEVE-VITRE AV CONDUCTEUR CDE SEQUENTIELLE
    LÈVE-VITRE AVANT PASSAGER LEVE-VITRE AV PASSAGER CDE SEQUENTIELLE
    AFFICHEUR AFFICHEUR (RADIO+MONTRE+ET OU T°,CD) SANS MEMOIRE
    ACCESSOIRES INT. DIVERS SANS FILET ANTI REMOUS
    MIROIR DE COURTOISIE CONDUCTEUR+PASSAGER OCCULTABLE SANS ECLAIRAGE
    REPOSE-PIED REPOSE PIED CONDUCTEUR
    MATELASSURE COUSSIN MATELASSURE ASSIVE AV STANDARD
    SAC GONFLABLE LATÉRAL AVANT SANS SAC GONFLABLE LATERAL AV
    ECLAIRAGE BAS HABITACLE SANS ECLAIRAGE BAS HABITACLE
    COMMANDE INTÉRIEURE DE PORTE (ASPECT) PALETTE PORTE ASPECT CHROME + ENJOLIVEUR COLORE
    PROJECTEUR CORRECTEUR ASSIETTE REGLAGE MANUEL A DISTANCE PROJECTEURS
    PROJECTEUR DIRECTIONNEL SANS PROJECTEUR DIRECTIONNEL
    PARE-SOLEIL AVANT COTE CONDUCTEUR+PASSAGER SANS INSCRIPTION
    RANGEMENT (POSTE CONDUITE) RANGEMENT LUNETTES
    RÉCEPTEUR RADIO SYSTEME AUDIO COMPACT DISC RDS "RD4"
    RÉFRIGÉRATION REFRIGERATION AUTOMATIQUE
    RÉTROVISEUR INTÉRIEUR RETROVISEUR INT JOUR - NUIT
    RANGEMENT VOLUME CHARGEMENT AVEC FILET DANS COFFRE
    TUNER-RADIO MONO TUNER RADIO
    DÉTECTION D’OBSTACLE SANS DETECTEUR OBSTACLE
    STORES LATÉRAUX SANS STORES LATERAUX
    SURTAPIS SANS SURTAPIS
    FRÉQUENCE RADIO FREQUENCE RADIO ASIE
    COMMANDE VERROUILLAGE VERROUILLAGE SIMPLE CONDAMNATION +AUTOMATIQUE
    Electricité
    ALLUMAGE FEUX ALLUMAGE FEUX MANUEL
    DÉMARREUR DEMARREUR CLASSE 6
    ECLAIREMENT PARTICULIER FEUX DIURNE AV
    MESURE CHARGE BATTERIE SANS MESURE CHARGE BATTERIE
    Divers
    CRITÈRE VARIANCE, CLIENTÈLE CONCEPTION INCITATION FISCALE DEPOLLUTION L5
    PRISE D’ÉCOUTE RADIO PRISE ACCESSOIRES
    JEUX DE CLÉS 1 CLE PLIP HAUTE FREQUENCE+1 CLE PRINCIPALE UNIQUE
    EQUIPEMENT DE SECOURS SANS EQUIPEMENT SECOURS
    BOÎTIER SERVITUDE BSI EVOLUTION."
  14. #1049
    Aug 2016
    27
    Salutare , ma puteti ajuta si pe mine cu o detaliere VIN VF38DRHHABL031565 .Multumesc frumos.
  15. #1050
    Jan 2017
    POPESTI LEORDENI
    Salut un ajutor cu o serie daca se poate VIN VF38DRHC8CL003728
Tags for this Thread
