coduri injectoare bosch - dilema
  • coduri injectoare bosch - dilema
    am o nelamurire si nu am gasit nici un om in Timisoara sa-mi explice
    injectoarele bosch , pe langa cele 2 coduri mai au o litera care poate fi X Y sau Z ---sau o cifra de la 1 la 3
    singura explicatie ar fi aici:
    http://www.reparationinjecteur.co.uk...asp?ID=1803114
    "On this picture we find 0445110087 ou 0 445 110 087 on the head of the injector.Some injectors admit an injection grade for a particular flow. This is a number 1 to 3 or a letter X, Y, Z and rimmed engraved on the head of the injector. This class identifies a flow, it is normally unthinkable to mix class for the same series of injector.
    Above an injecteur 0 445 110 044 class 2
    A final category of injectors IMA has a number engraved on the head of the injector. This new generation of injector compensates for wear of injectors by an intervention by the injection computer. The introduction of the IMA code in the computer used to set the base against a manufacturing tolerance."
    ideea ar fi: pot fi diferite literele la acelasi set de injectoare pe un motor? si are importanta ce litera cu ce model de pompa sau ce piston este montat pe motorul respectiv?
    https://ibb.co/1ZWTvPt
    https://ibb.co/drChG38
    https://ibb.co/Z83v1Mx
    mirceaq
